Stripping gelcoat - Fiberglass RV
Old 04-02-2018, 09:33 AM   #1
philtripp's Avatar
Trailer: Ventura
Manitoba
Stripping gelcoat
Hey all. Been a while! The Ventura is coming along great with the interior 95% complete. I’ll post some pics in another thread a little later.
My current question is about fiberglass/gelcoat. The roof of the camper is quite badly damaged and my plan is to strip the gelcoat off and add several new layers of glass. Sounds like a good idea...the only problem is that stripping the gelcoat off is proving to be a nightmare. Any tips for removal? Can I simply lay new fiberglass over the gelcoat?
Your help would be greatly appreciated! Oh and if you have some warmer weather feel free to send it my way, I’m currently sanding on the driveway in -16C!
philtripp is offline   Reply With Quote
Old 04-02-2018, 09:35 AM   #2
phil you must want it off pretty bad! wow!
good luck
bob
Old 04-02-2018, 09:40 AM   #3
philtripp's Avatar
Trailer: Ventura
Manitoba
On a bit of a time crunch. Would like to get the repair done before I go for ACL surgery [emoji51]
Old 04-02-2018, 09:41 AM   #4
rbryan's Avatar
Arkansas
Generally, glass should be laid on glass unless you're talking about a small repair where the edges are still gelcoat. Put it on gelcoat and you'll probably be able to pry it up with a putty knife. Removing gelcoat is difficult to say the least. If you take a look around the fiberglass boat forums you'll find that the usual method involves very aggressive sanding (no finer than 40 grit) and a lot of time and patience. Once down to good glass, you'll have good adhesion for additional layers.
Old 04-02-2018, 09:42 AM   #5
I don't know why not. That's exactly how repairs are done. I don't know of anyone that completely removed the gelcoat to do a repair. Yes it needs to be roughed up and completely wax free before the repair is started.
Good luck. Post pics!!
Old 04-02-2018, 09:50 AM   #6
John in Santa Cruz's Avatar
Mid Left Coast
6" angle grinder with 40 grit disks, wear a breather mask as you'll be making a lot of nasty dust.
Old 04-02-2018, 11:01 AM   #7
mszabo's Avatar
Trailer: U-Haul VT16
Like John says!
Old 04-02-2018, 11:23 AM   #8
ohhh
oh to have you guys energy again!!
bob
Old 04-02-2018, 12:10 PM   #9
philtripp's Avatar
Trailer: Ventura
Manitoba
Thanks everyone. Angle grinder with sanding disks is working like a charm!
Old 04-02-2018, 01:00 PM   #10
philtripp's Avatar
Trailer: Ventura
Manitoba
Here are some pics of my shenanigans. About half done stripping the roof! Hopefully by weeks end I’ll have some warm enough temps to lay down a few new layers of glass.
ID:	117292Click image for larger version
ID:	117293Click image for larger version
Old 04-02-2018, 01:20 PM   #11
philtripp's Avatar
Trailer: Ventura
Manitoba
Originally Posted by JB Mitt View Post
How is it damaged, like a tree fell on it, or like it is badly sunbeaten?
Mostly hail damage. And lots of pin holes. 5 or so bigger cracks from who knows what! I pulled it out of a farmers field so it’s anyone’s guess.
Stripping paint from the fibreglass: Smart Strip results coalminecanary Modifications, Alterations and Updates 5 09-06-2016 11:01 AM
Can I replace the weather stripping ? ted saxton Problem Solving | Owners Helping Owners 2 05-24-2009 06:46 PM
new weather stripping carole sullivan Problem Solving | Owners Helping Owners 1 04-25-2008 01:31 PM
Fiber Stream Door's Weather Stripping Charlie D Problem Solving | Owners Helping Owners 4 05-23-2006 09:47 PM
