Sure Mr Jon W, here is the skinny from Adrian,
Stone/gravel gaurd sprayed on first - available thru Napa, Dupont, Glasurite
its clear and applied in the front below the window and slightly around the front curves
Paint - Mfgr. Glasurite, color white, acrylic enamel
No clear coat applied but a small amount of "flex-agent" is mixed with paint ( this is the type of paint you use when
painting auto bumpers) This is readily available from Napa etc. You use this to make the paint more flexible to work with
fiberglass and it should make it less apt to chip
Hope this helps Regards Suger
Adrian also cautions that the
fiberglass must be wiped down very well (Miss Rays has noted in past too.) because
fiberglass can hold grease, wax, silicone etc. If not prep'd correctly paint will "fish eye"
Adrian also noted an 'anti fish eye' additive can be mixed with the paint
