06-19-2010, 04:41 PM
Trailer: 1983 13 ft Scamp and 1985 13 ft Scamp
Been visiting the site for some time, and learned alot, now I was going to show what I have been doing
When we purchased the Scamp, we found out that the floor and the frame needed extensive work, so we took the Scamp and have the frame beefed up, axle lowered to raise the Scamp up and put in a new sub-floor.
06-19-2010, 04:59 PM
HEY I THINK I have figure this pic stuff out
So if nobody minds, here is my story.
After the Scamp came home, I moved it down to my shop to get on withthe battle of the LEAKS
The PO was screw crazy and King of the silicon way.
The PO was vent crazy too
I was beginning to wonder what did I get into
But I was getting a ton of info from all of you guys
06-19-2010, 05:08 PM
So that's was the outside, come on in and look on the inside
The LEAKS, all that nasty water be hind that cool ensolite, no wonder it was squishy.
The biggest damage was at the spare tire area, whare the bolts go thru the fiberglass.
Water had ruined the wood for the table support
It also damaged that particle board floor
The water also damaged the tabs for support of the benches
06-19-2010, 05:25 PM
Looks like that title was well-deserved. Holy cow!
Good on you for giving it the "Royal" treatment
(just because you made it sound so funny; even though you must have been going crazy)
"King of the Silicone Way"
06-19-2010, 06:52 PM
Well I have learned a new trick today, now I need to know the proper etiquette on how much one is allowed to post in a time frame
Well the Scamp folly has been on-going since the fall, and I feel catching up on stuff, since I have made some inroads
I guess someone can just tell me to be quiet if I am babbling on too much.
On with the Scamp Saga
Water damage at those pesky vents too,
And then I found some leaks at the band area by the street side louvered window,
that ensolite I was trying to save so badly is taking a beating
Oh, and then I had to read up on Raya's stuff about fiberglass, another new skill, and thru all this I still was thinking about camping and sleeping and late night nature calls, and Adrian and myself hate to crawl over each other.
06-19-2010, 07:08 PM
If you noticed I jerked out the power box and fiberglassed a patch in on of the upper vents above the belly band,
from the previous post
I used the gel type resign and glass, it was color coded and made it easier for me to see what I did, I also added stainless steel plate behind the bolts for the spare. Decided not to put wood back for a table just figue I would use a floor mount
Had to made new wooded tabs, didnot take old out just put solid wooden one under old partical boaed ones and then glued, screwed and fiberglass in from bottom up, had to do that for both benchs
So I am still thinking of changing the layout for sleeping, but now started making pattern for floor, good gosh, does this mean I am going in the other direction? Will I get this thing together for the maiden voyage in May?
06-19-2010, 07:20 PM
Card board is great stuff, kids make forts, people (unfortunately) live in it, I have made a boat with it, floated too!
well any way, great pattern making stuff
New subfloor, ready for flooring
Now... Vinyl or Laminate
06-19-2010, 07:34 PM
Still a little goofy on this uploading gig, pic's get out of order, well
Flooring, Peel and stick from home depot, have used it commercial jobs, key is prep, always use the enhancer and floor leveler if needed. the enhancer is like a liquid contact cement, you'll never see them pop after you use it, even if the floor is flooded with water.
after picking up the benches, the bottom braces had to be replaced and I added some more support strips
06-19-2010, 07:49 PM
Let's see, All the screw holes patched,
Repaired spare tire mount,
Removed and repaired damged floor
Removed and discarded, water supply, power box
Patched water supply hole, Heater vent hole, additional frig vent hole,
Repaired benches and support ledges
Installed new sub-floor and vinyl
Removed damaged copper gas line
Total re-wire of lights, kept old pie-pan back lights new side lights
Thinking about adding outside access hatch, YIKES I am going to put a hole in this thing?
The old sink/stove layout is not what I think I want, back to the cardboard
06-19-2010, 07:53 PM
Trailer: 1976 Scamp 13 ft
Sugar, great to see someone else doing a super job on re-contruction. I've been at it a year and should be done in a couple of months, maybe. Thanks for the photo's and insperation.
Dan H
06-19-2010, 08:03 PM
Well so I go hunting and look what Adrian (the best lookin guy in East Tn!) has done while I was gone for 3 weeks!!!
It's not the stock color of Scamp but man was I surprised
And then he and his buddies put this type of coating on the front kinda like a sprayed anti-stone chipper stuff.
You'll notice I moved the power supply and put a ship shore type in (pick'd up the idea from peter) I didn't like the idea of dragging that cord thru a hole, and the access hole is easier for leveling blocks and jacks.
06-19-2010, 10:13 PM
Rambling on too much? I hardly think so. You're cranking on that baby and it's great to read about it and to see the photos Keep the updates coming
Raya
PS: Okay, maybe see if you can rotate the photos
PPS: Oh, Wow! Your last photos were posted while I was typing. Shiny!!
06-20-2010, 06:59 AM
New lesson for today, make sure the pic's are positioned so you don't have to stand on your head to view, here goes
No name for the Scamp yet, still trying to figure layout and what should stay and what goes
the fiberglass station that came with the scamp was chopped up pretty bad, out it goes, cabinets to be made,
gun-shy about removing front bench, don't know why
Decided, No sink, No stove, Need screen door, more drawers, place for microwave, 110 and 12 volt, reading lights, Awning or screen room, outside light, means to tap into propane for outside cooking, roll-out tray for storage access in center of front bench, Can not decide to keep made made up or if to change sleeping layout/ head at rear to avoid crawling over each other
Started out with a tall cabinet for micro and to cover for street side support
Began thinking about extending bed
Problem is storage and attachment of bed extension
decided tall cabinet makes scampie too closed in feeling, will figure micro location later but think I will put a counter snap extension on left, had to keep access in front bench street side hole for 110 box and future 12v wiring
06-20-2010, 08:09 AM
Trailer: Aliner
Photos and information like this is what makes this forum the best source of repair/rebuild info on the net.
Thanks for taking the time to share your progress with us. I REALLY appreciate it.
06-20-2010, 09:04 AM
Trailer: Boler 1984
Great work on your project. I love all the pictures. Don't forget to wear sunglasses for the first time you see the new paint job out in the sunlight.
06-24-2010, 07:46 PM
Hi, as the story goes, did not get everything done before the maiden voyage to Virginia/North Carolina. Forget cabinets, bed layout, and new table - LETS GO CAMPING,
Really it was good, Learned a ton of stuff, laughed a lot too.
First off, stuff shifted in transport, few little things added to the list of must have's
Then the first two days RAIN -lots of rain- Our buddies have a 13' scamp with a awning attached, the one you get from scamp - Not going to put that type on water runs down the edge and too small, saw a Coleman event canopy at a camp ground, that's the one I want, oh yeah when I get home and start searching - discontinued - hey thats the just my luck, well thank god for craigs look, found one in Arizona, paid as much in shipping as for the product, should arrive by wed.
Since I Had those two vents on the side and nothing to block the air, where did I camp? Well - at MILE HIGH Campground in North Carolina. OH yeah and of course it was cold, say in the 30's and then rain, BUT I did find out cube heater can keep you toasty.
Well enough jabbing put new stickers on the scamp, and before we took off replaced all the screws with stainless and caps, (And NO, NO, silicone) Butyl then pushed the screws thru, used acorns on the inside
If you notice I use a plastic frig vent for the upper exhaust for future frig, it has screening and it worked out to stay below the band, Adrian and myself could not find if out if the little trees were also on the front of the scamp
06-24-2010, 08:05 PM
On the maiden outing, decided the door needs work,
Added interior bracing, and a door stop and then also an outside 12v light(wiring in the future)
Also on the trip decided maybe another type of closet just to right of the door when you come in for hanging stuff.
06-24-2010, 08:36 PM
Now the big push is to complete the cabinets, re-work the door's of closet and overhead ( have them cut out and picked up the hardware) And what to do about the big lack of wall covering where I fixed the fiberglass
(Had to learn how to make pic's smaller to up load)
new door stop
wall covering, ensolite gone, none to find and I have another spot over on the street side where heater vent was, what to do?
door support, but may rework this latter
06-24-2010, 08:54 PM
So, going along to get parts, and what do I see
What's inside?
Could have some potentional
06-24-2010, 08:57 PM
I swear these things are like a DRUG, once your into them cannot get enough of them
I bought it on the spot, found out all the interior pieces were in the guys yard, loaded everthing in the scamp, hooked up to the truck and my friends think I am hatching these eggs
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Suger's Scamp Awning
sugermc |
22 |
05-24-2015 08:28 AM |
