suggestion for lighting trailer interior - Fiberglass RV
Old 06-07-2014, 01:08 PM   #1
Among many upgrades I'd like to do to my 98 Casita LD is improve the interior lighting. I am a newby to electrical so please explain accordingly.
My trailer currently has original lights are just inside the door, another on wall alongside sink midway of trailer and a final one under the shelf above rear window. There is also a very faint hood vent light that can be turned on over the stove.
I see pictures of nicer looking light fixtures in the forum on newer trailers.
What would be the best and most do-able approach for improved lighting?
I would like to do it myself to keep cost down so am hoping I don't have to be an electrician to figure it out. Also, is LED lighting much brighter than the current bulbs? LED vs Flourescent??
outdoorman is offline   Reply With Quote
Old 06-07-2014, 01:29 PM   #2
I would choose LED over florescent any day. You might try LED in the current fixtures before adding or replacing them. Unless Casita changed the fixtures over the years, they are probably a standard auto bulb and are widely available in LED.
Dim lights makes me wonder if you are getting full power to them. You might use a volt meter to make sure you are getting 12+ volts.
2009 Casita FD - Sold
Dave Fish is online now   Reply With Quote
Old 06-07-2014, 02:00 PM   #3
I used LED puck lights that used 3 LED batteries. I had 3 of them and they make the trailer bright. I have a solar led light from ikea we use, so in the four weeks we spent in the trailer the batteries never died.
I am not very good with electronics, but got help from this site, took a cell phone charger from the dollar store (as it is meant to plug into 12 volts, and drops it to the right voltage for the LED lights) and ended up wiring in two of the lights so I Know longer need to worry about batteries. The one that was too much effort to wire in is still on batteries. The three lights, wire, part to drop the voltage was cheaer than buying one LED light meant for an RV from princess auto.
Costco in canada has an interesting package of battery LED lights with a remote control, I would look at that if I was starting now, and wire them in to avoid the hassle of batteries.
Nelmes is offline   Reply With Quote
Old 06-07-2014, 09:08 PM   #4
Virginia
You have a couple of options. The easiest is to retrofit your existing lights with LED panels. You can find panels like this that plug in where your light bulb would go. No wiring required.
Or you could replace the lighting fixtures all together. This LED fixture is $32, it uses 5 watts of power, and it generates 520 lumens, which is roughly double what the factory lighting fixture can put out. As for the wiring, you only have 2 wires - negative and positive.
A few notes about LEDs:
Brightness: LEDs are generally dimmer than incandescents. But you can find really bright ones if you look around. If you look at the specs for the bulb, you'll see the light output measured in lumens. I wouldn't get anything less than 200 lumens. They're more expensive, but well worth it.
LED vs Fluorescent: LED is better, hands down. It has a longer life, it uses less power, it takes up less space, it's not as fragile, it's not filled with toxic gas, and it doesn't flicker when it gets old. The only reason CFLs still exist is because they're slightly cheaper.
Color Temperature: If you're converting to LED, pay particular attention to the color temperature. The "cool white" bulbs are cheap and bright, but they put out this really harsh blue-tinted light that most people find annoying. The "warm white" bulbs are the same color as incandescent lights and that's what I would recommend.
mmcwhort is offline   Reply With Quote
Old 06-07-2014, 09:27 PM   #5
Your posts have been helpful in me deciding to go with LED lights for the interior.
I think I'll try replacing the bulbs with LED screw in; also add a double LED light under my rear cabinet unit.
Thanks
Old 07-03-2014, 11:33 AM   #6
GMike A's Avatar
LED Lighting
I bought these on ebay 10 for 17 bucks with free shipping and they are awesome.
10 x White 48 SMD Panel Dome Map Interior Light Lamp BA15S 1156 Adapter DC 12V | eBay
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 07-03-2014, 12:12 PM   #7
sarahspins's Avatar
Trailer: 1984 13' Scamp named "Ramblin Rose"
I just installed new LED fixtures inside of my 13' scamp and I'm very happy with the light output of all of them, and I only went with 150 lumen fixtures... I didn't want everything super bright, but it is very well-lit with all of them on. Power usage is VERY low as well.. I've measured about .6amps with all of them on.
I did use a 250 lumen flat bulb for my porch light, and it's super bright - I'm actually going to wire that one into a dimmer so that I can tone it down a bit when I don't need it to be quite so obnoxiously bright.... I'd rather it be visible than blinding, but full power may come in handy cooking (and cleaning up) in the dark.
sarahspins is offline   Reply With Quote
Old 07-03-2014, 08:16 PM   #8
Thanks, my LED lights arrived but Ive been doing other things and will try to get around to installing them soon.
Hey sarahspins, I really like the paint design on your scamp.
Old 07-03-2014, 08:47 PM   #9
sarahspins's Avatar
Thanks, but I can't take any credit for it, I bought her that way, and I love the paint job
The prior owner posted a thread about it - Ramblin' Rose
Old 07-05-2014, 07:57 AM   #10
MCDenny's Avatar
Trailer: Lil Snoozy
Just came across a string of twenty very bright (no lumen spec) LED lights at Radio Shack for $30.00. The cool part is you can cut them apart and use them in three light increments. You have to solder wires on but otherwise you can have very tiny lights stuck on with two sided tape. You can have light anywhere. These would be especially good for inside cabinets.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 07-05-2014, 08:24 AM   #11
Trailer: 1983 13' Scamp
South Dakota
MCD those are great. I have a friend who uses them in his tiny home cargo van.
SimplyLesa is offline   Reply With Quote
Old 07-06-2014, 06:21 AM   #12
MCDenny's Avatar
Trailer: Lil Snoozy
Denny Wolfe
Correction, there are sixty LEDs that can be cut into twenty segments and wired individually. In fooling around in the dark with them last night one segment of three seemed about as bright as the flashlight function on my iPhone 5.
Denny Wolfe
Old 07-29-2014, 03:25 PM   #13
Trailer: Scamp 13 & TDI tugboat
Ohio
Burned-in yet?
Mike, I bought a similar bag of multi LED lights. But mine get very hot in operation after 10 minutes, so they stink (burning solder flux) and one of them got so hot the SMD dropping resistors began to melt off the board.
Have you had a chance to leave yours on, sealed up in the fixture for at least half an hour to see if there are any problems with continuous use?
Cheers,
Jim C
FJ40Jim is offline   Reply With Quote
Old 07-30-2014, 12:55 AM   #14
Night Sailor's Avatar
Connecticut
I've bee using the bayonet the mount led replacement lamps. I have not noticed any unusual heat or odor. I have two of these types, both warm and a brighter white in addition to a few flat panels. I have not tired the flat panels for an extended time yet. Perhaps at most an hour on one of them.
I am very impressed with LEDs. I bought a few tried them out and then bought more. I have a nice supply of spares plus I kept the old bulbs in case these ever started to fail.
The one thing I did learn, is that it is nice to have subdued lighting and ways to change the look of the interior.
light, lighting
Bigfoot Interior Lighting Mods Tim D. Modifications, Alterations and Updates 4 07-05-2011 06:43 PM
Interior Lighting John Jesse Electrical | Charging, Systems, Solar and Generators 18 05-15-2010 03:08 PM
Interior LED lighting Video kevin61 Modifications, Alterations and Updates 8 01-03-2009 01:09 PM
Another interior lighting system Doug Mager Care and Feeding of Molded Fiberglass Trailers 47 02-24-2008 01:36 PM
New Interior lighting led light strips jimtesla Modifications, Alterations and Updates 2 09-15-2006 08:42 AM
