sunrader - Page 4 - Fiberglass RV
Old 09-27-2015, 06:05 PM   #43
Rix
Rix's Avatar
Trailer: sunrader
And another
One more small piece then I can glass it in.
THAT guy
Rix is offline   Reply With Quote
Old 09-27-2015, 06:17 PM   #44
Looks like you are making some progress.
I was hoping to get over to see it on this trip to Chelan but I got all caught up in the fire clean up and only got a short trip up to Canada for any vacation.
There is a small Sunrader slide-in camper in a field near Chelan but I was so busy that I didn't even get a chance to follow up on that one. Fortunately it wasn't in the fire area, so maybe next time.....
I will be back in the northwest in December and hope to get over that way to see your project and the Retro trailers.
Old 09-28-2015, 05:44 AM   #45
Night Sailor's Avatar
Connecticut
Originally Posted by Rix View Post
Anyone have a suggestion for some insulation? Nothing REAL serious needed, but something to help a little with colder nights? The shape makes me think that the flat board sheets might be a little difficult.
Oh, and I got the support rail frame built, and had berg it sitting on the camper jacks. It started to straighten out a bit when I did. I'll be removing the tub soonish.
High density marine foam is a core material used in boats. It is light, string, and provides insulation. You would glue it down 1" thick core with fiberglass resin and then add a layer of fiberglass biaxial cloth on top of it. You would need to make sure the shell was in the shape you wanted it because once set up it would not move. It is also easy to glue onto this and interior bulkheads needed for walls which provide extra reinforcing for the shell.
Old 11-25-2015, 05:38 PM   #46
Rix
Rix's Avatar
Trailer: sunrader
All the wood is glued in. Next comes 'glassing the roof in, then i *think* i'll work on the tub. Trying to figure out which direction is the correct one for keeping it all "squared up" and the openings proper.
Not sure how to tackle the center bow it has, but I'm sure it'll come to me.
(or someone else'll say the right way or put me on the right path)
THAT guy
Old 04-27-2016, 07:55 PM   #47
Rix
Rix's Avatar
Trailer: sunrader
Life has taken me..... Elsewhere lately.
But I'm about to get geared back up and get back into this.
THAT guy
Old 04-28-2016, 02:34 AM   #48
Trailer: 1980 18' Sunrader Motorhome and 1971 Trails West CampMite Campster
Sorry, blocks of wood for cabinet/framing stuff.
I put in a fair amount of blocking in my Sunrader. I did not put glass over it. You mix up some epoxy resin and thicken it, wood flour will be the least expensive. Make the mixture the consistency of stiff peanut butter so it does not run down the wall. Then spread it on the blocking and press it against the wall. To do a temporary hold here and there along the edge as a tack down while the epoxy sets I used urethane hot glue gun that set up within a minutes time. Not sure if the craft hot glue sticks would work for the job.
There is something you need to know about using blocking on a fiberglass shell. You don't put it out in the middle of the wall sections where there is a lot of flexing, you don't want to induce cracking of the shell or imprinting of the blocking into the shell shape. Keep your blocking towards the edges where bends happen or close to the join lines of the shell halves. It might not seem logical not to put it out there in the flexing center area but that is how it should be done.
On the Sunrader's they used an approach to the insulation and interior wall paneling that might seem to be insubstantial and illogical. However it does work and it allowed that light weight shell to maintain some flexibility without inducing stress in it. It also substantially reduced labor cost because the walls floated over the join lines and other exterior details instead of each piece of blocking having to be a custom depth to account for the variations in the shape of the shell. The blocking they used was 5/8" thick. The foam was 1/2" thick which being applied with a thick construction adhesive make the insulation fit just inside of the blocking.
The shell is two angular halves but that interior wall gently curved to float over all the variations leaving a smooth inner surface. This method allowed them to fabricate the interior paneling,the blocking and the insulation on the walls on the factory floor using staplers and adhesive in caulking guns. So what they did was glue the blocking and the ridged foam insulation to the back side of the 1/8" wall panels, put some staples along the edges and where the 1/8" paneling met another section of it and then those prefabricated units were secured in place by being screwed to blocking that went into the plywood floor at the lower edge and then it was was clamped in position by the pressure of the window frames and the door frame. So all in all a very cost effective and efficient method of putting in the interior walls. Once you understand what the designers were doing and why you will realize it was actually a very practical system for handling the build up. When you start gluing blocking to the wall you will quickly learn about all those thickness variations in the shell and how it will take you a lot more time to level out to support the wall panels.
The roofs in the Sunraders were created as SIPS, structurally insulated panels. Before the upper shell was taken out of the mold a layer of urethane foam was added to what is the underside of the roof. Then adhesive and fiberglass skrim went over that and it was finished off by a sheet of plywood that had already been covered a vinyl wall paper. When you gut a Sunrader and take apart that SIP and toss it into the trash bit you have basically trashed the structural integrity of the roof. Now you are stuck trying to create a roof beam system to do the support work that was being done by that lightweight and strong SIP. Its strength having been created by those well bonded layers of materials. Unfortunately you can't get back to what was removed.
The strongest, smallest in size and lightest stiffener beams to strengthen the roof will be to create a hat section with foam covered with fiberglass. You could use wood as well, the strength is not from the inner filler, it is from the fiberglass over that substructure. But it must be done correctly with the layers applied in sequence as to width. This pdf file from West Systems will show you how to create them. http://www.westsystem.com/ss/assets/...aintenance.pdf
As to how you will get that curve of the roof back. You need to take a long board or piece of thick plywood and cut the bow shape into it. Then you will support it from underneath up against the roof pressing upwards until the roof is reshaped. You will likely need at least one pair of these spaced appropriate apart for building support beams. Then build your hat beams close to them and let those fully cure. Take out the pair of curved supports and move them then build the next set of hat beams in that position. Repeat until done.
Old 06-24-2016, 10:49 AM   #49
Rix
Rix's Avatar
Trailer: sunrader
There was never any rigid foam insulation in this thing. Later ones maybe. If it's not 'glass, it's wood 'glassed into/onto outer panel, or encapsulated into the outer panel (the roof). The interior of the fiberglass outer shell shows all the plywood grain on the resin surface in the places there is wood. Raw fiberglass everywhere else.
But besides that....
My weeklong camping trip is over, and some friends brought a camper. I want to get this thing done now.
I finally got the window gaskets ordered.
I got the tub off. time to start on the new one. It will be all pressure treated wood, steel, and a ton of paint.
AFTER I do the repairs/mods on the shell.
I'm still not sure what to do with this pop out thing in the side though.
THAT guy
Old 06-29-2016, 07:53 PM   #50
Rix
Rix's Avatar
Trailer: sunrader
Trim loc stuff showed. It doesn't ship with the lock strip. lol
So gotta wait a little longer.
THAT guy
Old 09-12-2016, 12:31 PM   #51
Rix
Rix's Avatar
Trailer: sunrader
I'm going to wait a bit on the windows
I got a good start on the new tub though
Sturdier, heavier of course much more rot resistant too
I
THAT guy
Old 09-15-2016, 11:33 AM   #52
Rix
Rix's Avatar
Trailer: sunrader
Tub is built, support deck is on, and now the thing it sitting on it's tub.
I've since removed the metal frames and jacks, and it's directly on the deck.
THAT guy
Old 09-18-2016, 09:30 AM   #53
Rix
Rix's Avatar
Trailer: sunrader
What're the words of wisdom for sealing the seams of window gaskets? (where the two ends will meet)
THAT guy
Old 09-18-2016, 09:39 AM   #54
Doug P.'s Avatar
Trailer: Escape 5.0TA
Southern Alberta
sunrader
A small dab of butyl chalk is what I used on machinery windows. Force the rubber hard into the radius corners and cut the rubber at least 1/8" overlap, apply the butyl then force together and install glass. Glass cleaner makes a good lock strip lube when installing and never line up the lock strip seam with the rubber seam they should always be staggered.
Cheers
Doug
Doug P. is offline   Reply With Quote
Old 09-18-2016, 01:19 PM   #55
Rix
Rix's Avatar
Trailer: sunrader
Sounds good. Thank you sir.
THAT guy
Old 09-19-2016, 07:19 PM   #56
Ellpea in CA's Avatar
So is the little tub your Sunrader is sitting on just a temporary base? Or do you plan to tow it like this (and if so, how)?
Very interesting redo you're doing!
Ellpea in CA
1988 13.5' Lil Bigfoot
2002 Volvo V70 (turbocharged)
5 cylinders, 5 speed auto transmission
Ellpea in CA is offline   Reply With Quote
1986 toyota sunrader rv rare 17' gas 4x4 turbo efi 5 spd ac 22r-tec ollcnv Misc: Buy | Sell | Trade 31 04-23-2016 05:02 PM
MI: Toyota Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 37 01-15-2016 09:06 AM
*~*~RARE For Sale: Toyota / Sunrader 4X4 22RE SR-5 Opt. checkursix Misc: Buy | Sell | Trade 4 04-16-2015 07:03 PM
MI: Sunrader Mini Motorhome Thomas G. Referrals: Molded Fiberglass Trailers 9 04-03-2013 08:41 PM
MI: Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 4 11-10-2012 03:01 PM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
