sunrader - Fiberglass RV
Old 08-03-2015, 09:30 AM   #1
Rix
Rix's Avatar
Trailer: sunrader
sunrader
I'm Rick. In tacoma wa.
SO I bought this slide in for cheap
(I have to imagine this sounds familiar)
Sunrader made by gardner pacific sometime in 1975
Truck isn't mine.
The interior is....humble.
I started blowing it apart.
Wifey helping.
So far, I've found a lot of wood rot, a little bit of inner fiberglass rot where the wood and fiberglass are laminated together.
And a bunch of questionable previous work.
I got it off the truck and on the long bed trailer where it'll live most of it's life. THAT was interesting.
The windows and stuff are good. the roof vents are good, but I may replace the small one that's very flimsy.
The equipped cooler thingie is likely going away. I have an edgestar fridge I can put in.
The original stove/oven/heater may make the cut. Not sure yet.
the bottom bucket/floor dealy needs a bunch of new and better wood.
It looks like this one was designed to be supported by the rails of the upper portion, not the bottom bucket, but I really have no way of saying for sure.
I'm not real certain of how the window gaskets should go back in (with or without sealant) but They're easy enough to pull back out.
Getting the main shell sound is job one. So that's where I'm concentrating first.
Oh and the fabric kickout on the right side is a mystery. I'm thinking it's mainly there to allow the board for the bead to be used as an auxiliary, but I'm totally guessing about that.
THAT guy
Rix is offline   Reply With Quote
Old 08-03-2015, 09:45 AM   #2
Congratulations on your Sunrader Camper.
What you have is one of the very few "Full Size" Sunrader Campers that was built by Gardner-Pacific. While most Sunrader Campers (those for Toyota and other small pick-ups) were built in the Vallejo, CA facility between 1971 & 1978, I believe yours was built in Santa Ana, CA.
That version is easily identified by the wrap-over side windows. Survivors are scarce as it shared no major parts with the two versions built for smaller pick-ups.
Gardner Pacific also owned Amerigo slide in campers and trailers and they experimented a lot with what was called the "Snap & Nap" tilt out bed idea from that company on a few Sunraders as well. This may have been something they tried with the camper you have.
If you Google Sunrader and Germany, there is one in Germany that was extensively rebuilt over there a few years back with a plethora of pictures. The German owner has it on a restored Dodge pick-up and they show the combo at what's called "Old Timer" shows in Europe. if I come across the link I will post it for you.
Good Luck
Old 08-03-2015, 11:01 AM   #3
emers382's Avatar
Trailer: 2016 Escape 5.0TA
Manitoba
Rick thanks for posting this with pics and Bob thanks for the info.
I saw one of these six days ago on an old pickup pulling out of Miami. That is Miami MB not FL!
Adrian
emers382 is offline   Reply With Quote
Old 08-03-2015, 11:34 AM   #4
Timber Wolf's Avatar
North Florida
That is too cool. Please keep us posted on your progress.
Old 08-03-2015, 11:43 AM   #5
As mentioned earlier, there were two different versions made. Of the smaller versions, (they had two different floor footprints) originally for slide-in use on Toyota pick-ups and a few mid sized pick-ups, there were over 10,000 built between 1971 and 1978, of the larger version, such as Rick has above, only a few hundred were made. The giveaway (other than size) is in the side window that wraps over the top in the larger one.
There is almost a cult market for the smaller of the small ones to mount on pre-2004(?) Toyota and Nissan 4x4's (they were much smaller than later ones)
The top half of the smaller one became the first Sunrader motorhome in 1978:
Here's a link to more pics of mine from a few years back;
http://s363.photobucket.com/user/adv...?sort=4&page=1
Old 08-03-2015, 12:42 PM   #6
Rix
Rix's Avatar
Trailer: sunrader
I can't find ANY info on this. Not so much as a single picture on google.
Fortunately (or unfortunately) I'm not doing an original resto on this.
So tracking down original stuff isn't on the menu. Looks like a gooood thing too.....
This might get drug through the woods a little.... so I'm going to have to up-armor it a little.
The tub (is there a correct term for where you stand?) might get a little weight added. By "might" I mean "will". Either 2x3 or 2x4 or something (steel?) for the box frame and heavier marine grade plywood. the steel section I added i think I'ma make into a ladder frame on either side, and bossible across the front. I'm good with steel. Steel I know. Wood... less so. Fiberglass I'm so-so.
Looking at it last night, I also think the whole body is starting to bow in the center. May have to make a plate to suck it back in and reinforce it.
I'll definitely be updating.
THAT guy
Old 08-03-2015, 02:39 PM   #7
I have contacted the shop in Germany where the restoration was done and have this pic for starters. I will be downloading more later today and will post a link:
Old 08-03-2015, 03:56 PM   #8
Rix
Rix's Avatar
Trailer: sunrader
That's the monkey right there. A few small details are different. The interior layout and the rear part of the bottom. Mine wraps around the outside of the truck bed. But that's definitely it.
EDIT
The "after" layout looks different. the before is identical from what I can see.
THAT guy
Old 08-03-2015, 04:46 PM   #9
There are some more pics coming. I know that he switched out the wrap over windows. I saw that it also has the "Snap & Nap bed tilt out.
The smaller version, that became the motorhome, has a California King size bed that pulls out from the overhead, over the dinette. Does your have that feature?
Old 08-03-2015, 05:01 PM   #10
Rix
Rix's Avatar
Trailer: sunrader
I'm not sure. the overhead has a (flimsy feeling) carpeted section, then there's a piece of wood with the matching carpet on it, and a lip on one end, that isn't connected. It is free to move about, but the only way to do anything with it, given it's size, would be if the tilt out is open.
THAT guy
Old 08-03-2015, 10:34 PM   #11
Rix
Rix's Avatar
Trailer: sunrader
I was given a messed up flagstaff cobra a while back. Figured I'd use it for a donor for as much as I can.
So I changed gears a little and assessed what I had to work with.
Another cooler fridge
External stove
Mounted and separate tables
Heater unit
And 2 big bed cushions, lots of couch cushions, all with nice clean covers.
Bed sliders
Power unit
Extra siding, etc etc.
Going to try to get some more done on the sunrader tomorrow.
Old 08-04-2015, 10:38 PM   #12
Rix
Rix's Avatar
Trailer: sunrader
I'm currently cutting out rotted wood and fiberglass.
Getting the wood outta the roof's center section.
Here's a pic of the cross section of the window seals.
Old 08-05-2015, 07:21 AM   #13
Also sign on to toyota-campers@yahoogroups.com there is a lot of Sunrader info there and one of the owners (Turtle Mike) can tell you where to get new window sealing material. I am Sunrader Bob on that site.
Old 08-05-2015, 09:48 AM   #14
Rix
Rix's Avatar
Trailer: sunrader
Joined there. That's a bit tougher to navigate.
THAT guy
1986 toyota sunrader rv rare 17' gas 4x4 turbo efi 5 spd ac 22r-tec ollcnv Misc: Buy | Sell | Trade 31 04-23-2016 05:02 PM
MI: Toyota Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 37 01-15-2016 10:06 AM
*~*~RARE For Sale: Toyota / Sunrader 4X4 22RE SR-5 Opt. checkursix Misc: Buy | Sell | Trade 4 04-16-2015 07:03 PM
MI: Sunrader Mini Motorhome Thomas G. Referrals: Molded Fiberglass Trailers 9 04-03-2013 08:41 PM
MI: Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 4 11-10-2012 04:01 PM
