Surfside Front Kitchen - Page 2 - Fiberglass RV
Old 03-19-2006, 10:27 PM   #15
Trailer: 1991 16 ft Casita Freedom Deluxe
Lee,
Pictures, please?????? I'd LOVE to see it!
- Miriam
OK, they aren't the best. These were taken before I picked it up. There is some signs of water stains on the roof - the seams need to be resealed, of course.
Click the picture for a full-sized view, and don't pick on me for not having an egg.
Outside views:
Looking in through the door. The bathroom is in the corner beside the sink.
Looking towards the street-side rear. You can just see the edge of the refrigerator on the right side of the picture. The table folds down into a full bed. Yes, I need to repaint the ceiling.
Looking forward from the dinette. The refrigerator and bathroom are on the left and there is a closet and some storage space on the right before the opening for the door, which is right beside the stove.
Lee Hillsgrove is offline   Reply With Quote
Old 03-19-2006, 10:44 PM   #16
Miriam's Avatar
Trailer: Surfside TM14 1974
Lee,
Adorable! Interesting layout. A bathroom in a 12.5 footer - someone was using their thinking cap!
- Miriam
Miriam is offline   Reply With Quote
Old 03-19-2006, 10:59 PM   #17
Trailer: Fiber Stream
Talking
My next idea is to figure out how to mold fiberglass so I can create a standing shower unit (right now we use an inflatible pool or tub and hand-held shower unit. Hmmm...maybe a drop-down shaving stand for hubby...??? The mind wanders.......
This sounds similar to what the Rialta and LeSharo Class B Motorhome does. It is an ingeneous "origami" bathroom that folds up into a very small closet. The shower pan is permenently mounted in the center of the coach's floor. A piece of bound carpet hides it when the bathroom is "closed." To activate the full bathroom, you pick up the carpet out of the shower pan & grab the handles on the closet wall and pull the whole closet out into the center of the room, over the shower pan previously hidden in the floor. You then open the door, step inside, and flip down the panel over the toilet, and the sink, faucet, and hand held shower head appears! slip the shower head into it's wall bracket, and you're ready to go.
LeSharo Bathroom Picture
Old 03-20-2006, 12:04 PM   #18
Brian B-P's Avatar
While I contend that the Rialta is a Class C (uses the VW truck cab with a RV-specifc body) and the LeSharo is a Class A (entire body is built as an RV coach, no cab from the truck origin), so neither one is a Class B, that's just terminology details. See Winnebago Product Classification for details. In the Winnebago lineup, I believe that the LeSharo was replaced by the Rialta, and the Rialta has just been replaced by the View, all serving in their day as the company's smallest motorhome. The Sprinter-based View has a full bathroom with separate shower.
This idea of expanding a closet or toilet-only room into a full shower, using a shower pan recessed in the floor, is also used in some brands of Class B motorhomes (I've seen it, sorry can't remember the brand). Since a Class B is an RV conversion within a van body, space is really tight (especially in width), and these designs are an interesting source of design ideas.
I like this shower idea, but is does assume some level of familiarity of the RV occupants (at least part of the shower enclosure is usually just a curtain), and there's always the problem of just where it fits in the floor plan. The recessed shower pan goes between the frame rails in a Class B, as it could in a travel trailer; however, interference with tanks or whatever else might be under there needs to be considered. I have considered this in our Boler B1700, to expand the shower area to a more usable size; unfortunately, the resulting shower stall would be right in front of the trailer door, cutting off access to the kitchen and gaucho areas, and it would likely overlap the greywater tank (which is right against the bottom of the floor panel). The position might still be a workable compromise, and has the advantage of being right under the forward roof vent, for humidity removal.
Old 03-20-2006, 12:39 PM   #19
Lizbeth's Avatar
Lee, that's very simular to my 1972 Cardinal lowliner. After I get the Boler finished I'm going to start working on it again.
Old 03-20-2006, 01:23 PM   #20
Miriam's Avatar
I've seen the Winnebago's and thought it was a pretty ingenious idea. With the Surfside, the layout is different (closet directly opposite the door / entrance). The size of a Surfside closet is a tad larger than a Boler. It includes the access panels to the fridge, water tanks, electrical (from outside) - it's where all the cords and hoses curl up when the trailer's in tow mode. The closet is molded FG (front and lhs) with the lhs covered in Ensolite. The back is the outside shell of the trailer - also covered in Ensolite). The rhs panel (wood) has the access. There are 2 lights on the lhs and a vent over top. Also a clothes bar.
I'm envisioning maybe a floor pan in the closet to contain the water, and a drop down D-frame with shower curtain attached. A hook on the rhs for the shower head would complete the picture. A drain may not be necessary as the shower unit can suck the water back up to the sink in minutes (it's just outside the door), and from sink to portable grey water unit). I currently use that method with the bathtub. If I do decide to put a drain in, I'd drain it into a separate, portable grey water container.
The drop-down shaving compartment could be mounted to the inside door. I've seen them on - of all things - antique furniture wardrobes. Basically they work like those Ikea drop-down tables, except they have a hole in the centre so you can drop in your dishpan / sink. A few more strategically-placed holes could hold a cup with your razor, foamy, etc. The pan can be filled with water and then lifted out for disposal.
The toughest thing about the Surfside is having to curb the urge to have the closet do EVERYTHING. Because the fridge is on that side, and the water tank is a bit left of centre, these units are notorious for sacking out a bit on the driver's side. Of course, you want a balanced load.....
Anyways...I'm just in the idea stage right now. When (if) the weather warms up and I can start working on things, I may have a change of heart - especially if the task proves a bit daunting.
- Miriam
Old 03-20-2006, 01:31 PM   #21
Miriam's Avatar
Thanks so much for the link / picture. I was going by memory! I wish it showed how it pulls out.
- Miriam
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Front Kitchen Surfside Scott S. Modifications, Alterations and Updates 1 09-16-2009 01:13 PM
Triple E Surfside TM-14 left front running light cover Cam A Classified Archives 5 05-03-2006 06:27 AM
Front Kitchen Surfside Scott S. Classified Archives 0 12-31-1969 07:00 PM
