Tables for traveling... - Fiberglass RV
Old 05-02-2003, 09:00 AM   #1
I'm getting ready for my next long trip, and one of my primary concerns is lightening my load. (I have even taken the roof rack inserts off my truck cap and thereby saved 14 pounds!) I have an old, beloved LLBean camp table (not a piece of plastic in it!) from the 70's that weighs 28 pounds and is simply too heavy. My criteria are simple and entirely reasonable (?): a replacement table must weigh no more than three pounds and cost not more $5. (I'll use the table outside, under the awning, to hold my Coleman stove and other suchlike gear.)
Well, I had to fudge a bit, but I may have found the answer. At my local buy-out shop I found a supply of el-cheepo folding tables that weigh 6 pounds and cost $14.99. It's 2x4'. The frame is aluminum and looks repairable if it comes to that. The top is a kind of thin pressboard covered with wood grain paper. Elegant it ain't! So far I have put three coats of spar urethane on the top to protect it from premature decomposition and it seems to be taking it well. I'll do the same to the bottom, having already put one coat there to prevent warpage as the top gets its treatment.
So I have saved about 22 pounds in this one exchange. And the search goes on...
Old 05-02-2003, 10:34 AM   #2
table
:wave Hi Robert, well, this may or may not help. we, on the left coast, have been buying a collapsible, plastic top (19.5” x 30”) with an adjustable height from 21.5" to 28.5". guess (wag) it weighs about 5lbs. another wag is about $20.00 at costco. in our fd, it will fit between the captains chair and the bath wall and against the entry wall by the refrig. most of us have two. we throw the second one in the back of the tundra, along with a bunch of other stuff.:r
Old 05-02-2003, 11:00 AM   #3
Tables
Here's three suggestions:
Expensive but cool:
One of the fold-up aluminum jobs. We have one we take both camping and to the drive it. Works fairly similar to the modern folding camping chairs. Think we paid about $50-$60 at Costco a couple years ago.
Cheap but not so cool:
Folding TV trays. These things are a dime-a-dozen at thrift stores. They weigh nothing and cost even less. One is probably big enough to fit a portable stove on it.
Huge, free and adds nothing to your load:
Just use the wooden picnic table that's usually on-site. :)
mkw
Old 05-02-2003, 11:40 AM   #4
This is a topic that strikes a chord for me. In my quest for a 13' camper, I specifically wanted to rig it for a permanent bed. I planned to put a dinette up front. Then, other threads on this site got me thinking, and I decided to get a front bath instead. So, I now have a 13 deluxe with bath. I'd still like a semi-permanent bed, which obviously rules out interior seating. I've designed it so we can normally leave the bed set up and only set up the table when weather doesn't allow eating outside.
So, we plan to eat outside most of the time. The campground picnic tables are a stand-by, but many of them are simply too grody to eat from. I'd like to find a good, servicable, lightweight table that can seat four for dinner. We don't have a Costco around, and I won't allow Wally-World access to my business for reasons of principle. What are the rest of you doing for outside tables?
Old 05-02-2003, 11:56 AM   #5
consider this..........
Chas turned me on to the "porta leggs' tripod from campingworld......a fold up tripod that will accept the std table posts inside the trailer. I got a short 14" tube for side table height, and use the std tube for eating/coooking. By far, this is the most compact and lightweight solution to ancillary tables. Only drawback is the inside table is now outside, but a GREAT solution. Both the tripod and extra tube fit nicely in the back of the tiny dinette overhead cabinets on my 16. Note that I added a second hub centered on the table for this purpose. <img src=http://www.fiberglassrv.com/board/uploads/3eb2b1316c80411697.jpg/>
Old 05-02-2003, 12:00 PM   #6
.........and it's not a fire hazard!!!!!;)
Old 05-02-2003, 01:44 PM   #7
table tricks
I like my poly top folding table from Kragen Auto. It's about 5x2 and only $30. Bulletproof.
For small duty, the aluminum folding legs by Coleman for Coleman work good with an artist's 18x24 basswood drawing board as a top. Very light.
Old 05-02-2003, 02:54 PM   #8
>>tripod
Still works well for us, too, Phil! Why take two tables when one will do?
Old 05-03-2003, 12:23 AM   #9
how about this one. first weights 7.5 , second 15 so that's too heavy<img src=http://www.fiberglassrv.com/board/uploads/3eb360102482072718.jpg/>
from
http://www.sportsmansguide.com/cb/cb.asp?p=WX2&i=72718
Old 05-03-2003, 12:41 AM   #10
Jana
Good show.:thumb
Old 05-03-2003, 12:49 AM   #11
This folds up and stores in a bag like the camp chairs so many of us use now. I picked mine up at the local Wally mart for $20. Weighs in at 5 pounds. Holds up to 60 pounds.
<img src=http://www.fiberglassrv.com/board/uploads/3eb3664fb6007table.jpg/>
http://www.walmart.com/catalog/product.gsp...%3A4128%3A92574
Old 05-03-2003, 06:29 AM   #12
tables
Benita - I saw the one at one Wal-Mart, then haven't seen any more since then. I thought it looked interesting, but was concerned about being able to sit around it. When I went back to check on it, they were all gone.
e.s. - I had wondered about those Coleman folding bases.
Jana - Yours really piques my interest. I'm going to check that out.
Old 05-03-2003, 06:56 AM   #13
Tables
When I got my L.L.Bean table (33 years ago!) I decided that the fibreboard tabletop was its weak point, the rest of it being built like the Brooklyn Bridge. So I put about three coats of polyurethane (maybe it was spar varnish back then?) on it and it is still in very good shape despite having been rained on more times than I can count. I am now putting the final coats of spar urethane on the bottom of my new lightweight table. It already has four coats on the top. I'll probably put that many on the bottom as well. I've used about a third of a quart so far (thus making it heavier, ironically!), but I feel it is worth it to make this table last under the uses I intend to put it. About 5 pounds for a 24x48" table ain't bad-- not to mention the $14.99 part. I'll be able to put the Coleman and assorted implements on it. Even eat at the other end. Maybe sit outside and use the laptop, too. I'll try to post a pic when it's finished. Maybe load it up with "stuff" for effect!
Thanks all for all the great suggestions!:)
Old 05-03-2003, 08:26 AM   #14
Suz and Table Dimensions: Since I travel solo, the table is the right dimension for most of my uses - computer work, eating, TV night stand, etc. If I were trying to sit more than 2 folks around it, I'd consider a second table.
Jana's Rolltop Aluminum: I think the Walmart table is built on the same principle as Jana's aluminum table if I understand what they are saying about rolltop surface. My top is made of slats connected by a flexible web that roll up into a cylinder that can be stored in the duffle sack that came with it. If I'd seen the aluminum table first, I might have gone in that direction. One of my considerations was stores out of the way easily.
Robert's Spar Coating: Ditto on Robert's sentiments about the top being the weakpoint of my table. I plan to urethane it and if possible find something that is flame resistant to also coat it with. I think if the top were more sturdy the frame would hold more than 60 pounds.
Phil/Charles' Porta Leg: The next time I'm in Camping World I'm going to look for a collapsible tripod leg base. This would probably be a better solution for me when I use the travel trailer. The table in the Fiber Stream is sturdy, as solid as a butcher's block. Based on how I plan to use the trailer, it will be somewhat in the way a lot. Outside would be the better place for it and my humongous heat generating broiler/toaster oven. The tripod base would also allow me to reposition the table top in the trailer when I need a solid counter surface closer to the galley for instance. I can use the camp table inside when the butcher block is outside or hidden by the bed. More interior space . . . aaahhhh;)
Mike's Expensive Solution: I've seen tables like mine made out of aluminum in the Sports Authority camping section. I can't remember how much they cost. But I do remember it was more than I wanted to pay. $60- sheesh. I also considered TV trays. They don't store away as conveniently.
Old 05-03-2003, 08:54 AM   #15
table for two please?
I too was struck with the table dilemma, my first response was one of the folding rolltops as pictured above. Works great.
My second response was ; How do I set up a barbecue and a coleman outside to cut the heat in the trailer?
Answer : $99.00
<img src=http://www.fiberglassrv.com/board/uploads/3eb3d73f3aedbcamp kit.jpg/>
Yeah, its a little pricey, but it only weighs about 15 lbs tops, and makes life a whole lot easier. This one's even better than mine, 'cause it's 20 bucks cheaper, and has a sink. Mine just had a table top. It's made by the same company as mine, and these things are pretty tough
Old 05-03-2003, 09:36 AM   #16
Joe:
Sam's Club has a similar table, it's remarkable how many neat items have appeared for family camping in the last few years.
Old 05-03-2003, 12:31 PM   #17
OK, here 'tis.
My new table, with some scale-providing props. That mirror finish is the result of four coats of spar urethane. Only three on the bottom. Now to see how it holds up.
<img src=http://www.fiberglassrv.com/board/uploads/3eb40abe4b4fcnewtable.jpg/>
Old 05-03-2003, 07:59 PM   #18
Light Weight Table
Just curious, How much weight did all of that Polyurethane varnish add to the table?
Dave::cool
Old 05-04-2003, 07:22 AM   #19
Dave,
About a pound. I used just a little less than half a can of Minwax Helmsman® Spar Urethane. The table weighs about 6 pounds now.
Old 05-04-2003, 08:27 AM   #20
table
I've got a table with rounded legs like that. Really have to be careful where it's set up otherwise it wobbles. :o
Corian Countertops/Tables & Fabric Suzanne P. Problem Solving | Owners Helping Owners 2 07-25-2007 07:51 PM
Can anyone show me pics of their tables Ryan Kennelly Problem Solving | Owners Helping Owners 5 03-26-2006 10:41 AM
Folding Tables 4 Casita TT Legacy Posts Problem Solving | Owners Helping Owners 18 11-08-2002 12:19 PM
