Takin' it too the Maxx - Fiberglass RV
Old 04-20-2007, 05:40 AM   #1
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Has any one out there installed a Maxx Fan brand 12v. powered vent fan??? I have ordered this brand as it requires no additional rain hood or cover but my R.V. Supplier has no experience with a thin roof trailer...and neither do I I am really Maxx'ed out Alf S. North shore of Lake Erie
Old 04-20-2007, 12:17 PM   #2
Brian B-P's Avatar
I put a MaxxFan in my Boler B1700RGH. The minimum roof thickness requirement means that to mount nicely there needs to be a spacer added, either on top of the roof, or under it; I used a two-layer plywood spacer under it.
Since the mounting holes did not line up with those for the original vent (there were not even the same number), I drilled new holes. The basic 14" square opening was fine for the new vent.
One nice feature of the MaxxFan is that you install a mounting collar, then drop the fan unit into it. Since it is difficult to reach in to the centre of the wide-body B1700, while standing on a ladder due to the roof height, I did most of the preparation (cleaning off old sealant) and installation (new holes, placing collar and fastening it) while standing on a stool in the trailer with my body sticking up through the vent hole - right through the collar while installing.
I can provide more details and photo illustration if that is desired; it will take me some time to prepare (select, crop, resize) the images.
Old 04-20-2007, 12:25 PM   #3
That would be grand Brian Thanks for being willing to help out
Old 04-20-2007, 02:16 PM   #4
brendadave's Avatar
Trailer: 1976 Trillium 13 ft
Hi Brian, I am also interested in installing the MaxxFan, the details on installation would be great! My other question (for Alf too), did you buy it locally or did you have to order it from the US somewhere?
Thanks.
Old 04-20-2007, 04:09 PM   #5
Brian B-P's Avatar
I bought my MaxxFan from a local RV dealer, at an outrageous price, to avoid similarly outrageous shipping and customs brokerage charges. the various local dealers' prices were comparable to each other. It was the same price as a Fantastic Fan of similar features, but the MaxxFan has the integral rain hood (the reason I chose it).
It was over $300 (Canadian), a couple of years ago.
I'll assemble the photos this weekend...
Old 04-20-2007, 05:47 PM   #6
Chester Taje's Avatar
I put a Fantastic fan in my Boler but put the spacer on the inside and made it look like a nice frame.Worked for me.
Old 04-20-2007, 06:26 PM   #7
Alf S.'s Avatar
Hi: I purchased locally and managed to get the price down from $315.00 to $289.47+ taxes for the smoked top 3spd. non remote fan... Same reasons as Brian No S/H fees + fees @ Brokerage Alf S. North shore of Lake Erie
Old 04-20-2007, 06:43 PM   #8
Yves Pelchat's Avatar
Trailer: Bigfoot 17 ft (15B17G)
Quebec
I added a Maxxfan to the Bigfoot. It was a perfect fit. I like it.
You'll be glad you did.
Yves.
Yves Pelchat is offline   Reply With Quote
Old 04-20-2007, 06:53 PM   #9
Cheryl Libby's Avatar
Trailer: 1975 Boler 13 ft / Ford Explorer
We added a Maxx fan to our 13' Boler and added out spacer on the inside. It makes a nice accent piece also.
Cheryl
Cheryl Libby is offline   Reply With Quote
Old 04-22-2007, 05:41 PM   #10
Brian B-P's Avatar
I have posted my MaxxFan addition in a separate topic:
MaxxFan Installation, Replacing stock power vent in 1979 Boler B1700RGH
Old 04-22-2007, 08:45 PM   #11
Con
Trailer: 1977 Boler 1300/2003 17' Bigfoot
Very neat fix Brian!
Con is offline   Reply With Quote
Old 04-24-2007, 07:19 PM   #12
Alf S.'s Avatar
[b]MaxxFan Installation, Replacing stock power vent in 1979 Boler B1700RGH
Hi: Thanks Brian...this info and pictures will be invaluable...tks. again Alf S. North shore of Lake Erie
Old 05-07-2007, 07:24 PM   #13
Alf S.'s Avatar
Hi: Well the MaxxFan is in...wired...and working. Tested it today as the trailer was actually hot!!! Boy does it work slick and fast... By the time I set the control to high speed I could feel cool air on my elbow coming in from the window... We have 5' 9 &1/2" clearance under the large crank open/close knob and I was lucky to have been able to cover the two 3/4" plywood spacer rings with the Ensolite and the trim ring for the fan and also able to loosen the Ensolite to run the wires in the roof from the fan to the light fixture in the upper cupboard over the sink!!! A quick spray with Contact adhesive (for the foam cushions) and the Ensolite is re stuck to the roof!!! I still need to down load my pic's and start a new album showing the installation... Many thanks to Brian BP for his posting... it made mine sooo vewwy simple...
best technique for air flow with Maxx Air Fan with 13 footer lloyd cicetti General Chat 4 06-18-2010 05:04 PM
What if I ran my Maxx Air Fan for 7 hrs off my Rv battery? lloyd cicetti General Chat 7 06-17-2010 01:08 AM
