Tandem Axle Scamp Setup - Fiberglass RV
Old 01-26-2007, 09:33 PM   #1
For those that were at the 2005 Oregon Gathering, you probably met Merle Lilly. His trailer was a definite standout with tandem axles. He has graciously volunteered the information to this forum for those who would like to consider the modification. If you don't think you can do it...know that Merle was 70 years old when he tackled the job!
If you're interested in a printable PDF of this information, it's available in the Document Center HERE
At the time we ordered our new 1993 Scamp 5th Wheel, I asked the factory to put on tandem axles/ wheels and tires. Their reply was “you don’t need them,” and besides “we can’t do it.” After towing the trailer many miles and with seven tire failures, I decided in 1997 to take on the job myself. The earlier Scamp 5th Wheel models like mine, had 13 inch rims. Later, after many complaints, the company raised the trailer two inches and started using 14 inch rims with larger tires.
Here’s an outline of the procedure I followed to modify my Scamp to install a second axle:
Step 1: Prior to any cutting, I figured the critical measurements to determine where the final longer wheel well would be. Measure twice, cut once! Inside the trailer, I determined what parts would be moved and/or cut to accept the new larger wheel well. I moved wires, plumbing, the water pump and the converter before doing any cutting.
Step 2: Then I jacked up and blocked the trailer. Remember, I was removing the axle, the trailer needed to be blocked securely, evenly and level. I also removed the tires from the wheels. It was necessary for making certain the axles were mounted absolutely parallel to one another (Fig. 1).
Step 3: I placed two jack stands under the existing axle. Before cutting the axle loose, I marked the frame just forward and behind the axle. These two marks were used to measure for the front axle’s new position. In determining where the new axles were to be placed, I knew the current axle was balanced to the trailer. I needed to maintain proper tongue weight. If the axles were placed to far back, the tongue would have had a heavier load and vice versa. Then the axle was cut loose with a high-speed grinder.
Step 4: I cut out and removed the fiberglass skirt around the wheel well to enlarge and accommodate the tandem axle setup. I could always come back and cut the area larger, but could not come back and cut it smaller! I used the same measurements for both sides of the trailer. I put 25" between the axles (tube to tube). This measurement depends upon the size of wheels/tires used. A different size wheel/tire could also change the size of the wheel well. I wanted the tires to be close together, but obviously not so close they rubbed against one another.
Step 5: Using a thin chisel I cut through the fasteners holding the wheel well. Once the existing wheel well was removed, I cut through it in the middle, top to bottom...and now had two end pieces. I used a thin sheet of metal to form a pattern to extend the length of the well. This pattern was about 36" long. I waxed the metal and placed it on a piece of wax paper to lay up the fiberglass. When it was dry, I peeled the fiberglass extension away from the metal and pop riveted it to the two end pieces. I then laid this piece on wax paper and filled in the middle with fiberglass.
Step 6: Next, I used nails to anchor the new wheel well to the wood floor and epoxy to anchor it to the body. Then, laid on my back with everything falling in my face to lay more fiberglass and to tie everything together! Remember, this area had to be made waterproof to the interior of the trailer.
Step 7: Mounting the axles. Like the original, a Dexter torsion axle rated at 3,500 pounds was used. The second axle did not need brakes. I needed two pieces of rectangle steel tubing 2" x 3", one piece about 4' long and the other about 3' long. (The trailer was being raised and I used these pieces as spacers between the frame and the axles.) The original axle was moved forward 9" of the original position from the front mark on the frame (Step 3). I cut two spacer sticks 25" long. With the forward axle temporarily in place at its new position, and using the spacer sticks (tube to tube), I moved the second axle in place behind the front axle. To align the axles, I dropped a plum line from the hitch to establish a stationary reference point. I measured to the center of the hub to the reference point and did this for each axle and on both sides of the trailer. This distance had to be the same on each side of the trailer for both axles! I adjusted each axle’s position, as necessary, to make certain the measurements matched.
Step 8: This is also where it becomes evident why I was working with bare rims. Using a perfect straightedge, I placed it against both rims and made certain the straightedge touched in four places (Fig. 1). Because I was working with a perfectly level trailer, I was also able to use the straightedge to make certain the rims were level at the bottom (Fig. 2).
Step 9: The axles were now ready for the welder to secure them to the frame. Welding took about an hour. When welding...be careful, fiberglass burns! The moment of truth, I had the tires mounted on the rims, put them on the trailer and lowered the trailer down on the tires.
Step 10: Lastly I riveted new molding around the bottom edge of the wheel well skirt (exact type as original).
My Scamp 5th Wheel handled well with one axle, but it is steadier now. Also I’ve upgraded by adding shocks which made it even better. The first reason for all of this work was to lighten the load on the tires by half. My second reason, I now have 14" wheels with larger tires which improved the ride further. Since this change to tandem axles, I haven’t had another tire failure. In fact the trailer currently has the original tires from the day the tandem axles were mounted and I’ve towed it thousands of miles.
The fine print: No guarantee expressed or implied come with these procedures. A different brand/model of trailer or even another Scamp 5th Wheel may require additional or different modification for a successful setup. I didn’t work quickly, but I did work methodically.
Merle Lilly, Sarasota Florida
THANKS FOR SHARING MERLE
Old 01-27-2007, 07:39 PM   #2
Brian B-P's Avatar
Thanks, Merle (and Donna)
If Merle is still actively participating in the forum, I would be interested to hear how the axle position was chosen. With a 25" inter-axle distance, and the existing axle moved only 9" forward to become the front axle, the effective centre has moved back 3"... or I just misunderstood the description.
The Trillium 5500 was designed for tandem axles, but most (maybe all) were built with single axles. If anyone here has done the tandem conversion on their 5500 (I know there are tandem 5500s out there), that would be interesting to hear about, too.
Old 01-27-2007, 08:59 PM   #3
Sorry, Brian (and everyone else) Merle doesn't have a computer and has never been on the internet. His wife typed the procedures and it took several phone calls back and forth to get this far. I'll be talking to him in a couple of weeks...he's trying to get ready for Highlands Hammock...and I can ask him any questions people might have. I'd be interested in seeing a picture of a single axle Scamp 5th wheel taken directly from the side. We could use Photoshop to see where the centerline is between the tandem axles...bet it's right deadcenter of the single axle hub...or darn close. In Merle's procedures where he talks about "balance," he just wanted everyone to think about it and know you couldn't just mount another axle fore or aft of the single axle...the single axle had to be moved.
Old 01-27-2007, 09:29 PM   #4
Brian B-P's Avatar
Thanks, Donna. I appreciate the effort that sharing this information has taken, and the continued follow-up.
I realize that Merle was emphasizing the importance of balance, which is why I thought the slight shift apparent in his detailed dimensions was interesting... and why I realize I may have just misunderstood what he meant by...
Originally posted by Merle's Step 7
...The original axle was moved forward 9" of the original position from the front mark on the frame...
Perhaps the reference points for the mark on the original and new positions are not the same, and the front axle is really 12.5" forward of the original mounting, to keep the effective position the same.
I agree the the direct profile image comparison would be interesting.
In the nearly-profile view on Scamp's 19' page, the axle appears to be centred on, or very slightly ahead of, the water heater and window centreline; of course it's hard to tell because the wheel is inset from the outside wall, making it look too far forward in this perpective. In Merle's photo, the midpoint of the axles appears to me to be slightly behind those same heater and window references... see why I'm thinking the axle is moved back 3"?
Okay, who has that perfect profile shot?
The balance issue is especially interesting in a tandem conversion. In a previous (pre-hack) discussion one member was considering a tandem conversion on his Trillium 5500 in order to increase axle capacity, and indeed the change could be made to allow the axles to carry more of the trailer's weight, and any change of axle position (even staying single) could be used to deliberately change the distribution between axles and hitch.
Old 01-28-2007, 07:03 AM   #5
Then too Brian, since Merle worked from the inside of the trailer first...it's possible the larger wheel well is as far to the rear as possible. There's the fresh water water tank to consider. It might be in the way of moving anything further rearward. I was inside Merle's trailer and I can't remember what's just inside the door to the left. A closet I THINK.
I too tried to line stuff up using the pic from Scamp Trailers...it's cocked just enough that it wouldn't work. If we can't get someone to post a direct side shot, I'll get one at NOG. We're are going to have 1-3 Scamp 5th wheels there.
Old 01-28-2007, 01:41 PM   #6
james kent's Avatar
Trailer: Boler 1984
Just draw a line on the single axle trailer just to the back gege of the small window divider ,same as on the other. You'll find that it extends downward near the backof the rim of the single. Now you can see how far forward he has moved the front axle. About 9 inches or so adding in a bit of rim, the width of the tire and the space required for axle separation, so I think we're right on the $$$
Old 01-28-2007, 03:31 PM   #7
Yep, and Merle did say 9 inches in [b]Step 7.
Old 01-28-2007, 06:00 PM   #8
Brian B-P's Avatar
Umm... that's what I was saying (my quote from from Step 7). Merle would have moved the old axle 12.5" (half of the 25" axle spacing) forward to become the new front axle if aiming for exactly the same effective axle position. I'm not saying there's anything wrong, just wondering if I'm reading the description right and (if I have read it right) wondering about the reasons for the choice of position.
axle, scamp
20' 5th Wheel tandem axle fiberglass trailer blaine gilruth Classified Archives 4 09-25-2010 07:26 AM
1986 Bigfoot 5th Wheel - eBay - Tandem Axle pete luchka Classified Archives 3 09-06-2009 12:16 PM
Tandem or Single Axle? Dana T Towing, Hitching, Axles and Running Gear 19 03-27-2009 04:54 PM
Setup Questions Cam A Care and Feeding of Molded Fiberglass Trailers 16 04-26-2006 06:13 PM
Some pictures of our new 'setup' Legacy Posts General Chat 2 05-15-2003 10:23 AM
