Tankless water heater - Fiberglass RV
Old 11-09-2011, 07:10 PM   #1
Lowpaidnurse's Avatar
I purchased this 120V tankless water heater on Ebay. I've been in Montana for the past few weeks and will install it and a new faucet when I return to Texas. Has anyone had any experiences (good or bad) with this type water heater? Any info would be greatly appreciated.
Lowpaidnurse is offline   Reply With Quote
Old 11-09-2011, 07:46 PM   #2
Perry J's Avatar
About 15 years ago I had a slide in camper that I installed a propane tankless water heater in.
It worked well. I never had any problem with it.
I am amazed someone doesn't make a REASONABLY priced tankless for RVs.
John
Old 11-09-2011, 08:11 PM   #3
This tankless water heater is 120V. No propane. I want to know if it is better to put the water heater on it's own circuit rather than plugging it into another outlet. I want to put it on its own circuit. I don't want to overload the outlets I have.
Old 11-09-2011, 08:18 PM   #4
Trailer: 16 foot Scamp
LPN,
I can't tell from the picture what the power draw is, but I'm betting it is high. It should say on the unit somewhere. I'd bet my bottom dollar it will need a dedicated circuit. Most 120V circuits are 15 amp max.
David
DavidSo is offline   Reply With Quote
Old 11-09-2011, 08:22 PM   #5
These are the specs I got from Ebay:
Chronomite SR-30L Electric Point of Use Tankless Water Heaters White
Chronomite SR-30L 120v Instant-Flow SR Tankless Water Heater - Chronomite Tankless Electric Water Heaters Since 1966, Chronomite Laboratories Inc. has been the innovative leader in providing solutions for commercial and industrial tankless plumbing applications.
Applications:Public Lavatory, Non-Public Lavatory, Kitchen / Bar Sink.Accessory package:Standard pressure OMNI flow control, low pressure OMNI flow control, 3 adaptors and 1 compression fitting.Chronomite SR-30L 120v Instant-Flow SR Tankless Water Heater Features:; Unlimited Hot Water; 98% Energy Efficient; Compact Size; Easy to Install; Low Installation Cost; Meets ADA Requirements; Made in the USA; Product Listings UL, HUD, IAMPO; Virtually Eliminates Alkali Calcification; No pressure & temperature relief valve needed (unless required by local code); Low Flow ModelChronomite SR-30L 120v Instant-Flow SR Tankless Water Heater Specifications:; Temp Rise at 0.5 GPM 49;F ; Watts 3600; Volts 120; KW 3.6; Breaker 30; 6-1/4"x9-5/8"x2-3/4"; 25 PSI Minimum operating pressure; 150 PSI Maximum operating pressure; 140;F Maximum operating temapture; Minimum operating flow rate 0.4 GPM* Old model number S-30L-110* The manufacturers start up instructions should be observed.
Other Details
Product Type: Electric tankless
Temp Rise (F) at 0.5 GPM::48
Temp Rise (F) at .75 GPM::-
Temp Rise (F) at 1.0 GPM::-
Temp Rise (F) at 1.5 GPM::-
Temp Rise (F) at 2.0 GPM::-
Temp Rise (F) at 2.5 GPM::-
Temp Rise (F) at 3.0 GPM::-
Temp Rise (F) at 4.0 GPM::-
Minimum Flow Rate::n/a
Maximum Flow Rate::n/a
Type of Control::Instant Flow
Connection Location::Side
Inlet Size::n/a
Outlet Size::n/a
Height::6 1/4"
Width::9 5/8"
Depth::2 3/4"
Weight::n/a
Power Supply::120 VAC
Power Consumption::3.6 KW
Amp Requirement::30
Minimum Operating Pressure::n/a
Maximum Operating Pressure::150 psi
Temperature Range::n/a
Old 11-09-2011, 08:29 PM   #6
LPN,
I was really suspicious when you said 120V. Most of these are 220V because the power draw is large. Yours is 30 amps! You CANNOT plug that into an existing outlet. You must have a dedicated circuit with 10 gauge wire, The problem is, even on a 30 amp hookup, you cannot run anything else when that heater is on. You cannot plug into any house current anywhere unless that 30amp service is available. You will blow the breaker immediately.
David
Old 11-09-2011, 08:31 PM   #7
cpaharley2008's Avatar
You will need a new individual 30 amp dedicated circuit for 3600 watts, that is equivalent to 2X15 amp circuits, so you will either have to convert your rig to a 50 amp hook up (these cost more at campgrounds) or have a 30 amp for the water heater only and use an extension cord, 15 amp circuit for your trailer needs.
Old 11-09-2011, 08:38 PM   #8
there is a propane model that does not draw a lot of electric here
RV Parts Center - Save on RV Parts, RV Supplies, RV Accessories
Old 11-09-2011, 08:54 PM   #9
I've been thinking about something like this:
Camp Chef HWD5 - Hot Water Heater / Portable Shower#
The cost of most of the tankless options is borderline offensive. This one gets good ratings, is simple, and priced sensibly. It's not a "built in" option though without some work. It raises the temp about 40 degrees, so you need to start with water that isn't too cold.
David
Old 11-10-2011, 08:22 AM   #10
Thanks for the input, all. I guess I won't be installing that tankless water heater after all. I wanted hot water to wash dishes and so forth. I do not want to convert my trailer to 50 amps. I guess I can try sending it back.
Old 11-10-2011, 08:40 AM   #11
If you do get your money back, there are alternative electric water heaters, The Egg Camper is all electric and has a small 4 gal electric water heater similar to this Shop Ariston 2.5-Gallon Electric Point-of-Use Water Heater at Lowes.com
and it would only need a 15 amp circuit, so your 30 amp trailer would be adequate.
Old 11-11-2011, 08:44 PM   #12
Trailer: 1985 16 ft Scamp
Ohio
I use an electric 50 cup coffee urn that I bought at a garage sale. It does take a little while to heat up but it beats heating water on the stove in a bucket.
BigMike is offline   Reply With Quote
Old 11-11-2011, 11:40 PM   #13
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
I bet you make that appliance urn its keep!
Old 11-12-2011, 10:16 AM   #14
Ha, Ha
I guess that meets the definition of a tankless water heater.
Old 11-12-2011, 04:14 PM   #15
Trailer: 1991 17 ft Horizon
Too bad the propane ones are so expensive as I might be interested in one some day.
Old 11-12-2011, 04:37 PM   #16
honda03842's Avatar
Name: Norm and Ginny
Tankless Water heaters
Small ones that are not too expensive
Tankless Water Heaters from EZ Tankless
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-12-2011, 05:53 PM   #17
David
We have a similar EccoTemp. It is designed for outdoor use ONLY , and that's how we use it. It's wonderful on our camping site on private property in NC.
Sherry
Old 11-13-2011, 06:08 AM   #18
Trailer: 2007 Eggcamper
The electric tankless water heaters sound like a good thing, BUT, how do you drain them? Do you just run antifreeze into it?
Art
artspe is offline   Reply With Quote
Old 11-13-2011, 08:41 AM   #19
Art
You have to protect electric from freezing, they are not made to be installed in an RV. The propane model you run antifreeze thru is, or if you are camping and using it, it has a "WUD" winterizing device that comes on routinely and circulates water to keep it from freezing.
Old 11-13-2011, 05:55 PM   #20
The seller sent me a reply. He says he has the Eemax tankless water heater for the same price. The only difference is that this one needs a 20 Amp. Will this work or do I need to get my monies refunded and go with one of the ones the others recommended?
Tankless Instant Shower Water Heater Lisa H. General Chat 10 06-14-2008 05:32 PM
Water Heater Q Eric & Tam Problem Solving | Owners Helping Owners 3 06-19-2007 07:00 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Water heater pjanits Problem Solving | Owners Helping Owners 4 04-11-2006 01:23 PM
Tankless Instant Shower Water Heater Lisa H. Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
