These are the specs I got from Ebay:
Chronomite SR-30L Electric Point of Use Tankless Water Heaters White
Chronomite SR-30L 120v Instant-Flow SR Tankless Water Heater - Chronomite Tankless Electric Water Heaters Since 1966, Chronomite Laboratories Inc. has been the innovative leader in providing solutions for commercial and industrial tankless plumbing applications.
Applications:Public Lavatory, Non-Public Lavatory, Kitchen / Bar Sink.Accessory package:Standard pressure OMNI flow control, low pressure OMNI flow control, 3 adaptors and 1 compression fitting.Chronomite SR-30L 120v Instant-Flow SR Tankless Water Heater Features:; Unlimited Hot Water; 98% Energy Efficient; Compact Size; Easy to Install; Low Installation Cost; Meets ADA Requirements; Made in the USA; Product Listings UL, HUD, IAMPO; Virtually Eliminates Alkali Calcification; No pressure & temperature relief valve needed (unless required by local code); Low Flow ModelChronomite SR-30L 120v Instant-Flow SR Tankless Water Heater Specifications:; Temp Rise at 0.5 GPM 49;F ; Watts 3600; Volts 120; KW 3.6; Breaker 30; 6-1/4"x9-5/8"x2-3/4"; 25 PSI Minimum operating pressure; 150 PSI Maximum operating pressure; 140;F Maximum operating temapture; Minimum operating flow rate 0.4 GPM* Old model number S-30L-110* The manufacturers start up instructions should be observed.
Other Details
Product Type: Electric tankless
Temp Rise (F) at 0.5 GPM::48
Temp Rise (F) at .75 GPM::-
Temp Rise (F) at 1.0 GPM::-
Temp Rise (F) at 1.5 GPM::-
Temp Rise (F) at 2.0 GPM::-
Temp Rise (F) at 2.5 GPM::-
Temp Rise (F) at 3.0 GPM::-
Temp Rise (F) at 4.0 GPM::-
Minimum Flow Rate::n/a
Maximum Flow Rate::n/a
Type of Control::Instant Flow
Connection Location::Side
Inlet Size::n/a
Outlet Size::n/a
Height::6 1/4"
Width::9 5/8"
Depth::2 3/4"
Weight::n/a
Power Supply::120 VAC
Power Consumption::3.6 KW
Amp Requirement::30
Minimum Operating Pressure::n/a
Maximum Operating Pressure::150 psi
Temperature Range::n/a
