Tarp Awning - Fiberglass-safe Fluid for Enhancing Suction Cups - Fiberglass RV
Old 09-09-2016, 06:14 AM   #1
junglejim83's Avatar
Trailer: Trillium 4500
New Jersey
Ok, so the title is long but I think it makes sense.
In a nut shell, I am using heavy duty suction cups as to anchor a tarp awning to the top of my Compact II. The whole camper is due for a scrubbing but I cleaned/polished the areas where the suction cups will adhere with barkeeper's. It is now smooth, as opposed to chalky, and the suction cups held great after cleaning it. It was wet when I tested them and I know some recommend using silicone or petroleum jelly to maintain a good seal when using these suction cups on glass panels, metal or tile.
I will just use water to maximize the suction if it seems that any other fluid will stain or degrade the gel coat and fiber glass. But it would be good to have something that wont dry up to make sure adhesion is maintained.
What do you all suggest?
I will post picture of the set up after the weekend trip (assuming amazon doesn't delay delivery of my extending poles again).
junglejim83 is offline   Reply With Quote
Old 09-09-2016, 09:10 AM   #2
Try rubbing just a little dish soap or shampoo on the suction cups and let them sit for a little while before putting a load on them.
Lee
Captleemo is offline   Reply With Quote
Old 09-09-2016, 09:51 AM   #3
I used a medium duty suction cup on the fiberglass (gelcoat) for a light duty clothesline and it quickly left a mark that was quite hard to remove. So I gave up on the idea.
Then I used the same suction cup on the Plexiglas window to mount a small camera. It left a mark that was hard to remove (again). So I gave up on that idea also.
It seems that the rubber on my suction cup was soft and while that helped it work well, it leaves marks. YMMV and I hope you have better luck than I did.
Old 09-09-2016, 10:40 AM   #4
Ohio
I use hand sanitizer.
cmartin748 is offline   Reply With Quote
Old 09-09-2016, 12:39 PM   #5
Name: Nancy & Dan
So I'm going to jump right into this conversation. I've been wanting to put up a awning on our Casita, but my husband doesn't want to put any holes in the fiberglass, and I agree. I've been racking my brain trying to come up with an idea that will work without drilling. I kept coming back to heavy duty Velcro, never thought of suction cups! Will the suction cups really work? Are they heavy enough to hold a mid weight cotton in place?? Any help would be appreciated!
Nancy from MI is offline   Reply With Quote
Old 09-09-2016, 12:50 PM   #6
Ohio
Handy little items
https://www.amazon.com/Suction-Sucke...e+suction+cups
Old 09-09-2016, 02:06 PM   #7
tractors1's Avatar
Trailer: Escape 21 - Felicity
These folks have the awning rope and mounting rails. Mounts with VHB tape:
Sailrite - Fabric, Canvas, and Sewing Machines Since 1969
# 100380 is the mounting rail I use.
Charlie Y
Old 09-09-2016, 06:30 PM   #8
bsedwebt's Avatar
Trailer: Casita "Cozy-Casa"
Central Virginia
My rope and pole awning is held on with only VHB tape - NO HOLES is my motto - so far so good...
"Cozy-Casa" -- Visualize whirled peas
bsedwebt is offline   Reply With Quote
Old 09-09-2016, 06:35 PM   #9
Your "Cozy Casa" looks like the real thing!
Lee
Old 09-09-2016, 06:42 PM   #10
Originally Posted by cmartin748 View Post
Those are the ones that left the stubborn marks on my gelcoat.
Old 09-09-2016, 06:46 PM   #11
bsedwebt's Avatar
Central Virginia
I have cleaned hard to get off marks with a $2 can of carb cleaner from the auto parts store. Just a quick spritz and then quick rub with a paper towel.
Old 09-09-2016, 11:14 PM   #12
tractors1's Avatar
Hey, don't drill holes has been my biz motto and on my license plate frames and truck signs for over 10 years!!!
Charlie Y
Old 09-10-2016, 04:56 AM   #13
South Carolina
My awning attaches with suction cups from busdepot.com as does my awning. The main thing is locating a flat spot for attachment. This can be problematic with a trailer like my casita with all it's subtle curves. I clean the chosen spot with rubbing alcohol and spritz the rubber of the suction cup with a product that has the unfortunate name of "suck a lot" (available on Amazon). It's sold as an aid for attaching a gps and such to windshields. I suspect that it's simply a watered solution of glycerin which also works well and is available from any drug/grocery store. I've not noticed any lasting residue.
p@
patrick crawford is offline   Reply With Quote
Old 09-11-2016, 07:58 PM   #14
New Jersey
I used the dual suction cups from harbor freight and they held great using just water. There was a thunderstorm and pretty stong wind (20-30 mph gusts) and the held great.
Also, there was no marking.
Suction Cup Lifter - Dual Cup Suction Cup Lifter
I like the VHB tape and track, I might try that when I do window awnings.
awning
Enhancing small kitchen work surfaces WDavidG Modifications, Alterations and Updates 19 04-01-2016 03:48 PM
Product testing: Harbor Freight suction cups rabbit Modifications, Alterations and Updates 10 06-12-2013 08:02 AM
Suction Cups, FG Camper's Friend D Davis Modifications, Alterations and Updates 14 08-01-2012 06:47 PM
What kind of tarp would make a good awning? Vickie B. Problem Solving | Owners Helping Owners 30 03-24-2011 09:21 AM
Stronger than suction cups jamessue Care and Feeding of Molded Fiberglass Trailers 7 08-24-2009 08:35 AM
