01-08-2012, 07:50 PM
Trailer: 17.5 Bigfoot
Tell me about Inverters please.
I'm in the market for a new LED TV, 15.5" or 18.5" for my Bigfoot. As suggested in the other tread on TVs, going with a new style AC LED TV and an inverter may be close enough to the power draw of an AC/DC TV. I am trying to make my trailer as energy efficient as possible.
All interior lights are now LED.
Running lights will be converted to LEDs this summer.
No airconditioning.
Very seldom run trailer heater on propane.
Boondock probably 20% of the time.
Need to charge cell phone and iPad on occasion.
Hope to install a 135 watt solar panel system this summer.
So, what wattage do I need in an inverter to run a LED TV and a small DVD player?
What's a Sine Wave Inverter?
Should the inverter be hooked directly to the battery?
My single battery and TV will be 17" apart.
Can I just tap into a 12 Volt supply near the TV?
I'm new to this electrical stuff, so any suggestions will be greatly appreciated.
01-08-2012, 08:33 PM
Trailer: 1976 Surfside
Hi Don, to answer a couple of things on your list : Yes your inverter should be as close to your battery as possible , once you convert 12v to 110 v you can go the 15 or so feet to the tv outlet. You could run a single line from the inverter to a new outlet for the tv . A 1000 watt would be all you need and give lots to spare . Should go for the Pure sine wave it cost about a third more, it is just like shore power and will not hurt your electronics If you are going to get a 135w solar panel would be nice to upgrade your battery bank, you need a place to store all that free power .
Hope this helps Ken
01-08-2012, 08:36 PM
Read this, particularly part II
The 12volt Side of Life (Part 1)
part II continues after part I
01-08-2012, 08:40 PM
Trailer: 78 Trillium 13 ft / 2003 F150
Inverter??
Hello,
Why not stick with 12V DC? I found a nice little LCD TV made by
Sharp... it had a 12vdc external power supply so it plugs right into
the trailer battery supply and draws about 3 amps. Add a little
Coby DVD209BLK Ultra-Compact DVD Player from Amazon and you have
a nice little entertainment center. Or get a little portable combo
DVD player with its own screen. DVDs can also be played on your laptop
computer and you can run it with a 12V DC power supply for the puter.
However, you can use AC appliances but their power draw would be
much more with the inherent losses of the inverter and TV AC power supply.
A sine wave inverter supplys AC power from your 12V battery and has a
waveform that is just like what comes out of the wall at home. The other
kind of inverter is a modified square wave which might work but nmight
not depending on your video equipment. Samlex makes a nice little
150W Sine Wave inverter that would power a 22"LCD TV and
a small simple DVD player.
As far as hooking all the stuff up there are many good older
discussions here or you can educate yourself on line to figure out
the installation.
I use a small cheap $20 inverter in my Trillium just to run the coffee
grinder.
Good Luck, Larry H
01-08-2012, 09:36 PM
No airconditioning.
I have a tru-sine 400W inverter which we use to run all of our electronics in our Scamp. Usually this includes only a digital tuner/converter , a DVD player and a Sharp 13" LCD Television along with an occasional laptop. We have a 27 Battery and about 12ft of 8 or 10 guage wire(I forget which).
This set-up has worked well for 7+years so far.This inverter is far more than really needed, but has proven to be a great choice. It is fan cooled and installed in a vented cabinet,It has never even gotten warm to touch and we watch movies and television for several days without shore power while using 12V pumps, lights, fantastic fan, etc. along with it.
It has an alarm and a light to warn of low voltage before automatic shutdown.
01-08-2012, 10:12 PM
Trailer: 1996 16' Casita SD
Louisiana
As far as wattage use goes, every electric devise has how much watts or amps it draws on a tag somewhere. You have to add up all your devices' wattages to get an idea of how much power you need. With a 135 watt solar panel and a good battery, you should be alright.
I do agree with Larry about getting all the 12 volt devices you can. You lose power when it goes through an inverter -about 10 %.
BTW- watts = amps x volts
01-08-2012, 11:18 PM
Let's clearify a bit. You only need to add up power (watts) of devices you want to use at the same time. Usually you'll only be using one device at a time, if that's the case then you want to make sure you can use the device with most power consumption.
Heating devices of any kind are power hogs, so you need to watch out there.
If you're going to be operating on battery without hookups you can determine the number of amps drawn from the battery by looking at 120 Volt device and multiplying the number of amps listed by 10. All these things need to be considered.
01-08-2012, 11:48 PM
135 Watt Solar Panel should be plenty. I very seldom have hookups of any kind. All LED lights, run the furnace as I would at home. A single 80 amp hour battery, and a 65 Watt solar panel that I use about every 3rd day. Contrary to popular belief a larger solar panel array is not necessarily a good thing. I get about 4 amps of charging current, which is about all my battery can safely handle. If I let the battery run all the way down, that's only 40amp hours. Even then 8 hours at 4 amps will bring it most of the way back. 10 hours and it's fully charged.
Solar panels are sold by the $$/watt. Get what you need and not much more. It sounds like in your case a 50 Watt to 75 Watt would be plenty.
Some inverters put square waves, some triangle waves, and some sine waves. The cleanest are sine wave inverters. Some devices don't like anything but a sine wave. (that's comes out your wall out let). Anything else can cause troubles with electronic devices.
The next questions are hard to answer without more information, wire sizes, current draw, etc. for the 12 volt line going to the inverter. Therefore the safest thing to do is put the inverter as close to the battery as possible. Then run 120 volt wiring to where you need it.
01-09-2012, 05:27 AM
Another thing to realize is that the 12vdc power adapter for many items like Laptop computers is simply an INVERTER!
They are just just small task specific models made for the computer alone.
Most small LCD TVs now use a switching power supply either inside or outside to provide power from the wall and most of these will have no problem with even the cheapest inverter you can find.
My original point was that even though there is always some loss through the process of the inverter creating AC from DC the current draw of a newer LED backlight small TV is so small anyway that it is not a terrible way to go if you can not find an 12vdc model.
As with everything some research will help make a better choice.
01-09-2012, 08:41 AM
Louisiana
Well taken points Byron, however, I would fall somewhere between what you suggest and my first suggestion. Having camped for long periods of time in the winter, when sunlight is shorter or obscured by clouds, I have run pretty low on energy. I had two good batteries which got me through the time, but if I hadn't "overfigured"..... different story.
Better to have it and not need it than to not have it. Sunlight is free -so far.
01-09-2012, 10:55 AM
Trailer: Escape 17 ft Plan B
Just remember that when using an inverter the input draws 10X the amperage of the output. If your TV & DVD Player together draw 2-3 amps, the wiring (and fuses) feeding the inverter will be drawing 20 - 30 amps. Since most standard 12v outlets are limited to 10 amps or so, in most cases you will need to install larger wiring & fuses for the inverter. Try to keep the DC side of the inverter wiring as short as possible - if you need to extend the wiring, do it on the output (120V) side.
02-18-2012, 09:36 PM
Ok....I now have a 1000W Pure Sine Wave inverter. No cables were supplied. Where do I go from here in regards to cable size, type of wire, connectors, in line fuse size, etc. Really need to start with the basics. Thanks.
02-18-2012, 10:09 PM
There are lots of different approaches. I also installed a 1000 watt inverter, a Qantrex Prowatt SW 1000 watt pure sine wave inverter. I followed their instructions (a PDF is available on line) & ran #0 Boat Cable (a high quality cable available from Genuine Dealz. They will sell parts or, for a reasonable price, well made cables at what ever length , color & ends you need.
I also included a 200 amp disconnect switch & a 150 amp fuse.
The advantage of going to an oversized cable is less voltage drop under load. Since the inverter has a low battery cutoff, wiring too small will drop enough voltage that the inverter will shut down before the batteries are actually at the cutoff voltage.
02-19-2012, 08:52 AM
It is important to emphasize that the inverter should be installed as close as possible to the battery. When in the surge mode, this inverter can pull over 100 amps - you could literally weld steel with that much current.
Don't skimp on wire gauge. You can buy heavy cable and ends at a welding supply or if you are thrifty like me, buy new, but discarded cable from a metal recycling yard by the pound. Fuses and fuse holders are available on eBay. They are used for high output boom box set ups in cars. Harbor Freight has a high capacity switch relatively cheaply. Heavy Duty Battery Cutoff Switch
20% off coupons here: Digital Savings
02-19-2012, 01:26 PM
Trailer: 19' Scamp
Nebraska
Good info here.. Thanks everyone, I am going down a parallel path right now as well and a bit confused with all of the options.
02-20-2012, 10:17 AM
Thanks to you Jon and the others that are supplying all this useful info. As Earl said....to us newbys it can all be a little daunting. Would you mind posting a list and links to the Cables, fuse box, fuse, etc you purchased so I can compare that to the complete kit Ken suggested. Thanks
02-20-2012, 10:47 AM
The cables were made to order by Genuine Dealz. I used their Boat Battery Cable, Expensive, but very good quality. I specified length, color & the size lugs (if needed) for the ends. The fuse & holder manufactured by Tusnami came from a local car audio store, although I linked an Amazon source. It was a bit of a pain to assemble since the lugs that are used to connect both the cable & the fuse itself are not permanently attached to the plastic case & getting the cover back on after connecting everything took some doing. Still, the others I looked at were either just as difficult to use or were not very water resistant. Since I mounted mine on the rear bumper (where the Escape 17b 6 volt batteries are located) this was the one I used. The switch was from Performance Plus.
The inverter is located in the underseat compartment behind the converter, & I mounted the remote near the sink. . Rather than attempting to tie the inverter into the existing AC system, I added a receptacle near the sink that is a stand alone inverter outlet.
Hope this helps!
02-23-2012, 07:52 AM
Trailer: scamp 13
we are thinking about just using a laptop with a tv tuner progythingy,(technical jargon us fogies use) it can recharge from 12 volts, plays dvd's.
remember that things like you cell phone can recharge in your tow vehicle when you go on a beer,,,,uh,,,i mean grocery run.
02-23-2012, 09:00 AM
Name: Norm and Ginny
Trailer: Scamp 16
Inverters
We carry two inverters, a 1200 watt non-sine wave, $59 Black and Decker Inverter located within 2-3 feet of the battery and two 100 watt cigarette lighter inverters.
I switch our water heater and fridge to propane before turning on the 1200 watt inverter. As well I unplug the Converter. We typically use the 1200 watter to run our coffee pot in the morning and just about anything else. I should mention we do not have a micro wave though I expect it could run a 600 watt microwave for minutes like it does the coffee pot.
When I want to run only the TV, I use a 100 watt cigarette lighter inverter. We carry two of these, one in the car and one in the trailer. Again these are non-sine wave inverters. We have three 12 volt outlets in our trailers. A 100 watt inverter is more than enough power to run our TV and Satellite receiver.
As well we frequently use a 100 watt Inverter to charge our cell phones while driving and to charge our computers.
We bought our 100 watt inverters, also Black and Decker, for $20 at Walmarts.
I will say a full sine wave inverter is the best you can buy however we have never had a problem with the much less expensive non-sine wave inverters and have never had any TV interference from using a non-sine wave inverter.
Certainly if a 12 volt TV or a 12 volt electric blanket are near the same price as a 110VAC unit 12 volts is the way to go, though this is not usually the case.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Inverters and Power Draw
honda03842 |
27 |
11-16-2011 12:16 AM |
Power Inverters??
81scamp |
4 |
08-15-2011 02:54 PM |
inverters - too much battery drain?
Scott S. |
4 |
07-18-2008 09:52 AM |
Inverters
Legacy Posts |
8 |
05-23-2003 04:29 PM |
Inverters
Legacy Posts |
25 |
04-02-2003 12:15 AM |
