I would suggest that you check all of the 120 v wire connections in the outlets,
lights, and any junction boxes for loose wire, wire nuts and connecting screws. It's not very time consuming or difficult and could save you problems or a fire down the road. I suggest this because if on location has loosened up it is possible that others have and if they start arcing they cause a lot heat. Very easy to avoid by tightening connections. Work with the power disconnected.
Remember that neutral wire have the potential to kill. It's carrying the unused electricity back to the suppy. You touch it and a groud at the same time the power may flow through you instead.
