The Pine Cone's almost done! - Page 3 - Fiberglass RV
Old 11-17-2008, 09:46 PM   #29
Pamela S.'s Avatar
Trailer: 1984 Fiber Stream
That's what I was wondering: how much did all that paneling add to the weight of the camper? Absolutely gorgeous job, by the way. It looks so completely homey and welcoming!
Pamela S. is offline   Reply With Quote
Old 11-18-2008, 03:40 AM   #30
cjlindsay's Avatar
Trailer: Decrepit Canoe
Thank you very much! I hope to get the inside finished this winter. (After 2 years of working on it... Finally!)
Well, I took out the furnace, so that's 20 pounds gone. The fridge is gone, 20 -25 pounds. The water tank is gone, another 5 pounds. The center of the Closet is cut out, 5 pounds. The bunk bed is gone, at least 50 pounds gone. (That is CRAZY heavy wood!) The bunk bed bench is gone, another 20 pounds. and the propane tank is gone, 15 pounds. The paneling is UBER light. Each 8 foot long by 3,1/2" by 1/4" weigh maybe a couple ounces. They are REALLY light. I didn't have to add any structural pieces except for the bathroom door support and the screen door support. Altogether I took out about 140 (or more) pounds, and added back about 150 - 175 pounds. So, not too, too bad I think.
Thanx!
Later!
cjlindsay is offline   Reply With Quote
Old 10-30-2009, 01:22 AM   #31
cjlindsay's Avatar
Getting Closer!
The Back
The stained glass window from the outside at night. Made by Ann from Bill and Ann C
The stained glass window from the inside.
Just a bit more brass and a screen door and she's done!
Later for now!
Old 10-30-2009, 12:00 PM   #32
Gerda, H's Avatar
Trailer: 2010 17 ft Escape B ('Cafe Egg')
Wow, you have a beauty at hand here! VERY well done!!!! I agree with another poster out here, I would not know whether I would go outside enjoying outdoors or stay inside!
Gerda, H is offline   Reply With Quote
Old 10-30-2009, 03:43 PM   #33
Some beautiful workmanship. I hope we'll see it one day in person!
I'm sure you're going to enjoy your cabin on wheels.
Sherry
Old 10-30-2009, 05:09 PM   #34
Robert Johans's Avatar
Trailer: Nest Caravans
Did you say how you affixed the wood strips to the shell? If not, please do!
Old 10-31-2009, 12:32 AM   #35
cjlindsay's Avatar
Hi! Thanx for the thumbs-up everyone!
Well, I used "furring" strips between the original ceiling and the new panels. The furring strips I used were ~5/8" x ~1&1/4", (Otherwise known as 1 x 2's), cut as long as the trailer's roof bulge is wide. I cut a groove into the furring strips every 3&1/2" most of the way through to allow the strip to bend to match the side to side curve of the roof. I attached the furring strips to the roof by drilling through the roof and screwing the strips to the ceiling from above. (Filling the drill-holes with caulking before screwing in the screws.) Then I attached the ceiling panels to the furring strips. One strip at each end of the ceiling, one near the middle, and one at the vent. gives you a nice curve that matches the original without adding too much mass. each originally 8 foot by 3&1/2 inches ceiling panel weighs no more than a few ounces. (3/16" thick.) You could also attach the new ceiling pieces to the roof first and then add horizontal cross pieces, kinda like the the beams on the roof of an expensive yacht. Bolt some brass bolts through the roof, through the ceiling pieces and through the "beam" until it's flush with the surface of the beam. Back the bolts off a bit, countersink the hole in the beam, screw the bolts back down, then cap them off with some brass screw caps so that the caps are flush with the ceiling. That's how I would have done it if I had thought of it sooner. Would have been a bit easier.
Righto! Thanx & later!
Old 02-06-2013, 03:26 AM   #36
Night Sailor's Avatar
Connecticut
I was planning on buying a sardine stove with a window. I wonder how it worked out for heating your egg. Can you inform us?
Old 02-06-2013, 07:28 PM   #37
EddyEd's Avatar
Trailer: 72 Cloud
Wisconsin
Beautiful work. I love it.
EddyEd is offline   Reply With Quote
1972 Boler For Sale. (The Pine Cone) cjlindsay Classified Archives 4 07-24-2010 07:53 AM
Branson in Oct after Pine Knot Bill Hamilton Rallies, Get-togethers, Molded Meets (Archive) 5 06-28-2007 08:53 PM
added a Pine Knot album bill&sandra Camping, Campout Reports 2 12-02-2006 09:13 PM
Pine Mountain Observatory Oregon Byron Kinnaman Camping, Campout Reports 5 06-28-2006 09:19 PM
