The Story of a Poor Mans Airstream - Page 2 - Fiberglass RV
Old 01-25-2015, 07:35 PM   #21
james kent's Avatar
Trailer: Boler 1984
Originally Posted by EcoHeliGuy View Post
Please explain how you know the year.
Sent remotely
I believe that was the only year with the front mounted lamps.
Old 01-25-2015, 09:20 PM   #22
cpaharley2008's Avatar
looks like your hitch maybe set a little high, did you level it?
Jim
Never in doubt, often wrong
Old 01-25-2015, 10:16 PM   #23
EcoHeliGuy's Avatar
According to the paperwork your correct on the year. I have noticed the forward light pods arn't on many others.
As stated above, it looks high in the picture. It's actually 1.5-2" low, but I don't have a working fridge so not worried about it yet.
EcoHeliGuy is offline   Reply With Quote
Old 01-28-2015, 05:33 PM   #24
EcoHeliGuy's Avatar
Holy double hockey sticks batman, the fridge works on 120volt.
I was about the rip it out and get a new one based on previous owners statement that it never worked.
Now some much needed testing on the 12v and gas systems... But if one system works then this is going to be easy.
Sent remotely
Old 02-12-2015, 10:36 PM   #25
EcoHeliGuy's Avatar
Back at work for a month so trailer is hibernating.
Found a replacement axle, door hinges and new latch. As well replacement windows for the sides and door.
The Wife ordered some flooring, and has been looking into a new sink and facet.
Next step is 120v and 12v systems. And installing the axle.
For the 12v system I'll be installing porch and reverse light switches outside the door. And a switch panel inside the door on the closet wall. Every item will be on a switch so we can control amperage draw while boondocking. I'm also planing on installing a few PC fans in the compartments to circulate air when needed for moisture and heat.
For the 120v system I have a few outlets to place. One exterior, kitchen, gadget, and the two hidden for the fridge and charger. And a 30amp shore power inlet.
The axle will have brakes and a higher weight capacity. The frame was completely rebuilt by a previous owner and the original axle is still installed.
The flooring is a new floating engineered product from Home Depot. Looks like wood, and sticks together. Used in basements and bathrooms.
The Wife picked out a nice stainless drinking water type tap to save space. And we are searching for a sink to fit in the space we have while covering the hole of the previous sink. The counter also needs to be stiffened, which I plan to do with strips of plywood in a box shaped frame.
Propane and water will be tackled afterwards.
Sent remotely
Old 03-18-2015, 11:44 PM   #26
EcoHeliGuy's Avatar
Back working on the project 😃
Will do some updates shortly with photos.
Im looking for information from others, my boler is missing the kitchen supports between the counter and upper cabinet. Can I get some suggestions on what others have used that was visually appealing?
Thanks.
Sent remotely
Poor Mans Closet partslady9 Modifications, Alterations and Updates 5 08-02-2013 08:33 PM
One Mans Curse Gina D. Jokes, Stories & Tall Tales 0 04-24-2008 08:53 PM
Who is truly "Mans best friend?" Roy Bakehorn Jokes, Stories & Tall Tales 2 03-19-2008 02:44 PM
POOR POOR BUNNY !!! Dan Quinn Jokes, Stories & Tall Tales 1 05-02-2006 05:56 PM
