There's a hole in my Boler my Boler my Boler - Page 14 - Fiberglass RV
Old 12-01-2014, 04:00 AM   #183
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Hi Fred, just a thought to your windows. I use a small bungie cord around the roof vent "L" crank handle as the wind I get here while it's parked tends to raise the lid to full open. With a round handle you may have to drill a small hole in it to accept the hook end. Just a thought for you.
Old 12-01-2014, 10:57 AM   #184
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Thanks Dave, our vent just has a small thumb screw so a hole will be required.
Dave, I've often wondered if your in Borrego Springs Ca.
We went there this past march for lunch from O'side just to check it out.
I always think it's so amazing, the change from the beach to the desert in such a short distance.
FRED SMAILES is offline   Reply With Quote
Old 12-01-2014, 02:19 PM   #185
Trailer: 77 Scamp 13
Originally Posted by FRED SMAILES View Post
We may be delayed getting away this year, may not even be able to go,,,,, Marilyn had a small operation this fall and isn't healing just right,,
but we are planning for the best!!
And here is hoping all the best for you getting on the road to points sunny and south.
Old 03-26-2015, 09:03 AM   #186
Kootenay's of BC
This post is just to link another thread that has a mod I did to use the front rock guard as an awning.
Just tryin to keep stuff together.
Fred
Rock Guard Awning
Old 10-10-2017, 06:02 PM   #187
Kootenay's of BC
Well I just dragged the boler into the garage for another round of mods today. Getting it ready for another winter get away, may try the desert this year.
Plan to reinforce the frame under the door, no cracks but the door opening is different from sitting on it's wheels to sitting on stands so something is moving. Thinking about roll and tipping a paint job on it. May mount the upper kitchen cabinet with fiberglas and remove the bolts and make a cover for the propane/spare tire for starters.
I grabbed my angle grinder with a ZIP disk and cut up this old truck canopy for starters, material for the front cover.
A zip disk is a little dusty but accurate, fast cuts, and as the pics show I did a lot of cutting!
Couple a hours and it's starting to look like something.
Old 10-10-2017, 11:59 PM   #188
Exlnt Fred, I've mentioned here before of using camper shells window cutouts for building new stuff or mods. I've done a lot of changes on my FG dune buggy using cutouts. Sure makes it a lot easier starting with the flat work already done. Love how you used the shells rise angles . BTW, what desert(s) are you thinking of?
Old 10-11-2017, 11:10 AM   #189
Kootenay's of BC
hey Dave, well maybe I got the idea from you. I've been holding on to this canopy for a couple years now after I sold the truck it was on.
Pretty happy with the way the angles are working out.
We are looking at Elcentro at the moment but haven't booked anything yet.
Also that spot in Borrego with the antique trailers for rent.
So many want you to book in and out at the beginning of the month,, doesn't work for us so that will have a bearing on where we end up.
Fred
Old 10-11-2017, 11:26 AM   #190
amazing
fred has anyone ever told you you are amazing?
bob
Old 10-15-2017, 12:16 PM   #191
Kootenay's of BC
Thanks Bob, when I hear something like that I expect to be asked to do something for my special someone (of 45 years coming up on the 28th),,, lol
I put the boler a couple feet in the air so I could inspect the frame around the door closely and can't find any cracking or weak spot but the door shifts about 1/2 an inch in it's opening from resting on it's wheels to sitting on jack stands front and rear. I'm sure the frame is flexing under the door opening so I plan to reinforce that area with additional material.
On the front cover, once I'm happy with the fit of the pieces I'll simply double cut the overlapping panels as I would with wallpaper.
Once I finish looking at this stuff and start doing something I'll post more pics,, lol
Fred
Old 10-15-2017, 02:04 PM   #192
plug
fred I mean it your are an amazing person to not only do this but come up with those fantastic ideas.
I do not know where you guys come up with such talents! I know how I just can say it!
best of continued luck
bob
Old 11-16-2017, 09:03 PM   #193
Kootenay's of BC
Well a combination of busy with other stuff and a bit lazy didn't get much done till the last couple days.
Thought I'd throw up the process go through to make this thing stay together.
The first pic shows how I hold pieces together till it is glassed then tape it to stop any resin from flowing through. Flip it over and grind off the screw ends rough the surface and put a couple coats glas on the joints. After it dries remove the tape, screw heads and pieces of wood. As you can see other than paying attention to the fit of the joints the rest of the work can be pretty quick and sloppy as non of it will show in the end.
Fred
Old 11-24-2017, 09:41 PM   #194
Kootenay's of BC
This little fiberglass project is taking on a character all its own!!
In other news I have the boler almost ready for paint, I have ordered a gallon of 4359 Brightside white. Actually looking forward to this roll and tip project.
I have a renewed excitement to get the boler done as we have booked a couple of months away from the white stuff and leaving Jan1/18!!
Fred
Thought I'd edit the post to show how I set in the handles,,(eyes) of the project.
Plastic doesn't stick to fiberglass so I just made the holes the size of the mixing cup and then glassed the inside of the cover, removed the mixing bowl and done. This isn't he first time I used the mixing bowl on the trailer, It's also the way I got the clearance lights " frenched" into the body as the lights fit into the hole almost perfect,,,
Old 12-02-2017, 05:37 PM   #195
Kootenay's of BC
Changed out the stock jack because it was mounted on the side of the frame rail and that wouldn't work with cover I'm putting on the tongue. I had to mod this one because it was too low and wanted to be able to put a wheel under it.
In the pic you can also see the aluminum angle that is mounted to the bottom of the rail, this is for the cover to rest in.
Old 12-02-2017, 10:34 PM   #196
Really taking shape now Fred. Funny, I've used a number of things like your lid idea to form up voids and such in concrete. Never thought of doing it with FG work. Think I might stea....er, borrow your idea .
boler
BIG HOLE IN ROOF ( Boler ) trailerlust Problem Solving | Owners Helping Owners 17 04-07-2013 07:54 PM
BC Boler 13' Priest Referrals: Molded Fiberglass Trailers 1 03-14-2013 07:51 PM
Wanted: Boler Hinges - Looking for a pair of Boler Entry Door Hinges idiotsniff Parts: Buy | Sell | Trade 6 01-13-2012 10:02 AM
17ft Boler 1980 needs a true Boler lover Tina Problem Solving | Owners Helping Owners 5 12-27-2010 09:48 AM
MY 2008 BOLER BLOG, Camping trips using THE TANK: 74 Boler 1300...Pics Jayson Wall Camping, Campout Reports 1 01-18-2009 10:49 PM
