Thermostat question - Fiberglass RV
Old 01-16-2020, 03:42 PM   #1
Trailer: In the market
Thermostat question
I am very dissatisfied with the temperature control in my new Scamp 13. The furnace either roasts us out or allows the temp to drop to uncomfortable levels. From what I can see the thermostat that came with the trailer sucks, rarely registering temperature changes for half an hour. So, I intend to replace it. Can a regular household thermostat work, or are RV thermostats different? (Voltage etc.)
Yellowjacket is offline   Reply With Quote
Old 01-16-2020, 03:46 PM   #2
Scamp uses a digital one now. It requires batteries. Some reports are that it does a better job, but IDK. You can likely find it locally as well as from Scamp:
https://www.scamptrailers.com/parts-...at-detail.html
Old 01-16-2020, 04:29 PM   #3
I replaced the analogue thermostat in my Escape with a digital one because the analogue one made a loud click each time it turned the furnace on, and that woke me.
I like this Honeywell. I've not had to adjust the range, but I believe that can be done.
Old 01-16-2020, 06:43 PM   #4
In keeping with the current size/shape in order to look decent, you can use the same ones used in a home. In my experience though, RV furnaces are kind of like you describe despite the thermostats used especially in the colder weather, they just seem to go crazy sometimes. Some thermostats allow you to set a range, like 3 degree change before it kicks on/off.
Cathy P. is offline   Reply With Quote
Old 01-17-2020, 12:01 AM   #5
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Thermostats can be mounted in places that don't represent the temp very well, they can be in a situation where they might be overly influenced by the outside temp., through a cold wall.
They can also not be tuned very well.
Take the cover off the mechanical thermostat and make sure it is not getting stuck, that the small wires inside are not affecting it's operation as it moves based on temp. They are very sensitive to this.
There is an anticipator in every mechanical thermostat I've seen. This is an adjustment that can be made that cycles the heater as it is doing it's job, so that is doesn't overshoot. Some of the current that the thermostat is controlling is used to heat the bimetal coil that rotates to make or break the switch. Adjust this to where the system cycles more, and it will overshoot less. They usually say "longer" and have an arrow. Adjust it toward shorter and see if it helps.
Switching to a digital thermostat is fine too, but in a small environment like a small fiberglass tailer, the thermostat response may be so slow that the trailer is already overheated by the time the thermostat recognizes the temp, and shuts off.
For the trailer, I like a simple mechanical thermostat, with a thermometer on it. It should have an on-off switch, or a separate wall switch that controls it. Don't worry too much about the actual numbers on it's scale, just find a setting that is the best compromise. A programmable one is OK too, if you don't want to keep waking up to the noise during the night. Set it to come on when you wake up.
All thermostats have a differential between their "off" and "on" temp. This is usually about 3-5 degrees, and is not the reason for overheating. Older mechanical thermostats had a mercury switch that would last a lifetime and was very sensitive. These are no longer sold, but are very good. They must have an off switch too, or they will be cycling as you drive.
Bottom line: Small trailers are hard to manage the heat in. The thermostat must be in the right location. It must be a sensitive type. The anticipator function can help stabilize it and reduce overheating. Even if the heat seems to overshoot, let it settle in and stabilize, before judging it too harshly. On cold nights, it should begin to cycle regularly and run for about 10-30% of the time, on a repeating cycle.
Here is a link that might be useful:
https://inspectapedia.com/heat/Heat_..._Adustment.php
Raspy is online now   Reply With Quote
Old 01-04-2023, 12:13 PM   #6
Carey W.'s Avatar
Wisconsin
I had a similar problem with my new (2022) Scamp 13': temperature swings of 20°F or more when it was cold outside, so after reading reading up on it (including on this forum), I replaced the factory thermostat with a cheap Honeywell from a local building supply store. Here's a pic of them both:
It pretty much completely fixed the problem: the temperature swing is now only about 2°F with the windows closed and 4°F with a window cracked (to keep down the condensation).
Of course, the "Fan" switch and the "Cool" setting on the new thermostat don't actually do anything, but a two-wire thermostat would have cost twice as much, so I'm good.
Carey W. is offline   Reply With Quote
Old 09-23-2023, 08:56 PM   #7
Trailer: Scamp 13'
Which model did you end up going with? In the same boat now.
Chris Hendricks is offline   Reply With Quote
Old 09-24-2023, 05:14 AM   #8
Trailer: Casita ID
KY
When you set up your digital stat, (in the installer settings), choose electric heat, not gas, and you will get shorter cycle times. But there's still likely to be a 3-4 degree swing. But better than the mechanical stat.
Most of these heaters are over sized for a small space.
Cotton is offline   Reply With Quote
Old 09-24-2023, 07:42 AM   #9
Carey W.'s Avatar
Wisconsin
It's a Honeywell Home RTH111B. I'll try to include/attach a picture of the box (which in turn has a picture of the actual thermostat) to this post.
The Great A/C Thermostat Mod Patrick M. Modifications, Alterations and Updates 13 05-22-2019 09:02 AM
Old Suburban Furnace Thermostat Question? SteveV Problem Solving | Owners Helping Owners 7 09-09-2015 07:41 PM
Fantastic Fan Thermostat Switch Question Bruce H Care and Feeding of Molded Fiberglass Trailers 4 09-09-2010 10:01 AM
Fiber Stream AC Thermostat Question Pamela S. Problem Solving | Owners Helping Owners 3 04-24-2010 09:34 PM
Replacing Scamp 16' Thermostat Peter Kienast Modifications, Alterations and Updates 12 01-12-2007 01:09 AM
