Originally Posted by Bill Nolen
I'm thanking about removing the heavy LP bottle on the front of my 13' Scamp, removing the two-burner stove, and using this very cheap Chinese one-burner butane stove for all my cooking needs.
Bill
You are on the right track! I just ditched the 3 burner in my 1986
scamp 16 deluxe. The added counter space and
weight savings is WAY worth it.
Also I hated that burner. Having to
light it manually was ridiculous, and that was compounded by the fact that if you so much as twitched on the valve trying to slightly lower the flame it would go out. It seemed like only 5% of the total amount you could turn the valve resulted in a usable adjustment. It was either out, or max.
In my opinion this is the best butane stove for the job! It's
light, compact, and has all of the safety features of the larger steel units.
New Portable Single Burner Butane Gas Camping Stove Tabletop Stove Aluminium New | eBay
I love this thing. It has a regulator in it so it doesn't make a big yellow fireball if you move it while it's on.
I also have one of these;
Etekcity® Portable Card Type Camping Butane Stove Chef Gas Canisters Burner New | eBay
And while I do like it and would bring it in a backpack or on my dual sport bike... it does NOT have a regulator, and it DOES make a huge 2 foot fireball if you so much as look at it sideways.
I actually added a stainless steel braided line to my LP in the trailer and hooked it up with an adapter so I can run these little stoves on the
propane from the trailer OR the butane.
This is the adapter you need to do what I did.
New G Works Multi Gas Adapter Duralumin 55g Screw Type Butane to Cylinder | eBay
You could go with a single small 10lb
propane bottle as it would still be much cheaper than the butane. I carry 2 20lb tanks and about 6 butane bottles.
