thinking outside the box - Fiberglass RV
Old 09-01-2011, 09:44 AM   #1
Trailer: currently shopping
I've seen a lot of restored campers here, but has anyone thought of removing the ensolite or carpeting off the walls, adhering furring strips and do something like birch plywood? For the curve at the top, just install cabinets all the way around.
stink is offline   Reply With Quote
Old 09-01-2011, 11:22 AM   #2
IllAnnoy
Not quite the same but...
Old 09-01-2011, 11:37 AM   #3
Robin G's Avatar
Trailer: 2007 Casita
Of course owners have all sorts of ideas. I have seen one that is like a wood cabin inside. But most people look how to get the weight down when remodeling. Not adding more weight. Of course what ever fits your fancy.
It's about making the trailer fit your needs. What will bring you the most pleasure when using it. Good luck!
Old 09-01-2011, 03:39 PM   #4
Trailer: Fiber Stream
... has anyone thought of removing the ensolite or carpeting off the walls, adhering furring strips and do something like birch plywood? For the curve at the top, just install cabinets all the way around.
Factory built Fiber Stream trailers did this from 1981 to 1986. They had the advantage of having straight vertical walls. Scamp and Casita vertical walls still have a tapered bow out to the center "Belly Band" so you'd have to taper either the furring strips (for straight walls) or the paneling (to follow the center bow).
Originally Posted by Frederick L. Simson View Post
3. Third Generation: 1981 thru 1986
14838-A Boyle Avenue........ Fiber Stream Company
Fontana, California 92335.... (714) 823-1332
A U-shaped upper storage cabinet around 3 sides of the front compartment replaces the smaller cabinet that ran only across the front in the older trailers, increasing storage. All upper cabinets return to using hinged doors, here and in the kitchen. With the curve between the “wall” and the “roof” covered by cabinetry, thin foam insulation and thin paneling (that can easily be curved around the vertical corner wall curves) is applied to the remaining wall surface to match the partition wall paneling. Insulation and white material are applied to the ceiling.
The Fiber Stream Company went out of business in 1986.
Old 09-01-2011, 06:27 PM   #5
Pam Garlow's Avatar
Trailer: U-Haul 1985
Wasn't the trailer that had all wood interior called the 'pinecone' ?
Old 09-01-2011, 06:48 PM   #6
This one? The Pine Cone's almost done!
Old 09-03-2011, 11:09 AM   #7
Robin G's Avatar
That's the one! Thanks Donna!
Thinking of getting a Scamp RachelW General Chat 8 06-21-2008 12:51 PM
I'm not thinking right ronsmith100 General Chat 24 03-26-2008 10:02 PM
thinking about it ted saxton General Chat 12 04-10-2007 09:43 AM
What on earth was I thinking? Legacy Posts Modifications, Alterations and Updates 11 08-21-2003 08:29 AM
