This is our 1975 Boler we restored - Page 2 - Fiberglass RV
Old 03-11-2008, 12:55 PM   #15
Trailer: 13 ft Perris Pacer
Wow, that really looks great. Beautiful detail work
Angelo F. is offline   Reply With Quote
Old 03-11-2008, 01:45 PM   #16
Lizbeth's Avatar
Nice work!
How is it working out to have the sub floor? That is what I was thinking of doing to mine since the fiberglass floor is in rough shape and looks to need more even support.
Old 03-11-2008, 02:02 PM   #17
Trailer: 75 Boler
Nice work!
The sub floor works like a charm! I have no sag at all when walking around inside. You can also tell when your pulling it, the boler feels more solid when it hits those unavoidable pot holes. One of the smartest things I did in the restoration.
However, 1/2 plywood in not lite, it does add weight. I would have to say about 100 pounds.
Oh ya, one more thing. The sub floor also distibutes the weight of the shell more evenly alowing less stress (pressure points) on the steel trailer frame.
Mike Montville is offline   Reply With Quote
Old 03-11-2008, 02:20 PM   #18
Lizbeth's Avatar
Thanks Mike. The weight wouldn't be an issue as we already installed a new 2000lb axle. It's good to see the idea I had works well!
Old 03-11-2008, 03:53 PM   #19
David & Leslie's Avatar
Trailer: Scamp 16 ft Side Bath
Well done! Thanx for posting the pics of your terrific rehab. As others have said, the pull-out table is inspired!
Two questions:
1. D would like to know where you found the LED marker lights ... we have been looking.
2. I'm interested in the paint/finish used ... it appears to be "texturized" ?
We wish you safe journeys and many, many happy memories! Take care, L 'n D
“Imagination is everything. It is the preview of life's coming attractions.” A. Einstein
David & Leslie is offline   Reply With Quote
Old 03-11-2008, 06:16 PM   #20
Trailer: 75 Boler
Two questions:
1. These Marker lights came from Wal-mart, believe it or not. They were 1/4 the cost and the exact same mfg as the ones offered at all the car stores and farm stores in MN.
$5 bucks each. They are totally sealed.
2. http://www.nonslipcoating.com/anticorrosive.htm
I'll let you read up on it! It's not cheap, but worked great. I would use it again in a heart beat! Brick Red tectured
Old 03-23-2008, 10:40 PM   #21
Mike,
I really liked you renovation which has definately given me inspiration. I'm considering the same exterior paint product for my Boler. Can you tell me how many coats you ended up applying and how many gallons were needed? Did you use a primer?
Regards,
Iain
iainm is offline   Reply With Quote
Old 03-23-2008, 11:58 PM   #22
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
What did you do for insulatin on the walls besides carpet?
What carpet did you use? That is one hell of a carpet job on walls, roof eveywhere. Though pics are not close up.... I sure cant see any rugged looking seams. How'ld dya do dat?
Coach George Jessup is offline   Reply With Quote
Old 03-24-2008, 11:12 AM   #23
Trailer: 75 Boler
Mike,
Regards,
Iain
The paint is called Duraback http://www.nonslipcoating.com/anticorrosive.htm. Very heavy duty.
Cost is $139 a gallon (not cheap). Took 3 gallons (rolled on). You have about a 3 hour working time once seal is broken as it reacts to oxigen. Each coat adds a 1/8 inch rubberized coating that seals, works as an insulation, and is very very durable. You can pull steel chains across it and it doen't leave any marks! No priner was used, you just scuff up the surface. You can read more at the web site.
Mike
Old 03-24-2008, 11:29 AM   #24
Trailer: 75 Boler
Elementary my dear Watson!!
Carpet was the only covering applied to the inside, believe it or not, the paint is the true insulator. The paint is called Duraback http://www.nonslipcoating.com/anticorrosive.htm. Very heavy duty.
Cost is $139 a gallon (not cheap). Took 3 gallons (rolled on). You have about a 3 hour working time once seal is broken as it reacts to oxygen. Each coat adds a 1/8 inch rubberized coating that seals, works as an insulation, and is very very durable. You can pull steel chains across it and it doesn't leave any marks! No primer was used, you just scuff up the surface. You can read more at the web site.
Back to the carpet, we used a trunk (Stretchable) carpet, no backing so it stretches. It is used in high-end automotive restorations alowing you to make sure you see no seams, and you are right, there are no seams. It was applied with sprayed on counter top glue (It ain't ever coming off).
Mike
Old 03-24-2008, 01:15 PM   #25
Thanks Mike. I'm definately leaning towads this simply because it looks great and I have some imperfections on the fibreglass from the previous owners sloppy repair . This stuff should cover up the repair quite nicely without hours of sanding and filling. I'm assuming you applied 2 coats? Any idea of the wieght it adds?
Thanks again,
Iain
Mike
Old 10-08-2010, 06:32 AM   #26
Michel, Bouchard's Avatar
Trailer: Boler 1300 1973
Quebec
Anyone that did used Duraback one or 2 years ago that could let us know how it is holding up over time ? It is easy to keep clean ? I might go with this solution next spring.
Boler 1300 1973
Jeep Wrangler 2dr 2012
Michel, Bouchard is offline   Reply With Quote
Old 11-16-2010, 08:07 PM   #27
Trailer: 75 boler
looks good but is the rock guard hard to cleen as i would dout you can wax it
bobbie is offline   Reply With Quote
boler
Restored 72 Boler, Campbell River BC, $4200 GlenP Classified Archives 3 04-11-2009 11:29 PM
1975 13' Boler For Sale - Mint, Fully Restored Laun Saunders Classified Archives 0 04-11-2009 09:39 AM
Our 1975 13' Boler so far, with questions Naomi P Problem Solving | Owners Helping Owners 17 02-12-2009 07:16 AM
13' Boler, Restored Frame and Generator KARL PROUDE Classified Archives 0 08-09-2008 05:19 PM
This is our 1975 Boler we restored Mike Montville General Chat 0 12-31-1969 07:00 PM
