Time for Paint Mr Eskimo? - Fiberglass RV
Old 11-04-2012, 08:44 PM   #1
My trailer is almost ready for paint. The challenge is that most paint products I have investigated require temperatures of 10C (50F) or above. In my climate, temperatures are now consistently below 10C. For spot repairs (like fiberglass, fillers, and the like), I can put a heater on the repair for an hour or more to get the product to cure. I do not have an indoor work area, and painting the full trailer exterior is going to be too big an area for heaters. I have found that some products, such as MAS fiberglass resins for example, seem to be more forgiving in terms of temperatures then other products.
Is anyone aware of paint products that will dry properly at temps below 10C? Any suggestions for overcoming this challenge (aside from renting indoor space or putting the project aside until spring)?
Derek
glamourpets is offline   Reply With Quote
Old 11-04-2012, 10:36 PM   #2
Todd Reed's Avatar
Trailer: 1974 Scamp 13'
Malvern, Ohio
A couple of heaters in a storage unit should get the temperature up. Plus renting a unit for a month gives you enough time, and it should only cost less than $50.
Todd Reed is offline   Reply With Quote
Old 11-05-2012, 05:41 AM   #3
Quandry. BUT, you've spent a lot of time and effort to get to this point. I'm with Todd, rent the space for a month. You don't want to have a failure at this point. That or tarp the trailer well and wait until spring. YMMV
Old 11-05-2012, 12:36 PM   #4
Although thw storage room suggestion is a good one, I suspect that the big city rate for a space large enough to work in will be more than $50 month.
From what I can see online, there are paint products that have lower working temperatures. There are also adatives which will lower the acceptable working temp. Does anyone have any real world experience with any of these?
Old 11-05-2012, 01:27 PM   #5
Carol H's Avatar
Derek if you havent already looked into it you may want to consider checking out some of the chain type auto body repair shops in regards to having them do the painting. We have one locally who I know I number of people have used that I recall the cost was in the $300 range - but the owners had done all the prep and taping off etc to the trailer prior. Once you take in the cost of the paint and supplies and now a way to heat a garage it may be worth calling around and asking about.
paint
Insulation - to paint or not to paint? Trillium.Stella Problem Solving | Owners Helping Owners 23 09-04-2012 10:46 PM
Ice box part time, electric fridge part time? zoshia Problem Solving | Owners Helping Owners 8 05-17-2012 04:21 PM
Instead of paint Vicki A. Modifications, Alterations and Updates 8 12-02-2010 01:44 PM
How is Interior Paint Holding Up over time??? sj2moncton Problem Solving | Owners Helping Owners 11 09-12-2010 07:28 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 11:39 AM
» Trailer Showcase
the Boler
Jay H
Big Ei
Lora
