Tips for Drilling Holes in Fiberglass - Fiberglass RV
Old 04-02-2012, 04:23 PM   #1
Lil M.'s Avatar
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
Actually, I want to drill ONE hole...the first one I will be drilling in my Scamp.
I want to mount a little battery-operated clock on the right side of the upper cabinet over the dinette. No faceplate. Just the hands will be visible. I want the hole to be very neat and clean since the only thing covering it will be the itty, bitty, teeny, tiny hex nut that holds the movement in place.
So, does anybody have tips to make the hole very clean? Shot of whiskey beforehand? Painter's tape? Type of drill bit? How to keep the bit from skittering across the cabinet face?
Thanks in advance for your help.
Lil M.
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
Lil M. is offline   Reply With Quote
Old 04-02-2012, 04:46 PM   #2
ScampBum's Avatar
Trailer: 1982 13 foot Scamp
Wisconsin
Painters' tape and first drill a pilot hole smaller than the intended size.A shot a whiskey to celebrate upon completion.
I like your idea.Post pix of the process.
ScampBum is offline   Reply With Quote
Old 04-02-2012, 04:53 PM   #3
Lil M.'s Avatar
Thanks Al! Tape, pilot hole, big hole, whiskey...in that order. Sounds good!
Lil M.
Old 04-02-2012, 05:01 PM   #4
Raz
Raz's Avatar
Vermont
Hi Lil. If I want a clean hole in wood I use a Brad point bit. The problem with standard twist drill bits is that they tear the wood fibers leaving a shaggy edge. They also pull the fibers upward. A brad point bit cuts the fibers on the outside of the hole, leaving a smooth cut. What I have found with my trailer is that while drilling the fiberglass is not an issue, the gellcoat can easily be pulled up off the fiberglass by the standard drill bit. If I wanted a very clean hole I would try a Brad point. Please be aware this is speculation on my part as I have never tried it. A good hardware store will sell Brad point individually. A 1/8" bit will be a few dollars. Might give it a try in a hidden place like under a piece of hardware. Let the drill stop before you pull it out. When you're done we would love to see a picture. Raz
HSS Lipped Brad-Point Drills - Lee Valley Tools
Old 04-02-2012, 05:13 PM   #5
Ed Harris's Avatar
You forgot to mention the hole size you are going for?
In general this is an installers trick that serves me well all the time on surfaces I am destined to mangle somehow?
Use a Paddle bit if you can and use the type with the little points on the end of the 2 paddles.
Drill most of the way thru with light pressure "Feeling" for the point going thru first and then just reverse the drill and finish with the drill in reverse.
Normally you can get tearout going forward with almost any bit but going the other direction lets the bit scribe a hole and slowly remove the excess.
Try it somewhere else first to get the feel for it or if you think I am crazy!
Actually that would just be changing the subject!
Ed Harris is online now   Reply With Quote
Old 04-02-2012, 05:20 PM   #6
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Another way to make a clean hole is to use a tapered reamer. Drill a hole large enough for the tip of the reamer, then use the reamer to enlarge the hole to the finished diameter. Avoids any tear out.
Jon Vermilye is online now   Reply With Quote
Old 04-02-2012, 05:36 PM   #7
Mouse's Avatar
Trailer: U Haul CT13
Drill at a low speed.
Mouse is offline   Reply With Quote
Old 04-02-2012, 05:37 PM   #8
Lil M.'s Avatar
Thank you all for the great suggestions! There's always more than one way to solve a problem, or assure a doubtful remodeler.
The website that I ordered my clock parts from was: Klockit - Continuous Sweep Mini Quartz Movement
Following is the movement I hope to neatly install. The thickness I ordered was 1/8". The hole I need to drill is 1/4" in diameter.
Lil M.
Old 04-02-2012, 06:14 PM   #9
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Just carefully drill the hole. I drilled a large hole in my cabinet to install a voltage gauge, I used a hole saw but you don't need anything that large for your project.
Old 04-02-2012, 10:03 PM   #10
james kent's Avatar
Trailer: Boler 1984
If you use a brad point as mentioned by P Raz, run the drill ackwards slowly at first. This will create a scribed circle in the gel coat and then run the drill in the forward position. If your carfull, you should have no problems.
Old 04-03-2012, 08:09 AM   #11
Trailer: scamp 13
depends,,,what size is needed for the hole?.45 caliber? .38 caliber?
wait....maybe you should just ignore me like my wife does....
Old 04-03-2012, 08:49 AM   #12
IllAnnoy
Go for it! If it is not quite right get a brass, chrome or black decorative washer as an escutcheon.
Old 04-03-2012, 09:40 AM   #13
Lil M.'s Avatar
Hmmm...that would make TWO holes...one in the cabinet and one in the outside wall.
Lil M.
Old 04-03-2012, 09:47 AM   #14
Lil M.'s Avatar
Floyd, that clock movement only has about 1/8" of thread on the shaft/post. I'm hoping I can just screw that little hex nut onto enough thread to hold it in place. Otherwise, I'll have to order another movement with a longer shaft.
Don't know why I ordered such a short shaft. I HAD intended to mount the clock on the big cupboard door and that would require a shaft at least 1/2" long. Musta been dozing off late at night.
Thanks everybody for all your help. Off to the hardware after I close up shop. Then to the liquor store for whiskey. Then home to drill that hole. Pics tomorrow.
Lil M.
Screw holes? pindraak Problem Solving | Owners Helping Owners 70 06-19-2012 11:59 AM
Drilling hole in UHaul floor - sealing Thomas G. Modifications, Alterations and Updates 4 12-22-2011 05:21 AM
Window Holes Diane D Problem Solving | Owners Helping Owners 8 03-02-2009 11:20 PM
Drilling the frame Per Walthinsen Problem Solving | Owners Helping Owners 9 07-31-2008 09:14 PM
Drilling stainless steel sheet metal? Tom Myers Problem Solving | Owners Helping Owners 8 11-02-2007 08:13 AM
