Today's project - slat floor for Bigfoot shower - Fiberglass RV
Old 10-28-2014, 09:13 PM   #1
Trailer: Bigfoot 17' DLX
Alaska
One of the irritations I've discovered about showering in the Bigfoot is how long it takes for the floor to dry. If I shower in the evening and get up in the middle of the night to use the commode, I'll inevitably be stepping on a wet floor. Yeah, I know, I can wipe it down after I shower, which is what I usually do, which is a task I dislike and leaves me with a soaking wet towel and it never really makes the floor dry since there seems to be runoff from the walls and behind the toilet for hours after you waste your time wiping the floor down.
So for awhile now I've been thinking about building a slat floor panel for the shower and today I finally did it. The idea is that the wood slats won't hold a lot of surface water, will be easy to wipe, runoff will go under the slats, and it will simply dry faster.
I built mine with standard stuff you can find at Home Depot or Lowes, 1 x 2 redwood strips, brass screws, and some furniture feet. It only took me a couple hours and it looks great. I haven't used it yet but I have a trip scheduled for November with the whole family, which will be the acid test.
The only issue thus far is that it ate up just under 2 inches of height in the shower and I'm 6' - 1" tall so I'll have to hunch over just a tad to shower. Not a big deal to me if it makes it easier to take a leak in the middle of the night.
Hopefully it will work as well in reality as it did in theory.
trainjunkie is offline   Reply With Quote
Old 10-28-2014, 09:35 PM   #2
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Very nice work. Can you really get REDWOOD at Home Depot or Lowes?
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 10-28-2014, 09:40 PM   #3
Alaska
Yep, in this case, Lowes (in Southern California).
Old 10-28-2014, 10:09 PM   #4
Trailer: Bigfoot B-17 CB
California, Yes. Washington State, No. Mississippi, ???
Cedar will also work almost as well.
Old 10-28-2014, 10:12 PM   #5
Alaska
I really wanted teak. Too expensive though. I can build three to four of these out of redwood for the price of one teak version.
Old 10-28-2014, 10:48 PM   #6
Mississippi
I looked online at HD. That's a big negatory there good buddy for in-store. I can order it on-line, however.
Old 10-28-2014, 10:51 PM   #7
Mississippi
Trainjunkie, if it wouldn't be too much trouble, could you post the SKU or a link to the redwood you bought?
Old 10-29-2014, 12:10 AM   #8
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Your slat floor looks great Mike. I've been meaning to build one too as we had them on some sailboats. Just a thought for you, if you find it doesn't dry off enough for a night time trip, you could always set it in the hall while you shower and put it back in for the night and it's nice and dry. Hey, one other plus to that, it would give you more headroom for the longer time it takes for a shower.
Old 10-29-2014, 05:03 AM   #9
Carl Pa's Avatar
I plan on doing that as well, but mine will be a little higher,so wife can sit and feet touch floor. Redwood in these parts is to much $$$. Will use Cedar or hemlock, pine. Will put some kinda of non-skid material on floor so it won`t slide, bounce softer, so it won`t scratch floor. Carl
Carl Pa is offline   Reply With Quote
Old 10-29-2014, 06:00 AM   #10
Timber Wolf's Avatar
North Florida
Amen brother. Redwood is no more to be had around these parts. There was a time it grew on trees, figuratively speaking. I remember needing a good straight, 16' 2X4 many, many years ago and was surprised to find I could buy Redwood as cheap as Spruce Pine. But those days are gone, never to be seen again. We have Cypress down here though that would work well, and less likely to give a nasty splinter like Redwood might.
Old 10-29-2014, 07:18 AM   #11
Alaska
Steve,
Here's the link to the product from Lowes.
Shop 0.625-in x 1.375-in x 10-ft Kiln-Dried Redwood Board at Lowes.com
SKU: 60559
Old 10-29-2014, 09:02 AM   #12
Mississippi
Steve,
SKU: 60559
Thanks, Mike. I've been wanting to build one of these since two trailers ago. Just never found the time or, until now, the source of the quality wood I needed.
Old 10-29-2014, 10:12 AM   #13
IllAnnoy
Beautiful work!
We had considered something of the that nature... They even make a plastic mesh mat which is advertised to work well.
I settled on a simple towel to wipe down the shower and floor.
It only takes a few seconds and its dry... no scratching the gelcoat or risking mold.
Old 10-29-2014, 10:12 AM   #14
Alaska
Steve,
That is the reason I didn't tackle this project when I was in Alaska. There was no economical way to get the lumber I needed up there.
Dave,
I was thinking about the same thing last night, taking the slats out when I shower, and putting them in dry when done. I need to drill a finger hole somewhere on the slat floor assembly to make taking it out easier but I think this is going to be the way to go.
Cheers!
Mike
bigfoot
Shower floor grate Lainey Modifications, Alterations and Updates 11 09-24-2017 10:49 AM
Gelcoating Burro Floor to prolong floor life? not-very-clever Modifications, Alterations and Updates 12 11-23-2013 09:29 AM
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
Casita Shower Pan removal for floor replacement GMike A Plumbing | Systems and Fixtures 12 03-08-2013 09:45 AM
