Tongue box mounting - Fiberglass RV
Old 04-30-2013, 11:41 AM   #1
Trailer: Trillium Outback - 2004
Tongue box mounting
I'm thinking of buying a tongue box for my trailer. I've noticed people either use self tap screws or U bolts to mount their boxes. Does anyone have any thoughts as to which would work best? Thanks!
Where we’re going, we don’t need a plug-in.
multi-task is offline   Reply With Quote
Old 04-30-2013, 12:32 PM   #2
I would say U bolts would be the best, or maybe some angle iron welded to the trailer for the box to set on, then bolt the box to the angle. I've had a problem finding square U bolts locally, had to get them from McMaster Carr.
Old 04-30-2013, 01:32 PM   #3
cpaharley2008's Avatar
I have mounted 3 of these and the answer depends on your trailer's frame. "I " Beam frames are harder to drill thus the clamps are used. Box frame or "C" channel can be easily drilled and screws utilized. The issue with screws is a smaller surface area for holding vs the clamps when used with the metal brackets give a larger surface holding area. Just my observations. You will have to use very large washers with metal screws and again the brackets installed upside down will give a larger surface for holding.
Old 04-30-2013, 01:34 PM   #4
SilverGhost's Avatar
Trailer: Egg Camper
I would add that you want to spend the extra money on stainless steel bolts, which ever way you go. You wouldn't believe how fast bolts rust on the tongue of a trailer.
Jason
SilverGhost is offline   Reply With Quote
Old 04-30-2013, 02:00 PM   #5
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
I built my own tongue box and used U bolts around the cross members that originally held the propane tank. (I took the tank off as the only gas appliance I had was the stove and I prefer to cook outside anyway). My box lid also opens to the side instead of the back-giving me better access. I also mounted a received on top of the box for a bike rack.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 04-30-2013, 11:31 PM   #6
Thanks for the suggestions. Sounds like I'll go with U bolts.
Tongue box users rgrugg Modifications, Alterations and Updates 10 02-24-2012 03:39 PM
New tongue box Andrew GPSMapNut Modifications, Alterations and Updates 34 07-19-2011 02:37 AM
A/C in closet mounting box and drain pictures davidha Problem Solving | Owners Helping Owners 9 09-05-2010 09:49 PM
Adding a tongue box Roy in TO Modifications, Alterations and Updates 6 06-03-2008 08:31 AM
Tongue Box Barbara Gardin Care and Feeding of Molded Fiberglass Trailers 1 07-03-2006 08:03 PM
