Tongue boxes - Page 3 - Fiberglass RV
Old 09-27-2011, 04:47 AM   #29
Ron F's Avatar
Trailer: Eggless for now.
Formerly NH, now full timing
Greg,
Originally Posted by Casita Greg View Post
1.) Is the rear of the box designed to be "zero clearance" for installing it close to the trailer shell, or do you have to stand it off a bit (lid/hinge clearance to trailer shell when opened?)
It does stand out about 1 - 1/2 inch from the body of the trailer. That was as far forward as I could go before I ran into the battery box. At that point the top opens fully, but needs to be held open.
2.) Did you have to raise it, or "step it up" in any way. I ask because it will be a bit wider than the configuration of the "A" of my trailer frame/tongue and I use a 2-bar WDH.
The box sits right on the frame. I don't use a WDH, so I can't really say how that would work. For my frame, the box fit very nicely, matching the angle of the A frame.
Greg[/QUOTE]
Old 09-27-2011, 04:51 AM   #30
Ron F's Avatar
Originally Posted by Night Sailor View Post
Ron, Did you drill a couple of ventilation hole in the bottom of you box?
I have a couple of 2 inch round soffit vents in the back corners. I'll see if I can get a photo with the tanks removed.
Ron
Old 09-27-2011, 08:07 AM   #31
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Actually, the Line-X is on the outside to protect it from gravel etc. It is more difficult to clean since it is a rough surface, but it does protect the box.
I think it is a great option. It is the perfect location for things you don't want to put inside or items you use when setting up. Since I don't have a truck bed for those things, it is a great addition for those pulling with an SUV.
Check your battery boxes! Gina D. General Chat 8 10-31-2010 07:07 PM
Fiberglass Boxes RON HEIST General Chat 5 05-06-2009 05:24 PM
Tongue Jack Parker Buckley Problem Solving | Owners Helping Owners 16 11-14-2007 08:06 PM
Escape Trailer Storage Boxes Thane Modifications, Alterations and Updates 5 03-27-2007 06:53 PM
Generator Boxes Benita Modifications, Alterations and Updates 2 03-13-2007 07:32 PM
