Tongue generator mount - Fiberglass RV
Old 08-22-2017, 06:52 PM   #1
Any feedback on mounting a 120 lb generator above propane tank on a 13 ft scamp it would be at least the distance to remove propane tank tongue wt still way under max
Stump is offline   Reply With Quote
Old 08-22-2017, 09:04 PM   #2
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
Try looking at the specifications on this rack.
Trailer Tray A-Frame Cargo Carrier - Stromberg Carlson CC-255 - Cargo Carriers - Camping World
k corbin is online now   Reply With Quote
Old 08-23-2017, 04:03 PM   #3
Trailer: Shopping
CO
As you would guess, in that position most of the weight will be on the hitch, some on the trailer axle.
I'd be tempted to approximate the effect by resting the weight of the generator on the tongue (while parked on a scale) using steel weights. Then you could assess the impact. The actual height of the generator would affect handling and center of gravity.
Tom 72 is offline   Reply With Quote
Old 08-23-2017, 04:50 PM   #4
Trailer: CASITA
Ron,
you said tank, as in one, tank full wt.'s in at 47 lb.s, you would be top weavy from the git-go!! May add sway on hitch and tug, not good. Just saying.
Bbc ii
ps
most of 120# would result in about 100# added to hitch.
BARNEYCONE is offline   Reply With Quote
Old 08-23-2017, 08:05 PM   #5
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Ron, I'd be more concerned about the stock frame standing up to that much extra weight load on the tongue. Seems most of the frames that crack or break is at that point.
Borrego Dave is online now   Reply With Quote
Old 08-26-2017, 07:02 AM   #6
Trailer: 1999 Casita 17' SD
Ohio
X2
Joe
generator
Generator exhaust concern on trailer tongue. Kevin K Problem Solving | Owners Helping Owners 82 02-25-2014 07:11 PM
Prototype Generator security mount plate widgetwizard Commercial Posts and Products 21 11-01-2013 10:08 AM
Generator Mount Location William Brown Modifications, Alterations and Updates 12 12-02-2011 10:18 PM
» Virginia Campgrounds
