Tongue Tied... - Page 3 - Fiberglass RV
Old 06-22-2013, 02:24 PM   #29
Ok. New axle welded on! These are the wheels I bought. Is the hole in the wheel supposed to be a close fit to the center of the hub or do the tapered lug nuts do the job of centering the wheel? Do I need to get different wheels??
GrregP is offline   Reply With Quote
Old 06-22-2013, 03:53 PM   #30
Brian B-P's Avatar
Is there supposed to be a picture?
No, not normally with trailer axle hubs; they are not hub-centric.
... or do the tapered lug nuts do the job of centering the wheel
Yes, trailers are usually bolt-centric.
Old 06-22-2013, 04:15 PM   #31
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
But wheels on egg campers should never be egg-centric.
Old 06-22-2013, 04:24 PM   #32
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
exactly:
jack
Old 06-22-2013, 05:13 PM   #33
Duh. Attaching the picture would have been good i guess...
Sounds like I'm ok then.
Old 06-22-2013, 06:33 PM   #34
Brian B-P's Avatar
Looks fine. If you look at the area of the hub where a wheel centre hole would need to fit to hub-centre, you can see that it's not machined to a good surface, confirming that the wheel shoukd not touch there and it is intended to be bolt-centric.
Old 06-22-2013, 06:53 PM   #35
Thank you! That's a relief.
Tom, I thought that was an egg-cellent pun.
Old 06-23-2013, 06:22 AM   #36
GMike A's Avatar
Tom does have a tendency to Eggaterate on many occasions. So be careful.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 06-23-2013, 08:32 PM   #37
Trailer: '77 Scamp
Those wheels are dynamite. I may have to add'm to my wish list.
Otters is offline   Reply With Quote
Old 06-23-2013, 11:40 PM   #38
They were literally some of the cheapest I could find:
13" x 4.5" White Spoke Trailer Wheel with bias ST17580D13C Tire Mounted (5-4.5" bolt circle)
http://amzn.com/B001KPEY2Y
We'll see how long they last. The rims are a match for the ones I took off, with the red and blue striping. I have no idea if they were the originals.
Tongue je.bedard Modifications, Alterations and Updates 14 08-29-2012 07:22 AM
New tongue box Andrew GPSMapNut Modifications, Alterations and Updates 34 07-19-2011 02:37 AM
tongue storage cpaharley2008 Modifications, Alterations and Updates 2 03-23-2011 07:02 PM
Tong Tied Steve L. General Chat 7 08-29-2007 04:21 PM
Another Tongue Job Greg A Care and Feeding of Molded Fiberglass Trailers 6 07-30-2007 05:55 PM
