Awesome Awesome work! When are you going to
paint the hot rod to match?
Seriously, that's really great.
My garage spray booth is like that. I stapled slats on the bottom of the plastic so I can roll up the poly and wire-tie it to the ceiling when not in use.. I also screwed my regulator/water filter to the ceiling and have a coily cord hanging from it so I can reach all the corners of the spray booth without dragging my hose all over the place... I also screwed metal shelving supports to the ceiling so I'd have lots of places to hang things for spraying... I also use a
furnace blower to blow air out the bottom of the garage door and put a
furnace filter in front of it. The rest of the door panel gets blocked off and fresh air comes in the little slot at the top. I like your idea of having the filters at the bottom though.
I only regret that my
Boler 17 won't fit in my garage so I'm going to have to rent a booth.
Good work!
