Tow Vehicle charging - Fiberglass RV
Old 03-14-2011, 07:18 AM   #1
Trailer: 1983 13' Scamp
Massachusetts
Hi all, well we have been pretty busy this winter resto-modding our new to us 1983 13' Scamp. Will post some pictures of the finished product once the dust settles (literally, I have been doing a bunch of fiberglass work) . I do have a question about tow vehicle charging. Currently we just flat 4 pin connector, since I am going to be putting 2 6v golf cart batteries in (I put in a new high efficiency 12v fridge, solar panels are ready to mount and an onboard 110v charger) I also want to keep the batteries topped up going down the road. I have a battery isolator on order but I was wondering what kind of plug people are using. One other thing, our camper camp with electric brakes, not sure of they work but if I am replacing the plug can I get one that does it all, lights, charging and brake control? I see the 7 pin with a separate 4 pin connector on etrailer.com. Will this also handle the house bank charging?
Evergreen is offline   Reply With Quote
Old 03-14-2011, 08:04 AM   #2
Trailer: 1976 Surfside
A 7 way plug can do it all ,here is a wiring diagram
ken h is offline   Reply With Quote
Old 03-14-2011, 08:50 AM   #3
Massachusetts
Would it be the wire labeled "Auxiliary" ?
Old 03-14-2011, 09:07 AM   #4
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
No. The "auxiliary" is most commonly used (factory pre-wired) for buck-up lights. Contact #4 is used as 12V feed that can be used for battery charging.
Trailer Wiring Diagrams | etrailer.com has excellent trailer wiring info.
Andrew GPSMapNut is offline   Reply With Quote
Old 03-14-2011, 09:17 AM   #5
Massachusetts
Ok, thanks all. With those examples I am all set. Now I just need to order the parts.
Old 03-14-2011, 06:14 PM   #6
DannyH's Avatar
Trailer: 1976 Scamp 13 ft
Evergreen, who is the manufactor of your battery isolator? I'm thinking of getting one for our rig.
DannyH is offline   Reply With Quote
Old 03-14-2011, 06:43 PM   #7
Massachusetts
Well, to be honest I sort of cheaped out on it (we have taken a $1200 camper and put about another $3500 in it over the winter so I am trying to slow down a bit on it...). I ended up getting it off Ebay Sure Power 702 Single Input Dual Battery Isolator New - eBay (item 380323203834 end time Mar-13-11 19:09:51 PDT). I figured for $26 it was worth a shot.
Tow Vehicle Charging Battery Gerry Modifications, Alterations and Updates 11 01-18-2011 06:59 PM
We did it! Have A new TOW VEHICLE! Vickie B. Towing, Hitching, Axles and Running Gear 35 10-07-2010 03:45 PM
Tow vehicle Steven F Problem Solving | Owners Helping Owners 7 01-09-2006 06:49 PM
Tow Vehicle Legacy Posts Towing, Hitching, Axles and Running Gear 5 08-10-2003 12:12 AM
