Tow Vehicle power to solar controller? - Fiberglass RV
Old 07-28-2012, 02:52 PM   #1
dylanear's Avatar
Trailer: 2001 Scamp 13'
My solar controller will charge two separate batteries, monitoring them separately, optimizing voltage for each to their battery type (there is a type selector for each channel). As long as I can properly isolate the panels from the 12V T.V. source (if that's needed) is there any reason I can't just connect T.V. power to the 12V solar panel input on my solar charger like it's a 12V solar panel and then get intelligent charging of my batteries from the T.V. instead of whatever the T.V. voltage happens to be??
dylanear is offline   Reply With Quote
Old 07-28-2012, 05:23 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
It seems like it would work as long as you didn't exceed the current capacity of the controller. To protect it, you could install a circuit breaker in series with the TV input (like a 10 amp breaker for a 10 amp maximum controller).
I'm no EE, though. Maybe there would be an excessive voltage drop across the controller.
solar
Solar Panels on Roof of Tow Vehicle rvsue Modifications, Alterations and Updates 17 02-11-2013 02:02 PM
Always leave brake controller in vehicle? ThomasE Towing, Hitching, Axles and Running Gear 24 05-15-2011 03:23 PM
Solar Sans Controller James P M Modifications, Alterations and Updates 4 08-31-2010 10:04 PM
solar controller mounting for Boler Rick G Problem Solving | Owners Helping Owners 15 06-16-2010 10:38 AM
Solar charge controller yvonne Care and Feeding of Molded Fiberglass Trailers 24 06-26-2008 05:46 AM
