Towel rack - Fiberglass RV
Old 03-23-2007, 11:44 PM   #1
I remember finding these quite often in Europe and thought them useful, so I installed one to see if it would be of value in the Burro.
Claimed to warm and dry towels, dry wet clothes and undies, mitigate dampness, etc. etc. I found a model that would fit the bathroom wall and installed it with a couple of modifications. 120v, at 46 watts, switchable between shore power and inverter. Water resistant switch moved to the wall, and it is lit when on (night light?).
Puts out a surprising amount of heat from a measly 46 watts and is designed to run continuously. Our bathroom can be colder when the rest of the trailer is warm, but it seems like this should cut the chill nicely. We'll see.
Old 03-24-2007, 12:14 AM   #2
Miriam's Avatar
Trailer: Surfside TM14 1974
How clever! Nice touch!
- Miriam
Miriam is offline   Reply With Quote
Old 03-24-2007, 06:13 AM   #3
ooooh, park next to me Per at a Gathering!! The idea of wrapping in a warm towel after bathing is....NIRVANA
Certainly looks better than the clothes line I string across the back of my trailer to dry towels/swimsuits
Old 03-24-2007, 07:26 AM   #4
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
Per, doesn't that bring the Burro up to right about 5,000 lbs now?
Nice mod! Where did you source this?
Roger
Old 03-24-2007, 08:08 AM   #5
pretty fancy!!!
Old 03-24-2007, 10:30 AM   #6
Roger:
This weight thing is a give-and-take thing for me. Thanks to the numerous free weighing stations here I can keep a close eye on how it is going. I'm working on a list of items to "lighten" to compensate, but unfortunately the cost and trouble of doing so increases gradually.
At least the weight of this towel warmer is on the curb side, which is significantly lighter than the street side.
This unit is a Warmrails "Regent" model, which comes in a convertible soft wired or hardwired configuration. I went a bit further, hacksawed off the switch box, drilled and routed the wiring through one of the mounting brackets, etc.
When my daughter was living in Dresden her apartment had one of these things. She found it great for drying clothes as well as making nice warmed towels.
For our long road trips, I'm thinking of using the "bucket in the back of the van" as a clothes washer. There should be no problem using this rack as a clothes dryer as we drive, I believe.
Old 03-24-2007, 11:10 AM   #7
Gina D.'s Avatar
West Coast USA
hmnn.. yes, that back bathroom wall screams for something, but the curve makes it difficult to do anything but stick up goofy tub stickies.
Perhaps I will do this, and hook up my battery powered Cold Heat soldering iron to warm it up..
Wood Rack Matthew A Care and Feeding of Molded Fiberglass Trailers 7 02-25-2010 09:04 PM
wire rack ronsmith100 General Chat 16 05-10-2009 02:05 PM
New towel rails won't kink or bend if you bump into them. peterh Modifications, Alterations and Updates 1 04-21-2008 06:53 AM
Bike Rack kathy chamblin Problem Solving | Owners Helping Owners 5 08-18-2007 09:41 AM
Casita Paper Towel Rack Legacy Posts Modifications, Alterations and Updates 11 04-28-2003 06:47 PM
