Trading out microwave to toaster oven - Fiberglass RV
Old 07-12-2015, 12:31 PM   #1
We have a 2002 17 foot Cassita Liberty that came with an installed microwave oven. We want to take that out and install a toaster oven instead. Has anyone done that and is there any problems with heat exhaust or anything? The placement of the oven is above the refrigerator.
spiritart is offline   Reply With Quote
Old 07-13-2015, 11:14 AM   #2
GMike A's Avatar
I did it and wish had done it sooner. My setup is identical to yours. I have had no issues. I put in a turbo convection oven instead of conventional. A microwave in my opinion heating up a huge roast or chunk of meat could or would run 20 minutes or so and generate a lot of heat. Anyway I gave up a minor inconvenience of warming a cup of coffee for something in my opinion was a lot more functional.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 07-13-2015, 11:27 AM   #3
Thanks so much for your reply. Did you have to make any adjustments to switch it out?
Old 07-13-2015, 12:07 PM   #4
Trailer: 16ft Scamp
I rally want to switch out my microwave too, is it hard wired into the trailer?
mwolf is offline   Reply With Quote
Old 07-13-2015, 12:39 PM   #5
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Should just have a regular plug in behind the microwave.
Borrego Dave is online now   Reply With Quote
Old 07-13-2015, 12:51 PM   #6
I would be somewhat concerned about putting a 1000-1500 watt toaster oven in that space. Check with the MFG and see what it sez about clearances and enclosed spaces.
I looked at the book for a 1600 watt Oster I have in my kitchen and it warns to have nothing within 10 inches of the sides and top and 3 inches behind. It also warns to not install in an enclosed space.
BTW: Just last week I looked over a 30' class "A" motorhome that burned to the ground while overnighting in a San Clemente, CA Wal-Mart. About all the owner would say was that the fire started in the kitchen
Old 07-13-2015, 02:34 PM   #7
GMike A's Avatar
I guess the bottom line is use common sense. Googling the issue brought up many people switching over to a microwave- convection oven and then getting the benefit of both worlds. Regardless for liability issues I would use at your own risk. The oven that I have is small with lots of room on both sides and top and large enough for a small baking pan or TV dinner size pan/plate etc. I can make a small pan of biscuits or heat/bake a small casserole. All opinions are soley mine.
Mike
K5NAN
"Miss Adventures"
Old 07-13-2015, 03:09 PM   #8
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
I used the oven on the picnic table out side to keep the heat down
MRClaus is offline   Reply With Quote
Old 07-13-2015, 04:13 PM   #9
Trailer: Casita 17' 2000 Dodge Dakota 3.9L
My casita didn't come with a built in microwave.
But - when I use my toaster oven, I take it out of the microwave area and rest it on the door. You may not have a door, to do that. But I would recommend that you consider doing something similar while cooking. You might put the oven over the sink on a cutting board or one of your tables while in use.
If you don't I'd make sure the area around the oven can handle the heat.
Dextersp1 is offline   Reply With Quote
Old 07-13-2015, 06:19 PM   #10
I wrote to the Casita company: Can the microwave oven in the Liberty Deluxe be replaced by a toaster oven and is there any problem with the heat it creates?
I got this answer: yes it can be replaced just dont forget to turn it off when finished.
So, it looks like it should probably work fine. It does have direct access to vents where it is located and a regular plug. I will probably get a small one, so it will have room around it.
Old 07-13-2015, 07:34 PM   #11
We have one of those folding camp kitchen tables. Gas grill sets on top, toaster oven on bottom shelf, OUTSIDE of the trailer.
Old 07-13-2015, 07:38 PM   #12
I'd be sure to put that reply in the papers for your Casita, you may need it some day.
Old 07-14-2015, 10:25 AM   #13
WendyW's Avatar
Now someone needs to invent a way for a timer on a toaster oven to automatically shut it off when the time is up. I've forgotten to turn the oven off more than once when the last batch of cookies was done.
WendyW is offline   Reply With Quote
Old 07-14-2015, 10:36 AM   #14
Both of the toaster ovens I have already have built in timers, that's fairly standard I believe.
That's why I was surprised by the reply from Casita, it sounds like the answer came from someone that doesn't know much about toaster ovens.
microwave
Toaster oven/Microwave/Convection oven Karalyn General Chat 22 02-04-2017 10:45 PM
trading vent hatch for a fan April Wilcox Problem Solving | Owners Helping Owners 12 09-09-2009 11:39 AM
Trading up?? Don G General Chat 3 09-09-2007 12:52 PM
installing microwave and toaster oven Legacy Posts Problem Solving | Owners Helping Owners 11 05-06-2003 03:22 PM
Toaster oven/Microwave/Convection oven Camp Cooking, Food & Recipes 0 12-31-1969 07:00 PM
