Trillium 13' Queen Bed - Fiberglass RV
Old 02-02-2015, 12:20 AM   #1
dleverton's Avatar
Trailer: Trillium 1300 1973
Well I'm committed now. I have started to cut fibreglass.
Name:	ImageUploadedByFiberglass RV1422860223.134509.jpg
ID:	80144Click image for larger version
Name:	ImageUploadedByFiberglass RV1422860238.951673.jpg
It didn't take long to realize that the best way to cut the fibre glass is with the vibration cutter, $39 from Princes Auto. It cuts quickly and it is easy to cut straight if you clamp a piece of angle iron on the cutting line and use it as a tool guide. I tried a jigsaw, a disk grinder with a thin abrasion disk and various hand saws and the vibration tool is the clear winner.
There are actually 2 ways to fit a Queen:
1. Remove the closet and mount the mattress longitudinally as it is 59" from the kitchen to the curb wall and a Queen is 60" wide. I am 5' 7" and it is 5' 9" from the back wall to the door opening, so it would be a short Queen 59" X 69". Or
2. Remove the closet (leaving the upper 20" as a cupboard), and leave the closet wall closest to the door, and cut away almost half of the kitchen. That gives you a lateral Queen, 60" wide by 77" long. Works for me, and that is my plan.
I will then rebuild the kitchen with a slightly smaller sink. I will post pictures as I go. I am going to build a large roll out shelf under the bed and I figure I will have actually gained storage over the original configuration. The only loss is in the width of the kitchen and we usually cook outside anyway.
Doug L
Doug
dleverton is offline   Reply With Quote
Old 02-02-2015, 05:12 AM   #2
Raz
Raz's Avatar
Vermont
Fortune favors the BOLD !!! Raz
Old 02-02-2015, 03:04 PM   #3
Trailer: Bigfoot 19'
I'm in the Westshore of Vic and want to do the same thing and I have an idea that might inspire I would love to see your handy work. Can we meet up?
evenweight is offline   Reply With Quote
Old 02-02-2015, 07:13 PM   #4
dleverton's Avatar
Hey Evenweight, absolutely. I'm in Maple Bay, how do I reach you?
Doug L
Doug
Old 02-02-2015, 09:35 PM   #5
i sent a pm did you get it?
Old 02-02-2015, 09:45 PM   #6
dleverton's Avatar
I didn't so I sent you one.
Doug L
Doug
Old 02-08-2015, 09:40 PM   #7
dleverton's Avatar
The Queen bed is getting closer to reality.
Name:	ImageUploadedByFiberglass RV1423453428.640247.jpg
Name:	ImageUploadedByFiberglass RV1423453469.035430.jpg
ID:	80333Click image for larger version
Name:	ImageUploadedByFiberglass RV1423453493.011512.jpg
ID:	80334Click image for larger version
Name:	ImageUploadedByFiberglass RV1423453513.954362.jpg
It is enjoyable work.
Doug L
Doug
Old 02-13-2015, 03:10 PM   #8
Trailer: 1978 Trillium 4500
Hi dleverton and evenweight it would be great to see both of you at our Bolerama in Nanaimo, June 26th to 28, 2015 at Living Forest Campground. It would be great to have more Trilliums present. If you want more info email me or check out the Island Bolers and friends Facebook page.
Island Claire is offline   Reply With Quote
Old 02-13-2015, 03:20 PM   #9
dleverton's Avatar
Thank You Claire, I have put it in my calendar.
Doug L
Doug
Old 02-14-2015, 07:44 PM   #10
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
waiting to see at will be great
MRClaus is offline   Reply With Quote
Old 02-15-2015, 04:58 PM   #11
Roger C H's Avatar
Unhappy Cutting fiberglass
I don't want rain on your parade, but it is my understanding that all the internal fiberglass structure of a Trillium is just that, structural. Removing parts will weaken the structure.
The closet and the backsplash/stove/overhead cabinets support the roof.
The seats in the corners are not just conveniences, but stiffeners for the corners.
Scamp places the supports at the bed end of their "kitchen" for a reason. Nothing in any of these eggs are superficial, they all have a purpose, sometimes multiple purposes.
Cut at your peril.
Old 02-15-2015, 07:23 PM   #12
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
you can still make some support i know nyou can
Old 02-15-2015, 11:56 PM   #13
dleverton's Avatar
Hey Roger. Thanks for your comments and concern.
I was initially quite concerned as well as what you say is absolutely true; it is an integrated structure.
I solicited advice from a number of people on this site who have made similar and even more radical changes. They in most cases compensated for the removal of some of the internal structure, with additional stiffeners. Before any cutting I made a number of measurements to determine a baseline for the structures rigidity laterally and torsionally, and have been repeating those measurements as changes are made. I am prepared to add additional stiffening in the form of laminated beams as needed. I left one wall of the closet intact, and the kitchen while now shorter, still retains all of the original structure below the bed level and above bed level have added a wooden structure to support lateral stiffness. My sense is that I am pretty close to the original stiffness at this point. Pictures to follow.
Doug L
Doug
Old 02-16-2015, 09:56 AM   #14
dleverton's Avatar
Current state of project.
Name:	ImageUploadedByFiberglass RV1424105730.491144.jpg
ID:	80468Click image for larger version
Name:	ImageUploadedByFiberglass RV1424105763.667958.jpg
ID:	80469Click image for larger version
Name:	ImageUploadedByFiberglass RV1424105778.458463.jpg
ID:	80470Click image for larger version
Name:	ImageUploadedByFiberglass RV1424105813.346402.jpg
Doug L
Doug
trillium
Trillium 13' Queen size bed. dleverton Modifications, Alterations and Updates 20 07-14-2015 04:35 PM
Trillium Queen Bed option revisited Raz Modifications, Alterations and Updates 16 10-17-2014 08:54 AM
Trillium queen bed option Barrie Bochoff Modifications, Alterations and Updates 10 12-03-2011 06:46 PM
Seeking w/ queen bed near NE Florida Jim and Diane Wanted: Molded Fiberglass Travel Trailers 0 04-24-2011 03:58 PM
2005 25' Bigfoot Rear Queen Bed For Sale F.Bishop Classified Archives 7 11-08-2009 08:03 PM
