trillium 1300 with 14" wheels fitment - Fiberglass RV
Old 07-03-2016, 12:41 PM   #1
I have seen a few other threads on this but nobody has really mentioned clearance issues if any while actually driving and or setting up on uneven sites. Most 14" trailer tires that I can find are 205/75r14. Which to me means it's going to fit slightly taller. From the pictures I have seen the gap to towards the rear looks a little tight. I'm just wondering if those running the set up if you have had any issues with rubbing at all.
Thanks
Gavin
cabnfevr is offline   Reply With Quote
Old 07-03-2016, 05:46 PM   #2
Trailer: Trillium 1300
I have Ford Ranger 14" alum rims with 205 75r 14 tires with no clearance
issues on my 76 13' Trillium.
Material Guy is offline   Reply With Quote
Old 07-03-2016, 07:35 PM   #3
Trailer: '78 Trillium 4500
Currently running 14's, even temporarily ran a set of 15's off my dump trailer with no issues when I had some welding done.
Dave_L is offline   Reply With Quote
Old 07-04-2016, 06:07 PM   #4
Thanks for the replies. Might have to get some period correct alloys!
Old 07-04-2016, 08:36 PM   #5
MoDZuKi's Avatar
Trailer: Trillium 13'
I tried the 205 75R and 14" trailer rims.. they would have worked BUT I was a bit concerned about clearance on big bumps.. so I decided after a bunch of calculations and searching on 14" white rims and 195/70R-14
Nice and wide and fairly low profile! Stable as all get out and look great!
Cheers
Dave
MoDZuKi is offline   Reply With Quote
Old 07-04-2016, 08:38 PM   #6
Where did you find that size in trailer tires? Or are they truck tires?
Old 07-04-2016, 09:47 PM   #7
MoDZuKi's Avatar
Hi they are passenger car tires lower profile to control sway. They roll beautifully and stable
Old 07-05-2016, 09:58 AM   #8
David Tilston's Avatar
I also use 14" Ranger rims on my Trillium 4500. No problem.
Old 07-05-2016, 12:25 PM   #9
Are the wheel wells and axle height the same on 1300 and 4500?
Old 07-07-2016, 07:31 PM   #10
I have three of each. I just went out with a tape measure. The wheel wells seemed to be identical on both the 1300's and the 4500's. They were 28" long where I measured them, which was just where they started to curve under the trailer. They also all seemed to be 16" from the center of the wheel to the top of the well.
The age range is 73 to 77 on the 1300's and 76? to 78 on the 4500's.
Old 07-07-2016, 07:38 PM   #11
Thanks David
Old 07-07-2016, 09:30 PM   #12
What size are the Ranger tires and are they LT rated? I don't know why I'm having such a hard time finding any under 215 width?
Old 07-07-2016, 10:38 PM   #13
My tires are 205-75 R14 ST.
Old 07-08-2016, 09:12 AM   #14
Clayton's Avatar
Trailer: 1975 Trillium
I am running the same size tires as David. 205 / 75R14. When I replaced my axle last year, I added a 1 1/2" spacer between the frame and axle. The outside diameter of the tire follows the curve of the wheel well perfectly.
Clayton is offline   Reply With Quote
trillium
Changing out 13" wheels for 15" wheels Ed Morris Towing, Hitching, Axles and Running Gear 3 01-26-2018 04:14 PM
Aftermarket Wheels.. "Let's See Em " Phil Underwood Modifications, Alterations and Updates 73 07-16-2013 09:12 PM
Some "before" and "after" shots..... Don & Viv Modifications, Alterations and Updates 13 07-29-2010 04:52 PM
My "new" 1977 Trillium 1300 jimliston Problem Solving | Owners Helping Owners 12 02-10-2008 09:21 AM
