Trillium 4500 electric install - Fiberglass RV
Old 07-12-2010, 08:48 PM   #1
Trailer: Trillium 4500
So after 5 months of sourcing all the pits and pieces, and sweet talking my electrician buddy, in April it was all installed.
2 6V T-105 batteries
1000W Xanterx Freedom HF inverter/smart chargrer
130W Sun Electronics solar panel
Morningstar SunSaver solar controler
15.5" Skyworth TV/DVD combo
Logitech speaker system with subwoofer
When installed, I plugged in and topped of the batteries. Since then, 6000mi. and 25+ camping days later, I haven't needed to plug in again. We always "boondock" and we're in the sunny SW, not Canada, so I figured that the solar would really take care of business and it has! I set up my TV to charge from the alternator and with that and the solar I can't ever see needing a generator. I'm planning on switching my 12V interior lights over to LED's but until I add some more power eaters; water pump and heater ect., theres no need I can run the incandesents all night with power to spare.
Sorry the pics. aren't bigger!
Inverter/battery monitor, between upper cabinets.
Power center; under front bench; AC breaker box, inverter, DC fuse box, and solar controler.
Exterior AC outlet.
Battery box.
Roof shot.
Scott H is offline   Reply With Quote
Old 02-18-2011, 10:20 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hello-
I see you posted this last July- I'm interested to hear how it's worked out now that you've used the system for a while???
Also- do you carry a propane bottle on the tongue with the batteries?
Old 02-24-2011, 08:55 PM   #3
Hi Francesca, The system has been perfect, if there is a fault it's that it's a bit overkill but, with the outside outlet I can let the neighbors plug in
The steel grate in front of the battery box holds one or two 20lb propane tanks, I usually travel with just one.
Old 02-25-2011, 12:43 PM   #4
Trailer: 1987 Lil Bigfoot
How much?
How much was the upgrade?
Jeff Segel is offline   Reply With Quote
Old 02-25-2011, 01:25 PM   #5
[QUOTE=Scott H;238277]Hi Francesca, The system has been perfect, if there is a fault it's that it's a bit overkill but, with the outside outlet I can let the neighbors plug in
The steel grate in front of the battery box holds one or two 20lb propane tanks, I usually travel with just one.[/QUOTE
Any idea what the tongue weight is with/without the propane bottles? Mine is around 150 lbs. with a deep cycle battery, a 20lb. tank, and the leveling blocks on it.
trillium
Trillium Furnace Install Tracy S. Problem Solving | Owners Helping Owners 3 08-05-2009 10:06 AM
1979 Trillium 4500 for sale -- C$5200 or US$4500 - SOLD jenniferm Classified Archives 8 07-14-2009 01:38 PM
Update Electric Brake/Controller install on Boler kevin61 Towing, Hitching, Axles and Running Gear 5 01-12-2009 08:03 PM
Update Electric Brake/Controller install on Boler kevin61 Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
Trillium Electric Brakes Booker B. Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
