Trillium 4500 Renovation - Page 3 - Fiberglass RV
Old 08-25-2016, 05:08 AM   #29
Johnny M's Avatar
Deep South
Originally Posted by Randy Bishop View Post
Tell you what "Burro Bill" I'll come help you with your Burro if you will help me with my other projects coming up... Got 4 more to redo... The one with the box on front has already been done...
I REALLY like your trillium rock guard graphics. Very nice work on this unit. How did you end up with a "fleet" of them?
Old 08-25-2016, 08:30 AM   #30
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
Did you reuse the existing frame for the rock guard? I need to make a new one but the frame is damaged and am looking for suggestions on where to buy something to use. Also, what material did you use for the cover itself?
Patricia D. is offline   Reply With Quote
Old 08-25-2016, 10:06 AM   #31
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
I'm a hoarder and its a sickness I can't shake.. Sold 3 but ended up buying 4 back..... They just seem to find me some how...
Randy Bishop is offline   Reply With Quote
Old 08-25-2016, 10:20 AM   #32
Ardmore, Alabama
Yes I re-used the existing gravel guard... You can see where I have them parked.. That location is a new building I bought with 2 acres, I don't live there but the neighbor tries to watch everything for me..One of mine the gravel guard was in perfect condition but some idiot must have come by and wanted to look inside and instead of just opening the stupid front door which was "NOT" locked they tried to pry open the front gravel guard and look inside.. Well they ended up breaking both sides .. I took it off and carried to my local welder and he was able to aluminum weld it back together and straighten it .. So you might try that can't hurt to just see if someone can fix it.. I really never thought they could fix it but they done a really good job on it...
Old 09-03-2016, 06:19 PM   #33
Ardmore, Alabama
Well I was up late last night sewing curtains.. Got them finished and installed today.. I do things a little different I don't like curtain rods they are always falling out of the brackets then needing replacing.. So I'm using bungee cords and since this one is "Red" theme I used red balls on the ends, I install hooks you can easily get at any hardware store, cut the bungee cords so they just fit when stretched all the way out and hang the curtains that way...
Pictures........
Old 09-03-2016, 06:24 PM   #34
Ardmore, Alabama
Also completed the front area with the small seat that converts to a table.. Needing the frame back so I can install the wood flooring, can't do it till I get the body bolted back on ..... The front area pictures..............
Old 09-03-2016, 06:29 PM   #35
Ardmore, Alabama
Trailer is now setup with a 12 volt on-demand water pump for the sinks and toilet using stored water, city water still setup the same with cutoff valve so it can't bleed back through to the holding tank... Since the hand pumps will no longer be used I used a hole saw and installed stainless steel cup holders where they were located.....
Old 09-04-2016, 09:10 PM   #36
Roy in TO's Avatar
Then re-built the front gravel guard......
Randy ... everything looks great!!
What did you use for the panels of the gravel guard?
Originally Posted by Carl V View Post
Super nice job!
Can you post a close up picture of the Trillium logo on the rock guard? It looks really nice.
I need to have mine redone eventually.
You can order reproductions from Tom @ Trillium RV, go to:
trilliumrv.com
Then click on Parts
Need help... Does anyone know what Dexter Axle was used in a Trillium 4500..
The axle specs are listed here:
https://trilliumrv.wordpress.com/vin...um-repair-faq/
Too bad you extending the frame, Tom has what appears to be a good price on a frame/axle combo for a 4500.
Old 09-05-2016, 10:41 AM   #37
Ardmore, Alabama
The gravel guard panels are FRP panels (Fiberglass Reinforce Panel) you can get at Lowe's or just about any hardware store.. They are mostly used on Commercial construction jobs in restrooms or kitchen area's I have several in several different colors left over from job's we done in past. They are bumpy on the finish side and smooth on the back, I sanded the back and painted them to match the camper. I'm a bad hoarder and hate throwing things away..
I know you can get the logo's from Tom but I wanted different colors and my decal guy is so cheap and fast, I can tell him what I want and he has it the next day... Did you see the decals he made me for the stove, I only wanted 2 in case I screwed one up but he made 6 and charged me 5 bucks I posted the extra ones here in case someone had a stove like mine I would send them out free if anyone need a couple...Wedgewood Stove
I've extended the frame on 2 others and really like having a place to put folding chairs, cook stove, lantern's and just stuff in the front box rather than putting it in the storage binds which in the back are a pain to get into..Since this one is going to be mine I had to do it....
Old 09-09-2016, 08:49 PM   #38
Ardmore, Alabama
Well I got back to some more items while waiting on the frame to be extended and the new axle to be installed.. Got my door spray foamed something I do on all of my Trilliums I think it makes the door stiffer and adds insulation.. I put a small clear hose on the spray can and feed it to the bottom of the door then spray about 1/2 the can moving it back and forth, I let that cure over night and keep repeating the process until I get it full.. Always use the foam for window cracks because it does not expand as much as the other stuff.... pictures of the door completed, wish I had pictures of the process but somehow they deleted from my camera....
Old 09-09-2016, 09:09 PM   #39
Ardmore, Alabama
This camper sat in my back yard for 2 years completely stripped.. no windows, furnace removed, all cushions removed and all the cabinet doors and any wood removed.. It sat there covered with 2 tarps until I got the chance to start working on it.. Bought a 30' x 30' building on 2 acres of land that I'm doing all my work in now so that makes things a lot easier.. But during the renovation and moving everything from my small shed a lot of things got misplaced.. I was sure I had already cleaned the furnace cover but the only one I could find was one in really bad shape, stripped it and sanded it and then of course just before I got finished found "TWO" covers I had already done and didn't even know I had 2.. One is larger than the other so for sure I've got the right one at least..
Old 09-09-2016, 09:20 PM   #40
Ardmore, Alabama
Next took the furnace totally apart because the pilot light wouldn't stay lit, found out the thermocouple was bad luckily had a extra one.. once that was changed out I got the furnace lit but it would only burn a very small flame so I tore it completely apart and painted it with heat resistance paint..
Old 09-10-2016, 04:51 PM   #41
Trailer: Shopping for a boler
Will u consider selling one of your trailers ? If so can u text me at 250 300-1619 please
Thanku
Ladycenia33 is offline   Reply With Quote
Old 09-10-2016, 05:16 PM   #42
Please contact me at 250 300-1619
Interested in a trailer but maybe can u redo the inside of possible the way I would like it with my colors .
Thank you so much
trillium
Trillium Renovation Randy Bishop Modifications, Alterations and Updates 48 07-20-2015 11:18 AM
Trillium Renovation Randy Bishop Care and Feeding of Molded Fiberglass Trailers 1 07-20-2015 10:55 AM
AB (Canada) - Trillium 4500 - 1978 - $4500 David Tilston Referrals: Molded Fiberglass Trailers 16 04-22-2013 02:07 PM
Trillium 1300 Renovation Randy Bishop Modifications, Alterations and Updates 88 05-29-2012 03:50 PM
1979 Trillium 4500 for sale -- C$5200 or US$4500 - SOLD jenniferm Classified Archives 8 07-14-2009 02:38 PM
» Virginia Campgrounds
