Trillium furnace - Fiberglass RV
Old 08-29-2015, 08:55 PM   #1
dleverton's Avatar
Trailer: Trillium 1300 1973
Trillium furnace
Someone, I think David, mentioned the usual fault with the Trillium furnace is the sail switch.
We are a few days from a trip to Jasper and I realized I have never gotten the furnace going. So a couple questions:
1)how do you get it out? I had a couple quick tries and nothing would budge.
2) is it a sticky sail switch or slow fan or obstruction that is the issue?
3)my furnace is under the curb side settee and I have built a queen bed over it. I have no experience with this furnace so have no idea how well it might distribute warm air considering that air has to come out from under the bed. I could easily fabricate a channel with a fan in it. Any thoughts would be appreciated.
Doug L
Doug
dleverton is offline   Reply With Quote
Old 08-30-2015, 02:16 PM   #2
dleverton's Avatar
Well I have it out and the sail switch works well.
It does not maintain the pilot light. This is an older unit (Duo Therm 66012-005) and is pre thermocouple. Instead it has a Bourdon tube heated by the pilot light which activates the gas valve. I removed the end at the gas regulator and if I manually light the pilot light, the gas valve end does not expand as I think it should. Anybody know of a source for these?
Doug L
Doug
Old 08-30-2015, 02:34 PM   #3
dleverton's Avatar
Ah Ha, new revelation!
It is a thermocouple not a Bourdon tube. I put a milliVolt meter across it and it went up to 20mV when the pilot light was manually lit.
Doug L
Doug
Old 08-30-2015, 03:24 PM   #4
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Google ' DSI Service Guide ' , may be helpful.
Bob in Mb is offline   Reply With Quote
Old 08-30-2015, 03:42 PM   #5
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
If you have pilot light your half way there.
Now, take everything apart and clean it!
mszabo is online now   Reply With Quote
Old 08-30-2015, 09:20 PM   #6
dleverton's Avatar
So I have it working, but it is a very strange system.
Everything works except the thermocouple was mounted below the pilot light???
Even after the pilot flame had been on for 5 minutes, the tip of the thermocouple was cool to touch. If the furnace were to be inverted 180 degrees it would work perfectly. The following picture is after the fix.
Name:	ImageUploadedByFiberglass RV1440989669.585046.jpg
Now the thin copper tube (the thermocouple), is above the larger silver tube (the pilot gas tube). I couldn't flip the entire furnace but I drilled 2 new holes in the little manifold and flipped it.
My best guess is that there were 2 styles of manifold available depending on how you wanted to mount your furnace and my furnace had the wrong one.
Doug L
Doug
Old 08-30-2015, 11:49 PM   #7
dleverton's Avatar
Hey Bob thanks for the DSI link. Unfortunately mine is pre DSI. In fact I think it's prehistoric.
Doug L
Doug
Old 08-31-2015, 12:39 PM   #8
David Tilston's Avatar
Doug,
Your furnace is not like anything I have seen in a Trillium before. Could you post overall pictures of it?
Is it a forced air furnace? A sail switch implies a fan.
The standard Duo-Therm. Furnace for a 1300 would be like this, but without the blower:
Trillium Furnaces - 9-3608 Blower
Old 08-31-2015, 01:03 PM   #9
dleverton's Avatar
Trillium furnace
Hey David
It is forced air but different from the your link.
Name:	ImageUploadedByFiberglass RV1441047084.588156.jpg
ID:	88272Click image for larger version
Name:	ImageUploadedByFiberglass RV1441047103.056495.jpg
The 2 fans run coaxial from one motor.
It seems to run very well now, but it is so strange that it was mounted with the thermocouple below the pilot flame. I don't think it has ever run since installation, as I don't see how the thermocouple could ever be heated enough to latch the pilot valve, and the main gas valve would not go on without the pilot valve latched.
I would love to see a picture of the pilot manifold from an other unit.
I spent a number of hours yesterday contemplating if Duo-Therm had done something very clever that I was missing, or if it was simply installed with a special upside down version manifold. All the printing was right side up.
I suspect mine is odd because it is under the curb side settee.
Doug L
Doug
Old 08-31-2015, 01:47 PM   #10
To me, it looks like it is installed sideways.
I am calling this a PO install.
furnace, trillium
Trillium 1300 furnace removal... David Swinnard Problem Solving | Owners Helping Owners 7 11-28-2015 11:37 AM
Trillium 4500 Furnace Mic Shaw Problem Solving | Owners Helping Owners 7 10-04-2015 03:54 PM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
1977 trillium 4500 furnace again Mic Shaw Problem Solving | Owners Helping Owners 0 05-17-2009 05:54 AM
Furnace exhaust grille for Trillium wanted kevin242 Classified Archives 2 04-13-2009 08:22 AM
