Trillium furnace - Fiberglass RV
Old 08-29-2015, 08:55 PM   #1
dleverton's Avatar
Trillium furnace
Someone, I think David, mentioned the usual fault with the Trillium furnace is the sail switch.
We are a few days from a trip to Jasper and I realized I have never gotten the furnace going. So a couple questions:
1)how do you get it out? I had a couple quick tries and nothing would budge.
2) is it a sticky sail switch or slow fan or obstruction that is the issue?
3)my furnace is under the curb side settee and I have built a queen bed over it. I have no experience with this furnace so have no idea how well it might distribute warm air considering that air has to come out from under the bed. I could easily fabricate a channel with a fan in it. Any thoughts would be appreciated.
Doug L
Doug
dleverton is offline   Reply With Quote
Old 08-30-2015, 02:16 PM   #2
dleverton's Avatar
Well I have it out and the sail switch works well.
It does not maintain the pilot light. This is an older unit (Duo Therm 66012-005) and is pre thermocouple. Instead it has a Bourdon tube heated by the pilot light which activates the gas valve. I removed the end at the gas regulator and if I manually light the pilot light, the gas valve end does not expand as I think it should. Anybody know of a source for these?
Doug L
Doug
Old 08-30-2015, 02:34 PM   #3
dleverton's Avatar
Ah Ha, new revelation!
It is a thermocouple not a Bourdon tube. I put a milliVolt meter across it and it went up to 20mV when the pilot light was manually lit.
Doug L
Doug
Old 08-30-2015, 03:24 PM   #4
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Google ' DSI Service Guide ' , may be helpful.
Old 08-30-2015, 03:42 PM   #5
mszabo's Avatar
Trailer: U-Haul VT16
If you have pilot light your half way there.
Now, take everything apart and clean it!
Old 08-30-2015, 09:20 PM   #6
dleverton's Avatar
So I have it working, but it is a very strange system.
Everything works except the thermocouple was mounted below the pilot light???
Even after the pilot flame had been on for 5 minutes, the tip of the thermocouple was cool to touch. If the furnace were to be inverted 180 degrees it would work perfectly. The following picture is after the fix.
Name:	ImageUploadedByFiberglass RV1440989669.585046.jpg
Now the thin copper tube (the thermocouple), is above the larger silver tube (the pilot gas tube). I couldn't flip the entire furnace but I drilled 2 new holes in the little manifold and flipped it.
My best guess is that there were 2 styles of manifold available depending on how you wanted to mount your furnace and my furnace had the wrong one.
Doug L
Doug
Old 08-30-2015, 11:49 PM   #7
dleverton's Avatar
Hey Bob thanks for the DSI link. Unfortunately mine is pre DSI. In fact I think it's prehistoric.
Doug L
Doug
Old 08-31-2015, 12:39 PM   #8
David Tilston's Avatar
Doug,
Your furnace is not like anything I have seen in a Trillium before. Could you post overall pictures of it?
Is it a forced air furnace? A sail switch implies a fan.
The standard Duo-Therm. Furnace for a 1300 would be like this, but without the blower:
http://www.fiberglassrv.com/forums/f...wer-54226.html
Old 08-31-2015, 01:03 PM   #9
dleverton's Avatar
Trillium furnace
Hey David
It is forced air but different from the your link.
Name:	ImageUploadedByFiberglass RV1441047084.588156.jpg
ID:	88272Click image for larger version
Name:	ImageUploadedByFiberglass RV1441047103.056495.jpg
The 2 fans run coaxial from one motor.
It seems to run very well now, but it is so strange that it was mounted with the thermocouple below the pilot flame. I don't think it has ever run since installation, as I don't see how the thermocouple could ever be heated enough to latch the pilot valve, and the main gas valve would not go on without the pilot valve latched.
I would love to see a picture of the pilot manifold from an other unit.
I spent a number of hours yesterday contemplating if Duo-Therm had done something very clever that I was missing, or if it was simply installed with a special upside down version manifold. All the printing was right side up.
I suspect mine is odd because it is under the curb side settee.
Doug L
Doug
Old 08-31-2015, 01:47 PM   #10
To me, it looks like it is installed sideways.
I am calling this a PO install.
Old 11-16-2020, 09:33 PM   #11
Trailer: Trillium
St-hippolyte
Originally Posted by dleverton View Post
Hey David
Attachment 88272Attachment 88273
Doug L
I recently bought a 1980 Trillium 4500 and my duotherm furnace is exactly the same, located under a bench in the dīnette. Have to bend under the table to get accces! I am surfing on this forum to get info on it. Wondering what your outside exhaust looks like? Found a instruction manual on internet, previous owner lit it when I bought it ( wanted to see if it worked oK), but can’t remember how to light it.
SylvieK is offline   Reply With Quote
Old 11-16-2020, 10:36 PM   #12
dleverton's Avatar
Hi Sylvie
I eventually gave up on it and found another furnace. I don’t easily give up on this sort of thing, but after 30 trips under the bed to study it , I gave up. It did latch after I rotated the position of the thermocouple, but 10 minutes later it would quit. I had the regulator out and apart so many times and I suspected the latching solenoid had shorted turns. I still have it.
Doug
Old 07-07-2022, 05:38 PM   #13
Trailer: Unkn
Wisconsin
My thermocouples is below my flame, but...
Attachment 88256
Doug L
It's supposed to be that was because when the pilot flame is high enough the flame splits and the bottom part hit right on the thermocouples that sits below where the propane enters the furnace. I'm glad it works for you but I have the exact same furnace and it's located where yours was and works fine. Again, I had to adjust my pilot a little.
srm777 is offline   Reply With Quote
Old 07-07-2022, 05:44 PM   #14
Trailer: Unkn
Wisconsin
Attachment 88256
Doug L
It's supposed to be below the flame. I have the same furnace and the pilot flame splits when high enough and the lower part of the split flame hits right on the thermocouple where it keeps it heated to stay running. You may need to adjust the pilot by removing the slotted screw and putting a small flat blade screwdriver down the hole and turning counterclockwise.
Old 07-07-2022, 05:46 PM   #15
Trailer: Unkn
Wisconsin
Sorry for the double post, just getting used to this forum.
furnace, trillium
Trillium 1300 furnace removal... David Swinnard Problem Solving | Owners Helping Owners 7 11-28-2015 12:37 PM
Trillium 4500 Furnace Mic Shaw Problem Solving | Owners Helping Owners 7 10-04-2015 03:54 PM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
1977 trillium 4500 furnace again Mic Shaw Problem Solving | Owners Helping Owners 0 05-17-2009 05:54 AM
Furnace exhaust grille for Trillium wanted Kevin242 Classified Archives 2 04-13-2009 08:22 AM
