Trillium furnace issues - Fiberglass RV
Old 04-14-2016, 10:06 AM   #1
dleverton's Avatar
Trailer: Trillium 1300 1973
I have a (Duo Therm 66012-005) furnace under the curb side settee of my Trillium 1300. Also, I have built a semi permanent queen size bed which makes the furnace difficult to access. Lighting the pilot on the furnace is at best an ordeal, but if the pilot blows out on the road or you need to shut the propane off, the ordeal is repeated. I thought about adding an electronic igniter, but that still leaves the issue of standing on your head under the bed to turn and press the knob in order to latch the pilot on. Lately I have been thinking about fabricating levers and pulleys to control the knob remotely, and it may come to that.
Does anyone have any ideas of what modern electronically ignited (no pilot), type furnace might fit, or any ideas regarding conversion of the old Duo Therm to a modern no pilot system? Once lit the Duo Therm works very well and I have resolved the air distribution, so I'm fond of the old beast, except when the pilot needs relighting.
Doug
Doug
dleverton is offline   Reply With Quote
Old 04-15-2016, 02:53 PM   #2
Old heaters - a word of caution.
We have a 1976 Trillium 1300 that still had the original old gravity-fed propane heater. Not sure if it was the same as yours but I decided to scrap mine. Gravity feed hasn't been considered safe since around 1980. And when I removed the heater to examine it I found the exhaust pipe to be badly corroded and half full of mud-wasp nests. Etc. It was time to recycle it! The moral is, if you're going to keep an old appliance, be sure it is safe. We get by quite well without it, using a small electric heater and powered campsites in the cooler weather.
A company called Propex makes an interesting propane heater that would fit and I think heat a small trailer very well. It isn't cheap, but around the same price as any replacement furnace. Have a look here: Propex Heaters
Randy J. is offline   Reply With Quote
Old 04-15-2016, 03:18 PM   #3
David Tilston's Avatar
Randy, Doug's heater is not a gravity furnace, but a forced air model, as detailed in this thread:
Trillium furnace
I wish I had something to offer Doug, but I don't. I doubt that modifications to this furnace will be practical. Best of luck.
Old 04-15-2016, 10:22 PM   #4
dleverton's Avatar
RANDY
Thanks for the safety suggestion, I have had it out and it seems solid. And, thanks for the lead on the replacement unit, it does look like a nice unit.
DAVID
Thanks for your thoughts.
I think I'll pull it out again and at least install a piezo igniter, and make sure the pilot jet is clean and my propane pressure is reasonable. If I can get it to stay lit while parked I'll just have to do the acrobatic number once a trip.
Doug
Doug
furnace, trillium
Trillium 1300 Bargman latch wear / door issues FlatlandFlyFisher Problem Solving | Owners Helping Owners 2 08-31-2015 03:18 PM
Handling issues (1979 Trillium / 2000 Subaru outback) FlatlandFlyFisher Towing, Hitching, Axles and Running Gear 26 12-25-2014 09:58 AM
Scamp furnace issues - John Carter Problem Solving | Owners Helping Owners 14 11-28-2013 07:26 AM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
Trillium refridgerator issues. Nicole D Problem Solving | Owners Helping Owners 5 07-26-2011 03:59 PM
» Trailer Showcase
TBD
Andi
Jet Puffed
Tina in AZ
