Trillium Interior Reno - Kichen / Dinette Mock up - Page 2 - Fiberglass RV
Old 03-22-2013, 07:54 PM   #15
Trailer: Trillium Jubilee 15'-0
A few more pics ........
peatle is offline   Reply With Quote
Old 03-22-2013, 08:34 PM   #16
Amazing, absolutely amazing. I love the idea of using a "bucket" to get the shape you're looking for
GREAT... Thanks for the documentation!
Old 04-07-2013, 02:04 AM   #17
A few update pics on progress of the Kitchen " front dinette reno.
The kitchen cabinet is 95% done and likewise with the dinette. The doors on the kitchen cabinet are 1/2" Ultralite MDF faced with the same 1/8" maple ply, stained 'honeydew' as used elsewhere. This made the doors as light as possible but, at only 5/8" thick, care has to be taken when boring the 35mm holes for the euro hinges. I am very pleased with this finish as it is a nice light and airy look whilst retaining some imuted graining to give a little bit of character to the door and drawer faces.
I stole the room to squeeze in the plastic trays on the flop down dummy drawer front in front of the sink by by nudging the sink back a little extra. These trays help get rid of a lot of clutter around the sink as it is so easy to drop in soap, dishcloth, brillo pad and they have two little plastic hooks in them for the girls to hang their rings on while at the sink. One of the trays will do for 'sink stuff' and the other can be used for our toothpaste, brushes floss etc.
Instead of building a full drawer bank to the right of the sink cabinet I just made one slide out shelf out of 1/4" ply, with a drawer front on it, at the top. This will just get a plastic cutlery tray screwed on to it that has been cut to fit.
Below that there is another door behind which are two more slide out shelves with Sterilite light plastic bins screwed on plus a larger bin sitting on the bottom shelf. These 1/4" shelves simply run in a pice of 3/8" Aluminum Channel on the left side and a rebated wood strip on the right that's wide enough to keep the edge of the shelf from catching the inside corner of the door which always projects into the opening a little when using the Euro hinges. I use Euro hinges whenever possible because of their three way adjustability for evening up the gaps between doors and draw fronts plus the 'clip top' type allow the door to be removed and replaced in a matter of seconds. This is really great when wanting to do some work in the confined space inside these small cabinets.
I made the shelf in the bottom of the cabinet removable so that I could run the wiring from the converter, which will be mounted under the dinette seat that is adjacent to the kitchen cabinet , through this cabinet and through a channel. This channel goes across the floor in front of the bed area and over to the cabinet opposite the kitchen that has the fridge, microwave and TV built into it.
Old 04-07-2013, 05:49 AM   #18
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
Wow! Very nice work! Are you a carpenter?
Old 04-07-2013, 06:04 AM   #19
Oh man! This is looking really, really nice
Old 04-07-2013, 07:43 AM   #20
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Oh Peter this is amazing! Will you come to Virginia and do my kitchen? Can there be such a thing as "too nice for camping" ?
D Davis is offline   Reply With Quote
Old 04-07-2013, 07:54 AM   #21
cpaharley2008's Avatar
Nice work, one question re: sink. Is there a "p" trap there or Hepvo valve in use?
Old 04-07-2013, 08:15 AM   #22
Yes !
Old 04-07-2013, 08:30 AM   #23
The waste on the sink is just roughed in at the moment and I have to look into traps etc a little further.
The tiny sink that was in the old kitchen had an upside down dome type fitting under the outlet ..... is this the "Hepvo" valve you mention ? Presumably this forms a trap for sewer gases.
I'm wondering if I need any kind of a trap here as the outlet through the trailer wall just empties out into a 5 gallon plastic bucket that has no accumulation of fumes .... I'd be grateful for any thoughts that you have on this !
Old 04-07-2013, 08:49 AM   #24
Well Diane .... we are planning on driving from BC to Nova Scotia via the U.S. this year ( if I ever get this bloomin trailer finished that is ) and as much as we would dearly love to see Virginia I think the time might be a little too tight to fit it in. Thanks for the invite though !
Old 04-07-2013, 09:07 AM   #25
ndquiltlady's Avatar
Trailer: 1979 Trillium 1300
North Dakota
Wow!!! Looks great - almost makes me want to clear mine and start over...nah, would cut into camping time!
ndquiltlady is offline   Reply With Quote
Old 04-07-2013, 09:34 AM   #26
theresa p's Avatar
New Brunswick
peter---EXCELLENT reno job! everything is so very well thought-out.
are you planning on putting your fridge on the curbside? and what about a furnace?
Old 04-07-2013, 09:10 PM   #27
Thanks Theresa ....... the fridge is actually in place in a cabinet opposite to the kitchen but there is no door on it so it's not too visible ... see attached pic. I was advised on the forum to prop the door open while the fridge was dormant through the winter. I decided to take the door off and pull it apart and clean it up and spray paint it's front panel. The fridge face surround, where the hinges are, was pretty ugly too with scratches and rust across the bottom where there had been drips of moisture so these four strips of metal got pulled also, ground clean and repainted.
I have pulled the furnace out as I don't think we'll be doing too much real cold weather camping and can better use the space that it occupied. We can use a little buddy heater if we are without shore power in the fall or spring. The furnace worked well and I still have it along with it's vent and thermostat.
Fidge : Microwave cabinet.jpg
Old 04-08-2013, 05:56 AM   #28
no tank, no trap needed.
trillium
Bigfoot Interior Reno Completed jimmied Modifications, Alterations and Updates 36 06-12-2016 06:58 AM
Trillium Interior Reno - O/head cabinet sliding doors peatle Modifications, Alterations and Updates 11 03-06-2013 11:23 PM
Scamp 16 side dinette interior measurements 2wiresdave Problem Solving | Owners Helping Owners 1 04-05-2012 04:38 PM
Scamp 16 ft side dinette -wood interior. Karalyn Classified Archives 8 08-17-2011 08:19 PM
Interior Reno Dawn S Modifications, Alterations and Updates 4 11-02-2009 05:50 PM
