Trillium interior walls - Fiberglass RV
Old 04-18-2015, 07:06 PM   #1
I just bought a Trillium and the previous owner has painted the interior walls with a latex paint. Has anyone had experience with removing paint from the interior walls? I would like to get the trailer back to as close to original.
hixon is offline   Reply With Quote
Old 04-26-2015, 10:32 AM   #2
Trailer: Trillium 1300
that will likely be close to impossible…you would have to really soak them and scrub the heck out of them…i just painted mine and i love it - there are some stripping products in the market but they may do more damage to the ensolite than just removing the paint. maybe just pick a new colour and repaint…good luck either way!
littlemisspippy is offline   Reply With Quote
Old 04-26-2015, 12:10 PM   #3
Raz
Raz's Avatar
Vermont
Hello Ann and welcome to the forum. Trillium used a vinyl coated ensolite as interior wall covering/ insulation. It is common for folks to paint it. What ever you do don't remove it. Raz
Old 04-26-2015, 06:04 PM   #4
Thanks for the tips. I came to the realization that I can live with a new coat of paint. Mostly it was just so poorly applied my first reaction was to get it off! Now my other problem is removing the same paint from the green fibreglass around my sink and closet.... I'm sure it will come off with a low heat setting on a heat gun. Has anyone else had experience with removing latex paint not he inside fibreglass? I'm a total newbie here and have a lot of stuff to figure out but if I can get the floors and walls sorted for the time being I'll be happy!
Old 04-26-2015, 07:47 PM   #5
hmmm...would depend on how the PO prepped it - if they just painted a latex over it with no priming, you may be able to "scrub" it off...if they did it properly, again, it may be a bit of a challenge. Not sure about using a heat gun - I don't have enough of that kind of experience - some of the other members may.
Old 04-27-2015, 10:07 AM   #6
David Tilston's Avatar
A heat gun will likely soften up the resin as much as the paint. I have tried a heat gun. I put a groove in the gel coat. Not recommended.
trillium
Perris Pacer: Fixing interior walls Eve V. Care and Feeding of Molded Fiberglass Trailers 7 09-24-2016 02:13 AM
Success with Int paint walls,countertops,Cabinets, Carpet for floors. Walls, too? Gigi Problem Solving | Owners Helping Owners 2 08-31-2012 11:13 AM
Experimenting with different materials for interior walls kevin61 Modifications, Alterations and Updates 26 06-29-2010 08:47 PM
Another approach to finishing interior walls Brian Scott Problem Solving | Owners Helping Owners 12 03-08-2008 05:02 PM
Interior Closet Walls Legacy Posts Problem Solving | Owners Helping Owners 5 08-09-2003 07:08 AM
