Trillium Jubilee rebuild - Fiberglass RV
Old 08-27-2016, 06:55 PM   #1
Trailer: Trillium
Nova Scotia
Hello!
I'm currently gutting my newly acquired Trillium Jubilee. I'm almost down to the shell. My first order of business, I believe, will be to rebuild/reseal the windows. Is there a special type of wood I should be using to replace the rotted plywood? I assume I would just use plywood again. Is it worth getting marine-grade plywood? Should I fibreglass-in the new boards, or cover them with resin/epoxy?
Here is a photo of one of the windows. The plywood seems to be fine on all sides except for the top.
Any advice you have would be greatly appreciated!
Jennygdeans is offline   Reply With Quote
Old 08-27-2016, 07:31 PM   #2
Carl V's Avatar
I think most people used plywood.
I used cedar planks, cut to size. Better water/moisture resistance IMO. But then the original plywood lasted decades...
None of my local hardware stores carried "marine grade" plywood. All they had was "exterior grade". They could get me the marine, but it was much more expensive. I don't think it was worth it, "exterior" would have been good enough.
Use only butyl tape to reseal the windows.
Use stainless steel screws to put it back.
Make sure you clean the window flange and trailer before putting the window back on.
I used a metal brush on my drill to clean the grime off, then some "Scrubbing Bubbles" cleaner.
Don't over tighten the screws.
If you have a window crank that's not working right, it'll be the time to replace it, as the window must be off to fix it.
It's not a difficult job. The hardest part for me was to remove the old silicone sealant the previous owner used, and unglue the ensolite insulation from the wood frames. It's easier if you have someone to help when the time comes to take the window off or put it back in, especially the larger windows.
Lots of pictures on my renovation thread: http://www.fiberglassrv.com/forums/f...tml#post545110
trillium
Help! Upper bunk Trillium Jubilee rebuild Bee in Canada Problem Solving | Owners Helping Owners 2 04-10-2015 10:11 AM
15ft Trillium Jubilee webber33 Classified Archives 4 08-17-2006 07:36 PM
Trillium Jubilee Bill F. General Chat 4 05-11-2006 08:15 AM
SOLD 1980 trillium jubilee heller372 Classified Archives 0 05-01-2006 02:14 PM
1980 Trillium Jubilee for sale General Chat 0 01-01-1970 12:00 AM
