Trillium Queen Bed option revisited - Fiberglass RV
Old 09-12-2014, 01:15 PM   #1
Raz
Raz's Avatar
Vermont
A few years ago Barrie Bochoff posted how he expanded the bed in his Trillium by rotating his sleeping position and utilizing the space between the closet and the sink.
Trillium queen bed option
I finally got to try it for myself.
When we first got the trailer I replaced the rear dinette with a piece of plywood to make a permanent bed. The rear table was cut down to make a larger front dinette. By using that table, a wall mount table bracket ($10-15), a few pieces of scrap pine and some thread rod, I was able to make a very stable, easily assembled bed extension. Maggie is working on the bedding issues which include utilizing the front cushions. We'll let you know how it works out. Raz
Old 09-17-2014, 08:45 PM   #2
Trailer: 13 ft Boler 1986
Difference is that with ours I hung it under the origiinal table (taking off the table leg of course) so it slides in out of the way in the day time and I just flipped the mattress up onto the bed during the day. One side rests on our food cupboard and the other side has a fold-up leg to rest on.
We used it for about ten years now. Our little dog used to sleep with us and the cat still does, so we needed the extra space. The dog is gone and I had a hip replacement so found the climbing down to the bottom of the bed a bit of a pain so until I am back to normal, we are making "do" with the old system!!! Yuk!
Vivian L is offline   Reply With Quote
Old 09-18-2014, 03:31 AM   #3
Raz
Raz's Avatar
Vermont
Ten years. Sounds like you were happy with it. I have wanted to try this for quite some time and finally got to building it. We've yet to try it. I have to reverse the refrigerator door so it will open to get to the milk in the morning and move some things out of the closet. We currently have a puppy so she will fit any where. For now. Hopefully she won't get too big. Thanks for posting. I'm encouraged. Raz
Old 09-18-2014, 07:19 AM   #4
Worked quite well. Because we are shorter people, I only needed to pull out the extension to the edge of the closet, which left the fridge door clear. I cut the closet door into two - a shorter one at the bottom with a longer one on the top. The longer one clears the bed extension so we could still get in the closet as well. I have attached a photo of the new closet doors. The seat just below the bottom door is actually the top of our food drawers, which I found short enough to fit under the extension (it actually rests on that on that side).
Since the dog slept on the bed, we had no problem but she was a little Shih Tzu! Cat just wanders around wherever he likes. You know how they are.
Enjoy and good luck. Post to let us know how you like it once you get to try it out for awhile.
Old 10-09-2014, 02:38 PM   #5
WA
This is exactly what I want to do. Thanks for the post. I assume though that you lose the storage space under the table/bed when you do this right?
Colleeno is offline   Reply With Quote
Old 10-11-2014, 08:02 PM   #6
dleverton's Avatar
Trailer: Trillium 1300 1973
We are considering cutting away the sink area down to bed level, cutting away the lower half of the closet in order to put in a Queen size bed in our Trillium 1300. Radical I know, but sleep comfort is our number one priority. Any thoughts?
Doug Leverton
Doug
dleverton is offline   Reply With Quote
Old 10-12-2014, 11:43 AM   #7
WA
I assumed that the kitchen and closet units add structural integrity to the trailer. If I were to do this, I would consider adding struts to support the ceiling and etc. but I'm a newbie.
Old 10-12-2014, 01:57 PM   #8
Not really. We installed two outside access doors, one on each side allowing outside easy access to the areas under the table seats. We use those two spaces for jacks, blocks, tanks, anything that tends to get grubby.
The centre space beneath the table is still useable by simply putting stuff in tubs and attaching long enough pull strings on the tubs so we can pull them out to get at whatever is in them. The kitty litter box takes up the front area of one side at night and we put shoes, slippers, boots, spare linens etc on the other side. So all the space is still well utilized.
Enjoy.
Vivian
Old 10-12-2014, 04:16 PM   #9
WA
By "outside" do you mean on the ouside of the trailer? If so, I'd love to see pictures. Seems a very handy adaptation.
Old 10-13-2014, 06:07 AM   #10
Yes I mean outside the trailer. Here is a picture of the off-side one. Both are the same.
They are 15.5" x 10.5" making them small enough to clear everything inside. All we had to do was move the side marker lights up. We hung them right side up in case they came open during transit, but some people mounted them the other way. Your option. We could not get small enough ones up here in Canada so a fellow over near the border brought these in from the US. If you can't find them let me know and I'll find out where he got them.
PS: We also ran an extension chord from our converter, under the bed and over to the door-side area, put in another outlet cap and pull the extension chord out so we have outside hydro on that side of the trailer. I didn't install a permanent outlet because I won't do anything with electrical and I do all this stuff by myself.
Enjoy
Vivian
Old 10-13-2014, 12:44 PM   #11
WA
Thank you Vivian, makes all kinds of sense to do that. I'm a newbie to trailer land but I may just find the courage to do this sometime. Thanks again for posting
Old 10-13-2014, 02:28 PM   #12
You're welcome. Let us know if and when you ever do this, how you made out.
Vivian
Old 10-13-2014, 08:43 PM   #13
Barbara Gardin's Avatar
If you can't find smaller doors at a RV dealer try a boat dealer. We got one of ours there.
Barbara Gardin is offline   Reply With Quote
Old 10-17-2014, 06:54 AM   #14
Raz
Raz's Avatar
Vermont
Just back from a couple weeks in the Outer Banks of N.C. We used the bed arrangement the whole time. Because I'm using the front dinette table, we set up the extension each night. It took about 5-10 minutes to set up the support, attach the table, and add the bedding. Maggie used a fitted sheet tucked under the main mattress to hold the extra cushions in place. The extra space at the top was a big improvement over the stock bed. Maggie sleeps on her back. She really likes the configuration. I sleep on my side and tend to change sides numerous times in the night so I noticed the confined leg space more than she did. For the upper 4 feet, you have more than a queen and the lower 2 feet, less than a single (about 32").
The porta potti fit nicely at the foot of the bed. Since you can't exit the bed from the sides, to use it in the night requires a bit of a crab walk to the foot the bed.
When we first got our Trillium we went to a permanent bed using a sheet of plywood. It is short enough that by rolling the mattress at each end we can access to the rear storage compartments. Since the table/extension is removed during the day, all of the other storage is accessible. Raz
Large Dinette, Queen sized bed, and a Couch! My ParkLiner! deryk Modifications, Alterations and Updates 25 04-02-2014 01:58 PM
Queen size bed in a Casita? frank_a Problem Solving | Owners Helping Owners 16 08-21-2013 07:53 AM
Trillium queen bed option Barrie Bochoff Modifications, Alterations and Updates 10 12-03-2011 07:46 PM
Seeking w/ queen bed near NE Florida Jim and Diane Wanted: Molded Fiberglass Travel Trailers 0 04-24-2011 03:58 PM
2005 25' Bigfoot Rear Queen Bed For Sale F.Bishop Classified Archives 7 11-08-2009 09:03 PM
