Trillium window sealant - Fiberglass RV
Old 06-03-2015, 12:00 PM   #1
dleverton's Avatar
Trailer: Trillium 1300 1973
I have recently reinstalled the windows on my 1300. The butyl rubber worked really well, but the local RV dealer recommended sealing the edge with a product called Captain PHAB white marine sealant. I am hesitant to use it as I don't know what it is. Has anyone experience with this product? Or has anyone a recommendation? I remember someone here recommending a silicone and this is not an application that needs shear strength, so the dreaded silicone might work well, but I have never had much luck applying it smoothly. Thanks.
Doug L
Doug
dleverton is offline   Reply With Quote
Old 06-04-2015, 09:45 AM   #2
Trailer: 1978 Trillium 4500
Hi Doug, I just used exterior, printable caulk around the sides and top of the window making sure I left the bottom open for drainage should water get in. Then I painted the caulk as it attracts dirt that does not wash off.
By the way, the belly band is almost finished.
Island Bolers and Friends on Facebook
Island Claire is offline   Reply With Quote
Old 06-04-2015, 10:47 AM   #3
dleverton's Avatar
Hey Claire. Thanks, sounds like a plan. Good meeting you and Rob. Glad the belly band is working out.
Doug L
Doug
Old 06-08-2015, 01:13 PM   #4
dleverton's Avatar
I ended up using a product called ProflexRV. It looks and feels like a silicone but is a mix of thermoplastic rubber and hydrocarbon resins. Going slow I was able to lay down a finished bead in most places without tooling. Where tooling was needed I used my finger dipped in liquid detergent. I made a real mess in one spot and cleaned it immediately with paint solvent on paper towel and it came up quite nice.
Doug L
Doug
trillium
??Questions about front window over hitch?? Paint? Sealant? Coby Modifications, Alterations and Updates 9 04-22-2014 09:39 PM
window sealant jlbails Problem Solving | Owners Helping Owners 1 09-05-2012 08:32 AM
Mulco Flextra Sealant for Trillium Belly Band Rodre Problem Solving | Owners Helping Owners 3 07-20-2011 07:43 AM
Old Style Window Sealant DannyH Problem Solving | Owners Helping Owners 9 01-21-2010 08:32 AM
Fiberglass camper roof penetration sealant Rob and Dot Problem Solving | Owners Helping Owners 3 09-10-2007 11:07 PM
