Trim for table edge - Fiberglass RV
Old 12-20-2010, 11:34 AM   #1
Trailer: 1983 Scamp 16
Trim for table edge
I'm going to build a new dinette table for our Scamp. I will be started with a new piece of wood for the table top. The top will be covered with "brushed aluminum" finish formica but I'm not sure what to do to finish the edges. Any suggestions?
I supposed I could use a strip of the formica along the edge, but I would rather trim it with metal. I can't seem to find any trim in the 1/2" width needed.
Steve in TX is offline   Reply With Quote
Old 12-20-2010, 11:58 AM   #2
Matt in SV's Avatar
You want Tee Moulding or Edge Banding. This should get you started.
These are plastic tees
Outwater Catalogs - 2010 Master - page 18
Here's the aluminum tee. There's a half inch toward the bottom. You can click on the page to get the detail
http://www.outwatercatalogs.com/lg_d...atalog/page/19
You can also buy aluminum U channel that would do a better job of protecting the edge if you are going to be doing the dinette-to-bed conversion. It's going to be harder to install.
I am thinking that for the tight corner radius, you may need to have a tool or form to bend the metal without kinking. You'd probably need an edge with a tighter radius than planned to shape against. It will relax a little, so you'd want to over-form, but not kink it.
http://www.outwatercatalogs.com/lg_d...atalog/page/30
Regards,
Matt
Planning our next Escape!
Old 12-20-2010, 07:04 PM   #3
CliveAlive's Avatar
Trailer: Boler American #3104
Vintage Trailer Supply has aluminium trim to give a vintage look but it's larger than 1/2". Have you considered adding strips around the edge underneath the table to bolster it up. Then you could use one of these ...
Countertop Edge Moulding - 3/4" Polished
or
Countertop Moulding - 13/16" Satin
Old 12-22-2010, 08:13 AM   #4
Thanks for great suggestions, Matt and Clive! I'll need to take some more detailed measurements and make a decision which route to go.
Aluminum trim for table Kevin M Problem Solving | Owners Helping Owners 25 08-08-2014 08:52 PM
Edge Cover - Help Needed Judith Kennedy Care and Feeding of Molded Fiberglass Trailers 15 10-21-2009 02:39 PM
edge protector strips ronsmith100 Care and Feeding of Molded Fiberglass Trailers 5 04-02-2009 01:35 PM
Aluminum Table Trim Legacy Posts Problem Solving | Owners Helping Owners 9 07-16-2003 09:02 AM
