Trimming our larger replacement fridge - Fiberglass RV
Old 03-24-2016, 11:44 PM   #1
Hi....as I've seen on other threads, the new replacement Dometic fridge for our 1973 Trillium 1300 is going to be larger than existing. What sort of cosmetic solutions have others done to make this extra protrusion of 2-3" proud of the existing vertical face, look intentional? We've done a nice, full restoration of this trailer, and don't want the compromise the 'look' of the interior all because we can't get smaller fridges anymore. Unfortunately, our existing is beyond refurbishing. Thanks.
Krista is offline   Reply With Quote
Old 03-25-2016, 01:16 AM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Hi Krista, not sure what you mean by "extra protrusion".
Old 03-25-2016, 06:49 AM   #3
Trailer: 2014 Escape 21
Virginia
Scamp uses 1x? oak boards to fill the space between the frig. and the front cabinet. They use oak boards with the older oak standard cabinet doors. They rip the boards to fill the gap then made a frame, attached the frame to the cabinet, then they attached frig to the frame.
Eddie
Old 03-25-2016, 08:35 AM   #4
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
This photo shows the build out of wood trim that Eddie was speaking of above.
bpfick is offline   Reply With Quote
Old 03-25-2016, 12:03 PM   #5
james kent's Avatar
Trailer: Boler 1984
Name:	ImageUploadedByFiberglass RV1458928833.575158.jpg
Our replacement fridge extends about 1 inch into thetrailer. We framed it a spacer made from 3/4 plywood and found some paint that matches the cabinets.
Old 03-25-2016, 02:08 PM   #6
Virginia
If you don't want the wood look you could try using white PVC trim for a spacer. Home Depot sells it and usually they have a good selection of widths.
Eddie
Old 03-25-2016, 03:07 PM   #7
Thanks everyone!
fridge
Wanted 17' or larger Fiberglass Trailer Jay Moeller Wanted: Molded Fiberglass Travel Trailers 0 04-25-2008 10:38 PM
Larger tires/rims for my Bigfoot? Simon B Astin Towing, Hitching, Axles and Running Gear 4 04-16-2008 09:43 PM
Larger Fresh water Tank Ideas Steve Rosenberg Plumbing | Systems and Fixtures 8 12-15-2007 06:36 AM
Any Egg 16 foot or larger in Pacific Northwest? Jay Moeller Wanted: Molded Fiberglass Travel Trailers 0 08-16-2007 10:38 PM
Larger tires/rims for my Bigfoot? Simon B Astin Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
