Truck bed storage DIY - Fiberglass RV
Old 02-11-2019, 08:30 AM   #1
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
I built a system to help better organize my camping stuff. Itís made of half inch plywood and is totally removable with no hardware holding it together. Comes apart into six pieces and the drawer if needed. Chorizo approves and is ready for some camping!Click image for larger version
brian
2003 Casita SD 17'
http://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 02-11-2019, 12:55 PM   #2
francene's Avatar
Trailer: 13 ft Compact II
Truck bed storage
Looks good, Brian!
I am interested in a better solution for all the camping gear, and I dislike crawling on the bedliner floor; hurts the knees!
So this looks like a good approach for use only when camping. I use the entire truck bed space otherwise; but when camping, your modification transforms the space temporarily.
Fran
'74 Compact II
2008 Tacoma, access cab
francene is offline   Reply With Quote
Old 02-11-2019, 01:48 PM   #3
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
I retrieve stuff from the front of the truck bed with an old broom handle to which I attached a stiff piece of metal from an old bed spring bent to a 90 degree angle. It works great, saves my knees. Drilled a hole in the end of the handle and glued the metal piece in it with gorilla glue. Its a good idea to wrap some wire around the end to keep the wood from splitting.
Every day is a Saturday
Old 02-11-2019, 02:35 PM   #4
brian m.'s Avatar
Originally Posted by francene View Post
Looks good, Brian!
Fran
'74 Compact II
Thanks Fran!
Yes, I also have to be able to use my whole truck bed at times so this can all come out.
brian
2003 Casita SD 17'
Old 02-11-2019, 02:36 PM   #5
brian m.'s Avatar
Yep. I used something similar in my old truck and will probably do a new one for this set up .
brian
2003 Casita SD 17'
Old 02-13-2019, 01:27 PM   #6
brian m.'s Avatar
Still making a few mods to this set up, but tests show it's going work out. Plywood pieces are finally getting spray painted this week!
brian
2003 Casita SD 17'
Old 02-13-2019, 01:37 PM   #7
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
My sense is that I would keep only light stuff on top of the platform, limiting the heavier stuff to the bottom to keep it from coming through the rear window in an emergency stop. Otherwise pretty tidy.
Without adult supervision...
Also,
Old 02-13-2019, 02:10 PM   #8
brian m.'s Avatar
Yep Steve, that's sort of the plan. Without the platform I had camping totes stacked two high and it was a pain. They were as high as one tote up on the platform will be. Definitely will keep an eye on them.
brian
2003 Casita SD 17'
Old 02-13-2019, 07:35 PM   #9
Trailer: BigFoot
I have a 2011 Tundra 4x4 5.7L. I have a fiberglass camper shell with tilting side windows and a bed slide. I then use eight stackable blue plastic open top bins, four to each side. That leaves the center open for long items such as canopies and chairs. Works very well, I can reach everything without having to crawl inside or pull containers out.
But...This really cuts into my payload capacity. If I had it to do over again I would do something like Brian has done, however, I would have to make it as light weight as possible. Ultimately I may even have to buy a 3/4 ton or 1 ton truck. Yuck. I like my Tundra.
Rzrbrn is offline   Reply With Quote
Old 02-13-2019, 08:42 PM   #10
brian m.'s Avatar
Those sliding beds are very nice but they do cut into payload because of their weight. Iím probably at around 100 lbs for the whole setup. I think my all in costs were under $200 also.
brian
2003 Casita SD 17'
Old 02-14-2019, 08:44 AM   #11
NW Cat Owner's Avatar
Trailer: Escape 21' 2nd Gen, picked up on Black Friday 2016
Got basically the same thing from Amazon. Yeah, I make clocks and cards using rubber stamps, but that's as far as my make-it-yourself skills go.
they also have a telescoping version. I got the one that doesn't and it fits on the ledge around the edge of the truck bed where the canopy attaches.
https://www.amazon.com/Access-70950-...s=ez+retriever
I also have a couple of gardening foam pads in case I do have to crawl around in the back of the truck.
Laura and Dirk, and Spike, Sam & Jasper (the cats)
www.UnderKittySupervision.com
NW Cat Owner is offline   Reply With Quote
DIY Pull-out bed Ellpea in CA Problem Solving | Owners Helping Owners 6 09-02-2015 10:42 AM
Truck Bed Storage Ideas carlkeigley General Chat 38 05-29-2013 05:07 PM
Scamp 5th wheel truck bed and rail height Rhys H Towing, Hitching, Axles and Running Gear 4 07-18-2008 10:55 AM
Storage, Storage, and Storage Legacy Posts Problem Solving | Owners Helping Owners 18 11-20-2002 10:43 AM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
