TV connection - Fiberglass RV
Old 09-12-2015, 11:39 AM   #1
Trailer: 17 ft Casita
TV connection
Does anyone know how to watch TV on computer monitor using cable type connection on my 17' casita? I don t want to take both older TV and monitor. Thanks...Jon
jon farris is offline   Reply With Quote
Old 09-12-2015, 12:22 PM   #2
Well you need a turner somewhere in the mix, and the type of tuner depends on the type of cable signal. If its unscrambled QAM then you need that type of turner, if its ATSC (like off the air broadcasts) then you need a ATSC tuner. Most new HDTV digital televisions support both of these standards.
I use this USB device this for watching Off the Air TV and Clear QAM (which is used in some cable TV systems). It still requires a computer (or laptop in my case).
Here is the Amazon link.
I'm sure you could also get a stand alone tuner as long as it interfaced to the monitor for both video and sound (likely using HDMI cable). I find HDMI to be flaky at times however.
Old 09-12-2015, 12:52 PM   #3
Thanks alot for the info. Local TV isn' t much but better than nothing. Thanks again...Jon
Old 09-12-2015, 12:58 PM   #4
Trailer: Class A Motorhome
We use a standard HD flat screen for both a TV and a computer monitor, works great for our needs when we want to use the computer, stream a movie, watch a DVD or find a local off-the-air station.
Old 09-14-2015, 02:30 PM   #5
You could get one of the TVs that also will serve as a monitor and do both.
Best Buy has the insignia that we old fo that and has a DVD built in and has a 12 volt power supply as well.
You might look into that. They are not too expensive.
Sent from my SCH-I605 using Fiberglass RV mobile app
Old 09-15-2015, 08:37 AM   #6
Well, it s back to Best Buy! Thanks to all...Jon
MySQL connection error Brian B-P Forum Admin, News & Announcements 3 04-24-2006 07:20 PM
9-pin electrical connection Legacy Posts Problem Solving | Owners Helping Owners 5 01-06-2003 06:56 PM
Pig Tail Connection Legacy Posts Problem Solving | Owners Helping Owners 7 11-01-2002 06:46 PM
Trailer plus connection. Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-25-2002 07:31 AM
